Question about Air Tools & Compressors
I need to know where the Reset button is on the D55153 electric Air Compressor please
3 Suggested Answers
  • 21 Answers
SOURCE: My electric air compressor will not start. Is
On the small one that use oil , there is one behind the plastic housing. but mos the oil-less, small ones have a small fuse attached to the motor.
Posted on Sep 26, 2009
claudeinmo
  • 9098 Answers
SOURCE: Dewalt d55153 air compressor. Why won't it turn on?
DEWALT Service and Support ' Manuals and FAQs
www.dewalt.com/parts-and-service.aspx
DeWaltDownload instruction manuals for your registered tools ... the "D"-shaped air intake grill; the array of pyramids on the handgrip; the kit box configuration; and the ...
Posted on Oct 09, 2015
Hello I have a Dewalt D55153 electric air compressor it was cold outside i tried to start it it started for a minute then quit not will not do anything I can not find reset switch?
Check your electrical supply. Try plugging something in the receptacle the compressor is plugged into. If that does not work then start going back to the electrical supply box. If its plugged into a GFI maybe the GFI needs resetting. If not then check your main box and see if you have blown a fuse or circuit breaker. Sometimes when compressors start up cold they pull a lot of hydro.
Dec 23, 2016 | Heating & Cooling
How to reset low unload sump
Low unload sump. Would love to help but don't fully understand question. Gas as in air conditioning or refrigeration compressors low pressure (HP/LP) devise can be auto reset or if manual reset, will have a lever or button to push. If it happens often, you will need a refrigeration mechanic.
With an air compressor, make sure there is correct oil and at right level. Unless a big industrial type, there should only be a pressure regulator to control compressor electric motor. Nothing to reset. Good luck
Herman
Nov 15, 2015 | Air Tools & Compressors
Oct 09, 2015 | Air Tools & Compressors
Dewalt d55153 runs continually trying to get up to pressure, but can't.
Just a guess but I think you have broken the rings inside. If you keep running it with broken rings you will trash the cylinder inside. I think you can buy a new pump for it if you are not mechanically minded.
Apr 22, 2014 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
Air compressor not unloading
Check the pressure switch. The unloader valve is actually in the pressure switch where the small air line from the tank check valve attaches to it. When the pressure switch turns the motor off it then lets the head pressure bleed off so the motor can restart the next time pressure drops in the tank. If it's not working and bleeding off the head pressure the cold start valve (the one with the pin in it) also won't open so the motor can restart and warn up properly.
Sep 09, 2012 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
Were is the reset button for the hitachi EC 12 compresor?
As you may have noticed, there is no reset button listed in the parts breakdown. If you have been experiencing unexpected shut-down when the unit is hot you probably have one of the ec12s with a thermal protector incorporated with-in the winding of the motor. To prevent shutdown do not use extension cord or power your compressor with a generator. Test your unit with an amp meter to make sure that it is working with specifications. If you have other questions please post again. Good luck
Aug 27, 2010 | Hitachi EC12 Portable Electric 2hp Air...
HITACHI AIR COMPRESSOR
what type of air compressor you have,since when you maintained it
Sep 23, 2009 | Hitachi EC12 Portable Electric 2hp Air...
When i plug in my frigidaire fac125p1a the reset button trips immediately. won't turn on.
compressor has gone to ground. In other words the reason the reset button trips is to prevent any electrical shock due to the compressor going bad. Only way to fix this is to have the compressor replaced
Jul 14, 2009 | Frigidaire FAC125P1A Window Air...
Dewalt compressor electric not starting after blowing circuit breaker
look for a reset button on the compressor sometimes but not always is red in color but could be black also
Mar 22, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
