Question about Bose Audio Players & Recorders
We had our CD player repaired six months ago by Bose and it worked on its return but now not reading discs again and skipping on some songs. All CD s used were original recordings. What can be done?
SOURCE: the record player skips
Hi There,
From your description it sounds like there is insufficient weight on the needle end of the pick up arm.
The pickup arm is very delicate in its balance at the "rear arm end" fulcrum.
This weight is adjustable to allow the needle to press on the music track to an exact pressure and it is adjustable so that this pressure does not damage the music track.
There should be a wheel type thingy at the rear end of the pickup arm.
This wheel is usually marked in Grams, and to make the needle end heavier to stop "skipping' you turn the wheel to wards the + sign.
This + sign means more weight on the needle.
There also should be a - sign, and the wheel, when turned in that direction, the weight on the needle is reduced.
You need to be aware that a needle really needs to exist in the cartridge as they can be broken off very easily and if there is no needle present there, then there is no way you will get any music from the turntable.
So check there really is a needle there...use a magnifying glass to see....
If thats OK then place the needle end of the pickup arm on to the record surface and turn the weight wheel until the needle just lifts from the record surtface.
Now that this stage has been received turn the weight wheel in the reverse direction by around 5-7 grams in the heavy + direction.
The needle should now be resting on the records surface and not lifting at all.
It should play like this,,,BUT please ensure the record player is on a perfectly flat surface the
needle wont work on any incline at all...
If you turn the amp on in the phono switch position and carefully hold the needle over the record and touch the needle with your finger you should get a scratchy sound from the speakers.....
This is a basic test to ensure the amplifier and all the wiring is in place and doing its job..
Im Sorry you had a run around from the repair company but some of them are not interested in repair work any more they just want to sell new hardware...
It pays to ask if they are Pepared to repair stuff for you , then get a commitment of a reasonable repair date and time in writing.
If this date and time is exceeded then you dont have to pay for the repairs do you??
As they have missed the service level agreement you had with them for the reapir date and time..
Hope this helps
Posted on Sep 27, 2008
  • 35 Answers
SOURCE: my cd player skips
Unplug the unit, remove the cover and clean the laser lens glass with a Q-tip. Spray a bit of window cleaner on one end of the Q-tip (over a sink), then use that end to clean the objective lens of the laser. Then dry it with the other end. Wipe Carefully!
Do not apply pressure while cleaning, wipe slowly and then reassemble the unit and test. This is a common problem on many laser-based products, dust and smog get inside the unit and cloud the lens, causing it to skip or not read at all.
Posted on Mar 02, 2009
  • 25 Answers
SOURCE: 2003 audi a6 cd player error 2
Posted on Mar 19, 2009
  • 3600 Answers
SOURCE: The cd player reads check disc.I've tried alot of
get a lens cleaner and run it threw the cd player it should repair your problem.
Posted on Jun 22, 2009
  • 5 Answers
SOURCE: Fw316C cd player will not read discs
Buy A CD Lens Cleaner and put it in to the CD Player and keep retrying until the drive plays it and then follow the instructions for the CD Lens Cleaner after its finished try playing a CD if it still wont play try another disc and if it does not play that try reset the player by unplugging it for five seconds if it still wont play the CD drive has failed in the drive and you need a new stereo. Stereos dont last forever so dont be surprised if you need to buy a new one
Posted on Jul 21, 2009
How can I get my RCA 5 disc CD changer stereo to work right?
I have an RCA 5 Disc Changer, purchased at Target. The first one had a prolific issue of skipping on discs. It would play part of song on the first disc then suddenly change to the next disc. However, it did not ALWAYS do this, just sometimes, seemingly at random. Then one day, it would suddenly work just fine on all 5 discs. Eventually it simply would not play an entire song at all, so I took it back (within the time of the warranty). They had 1 of the same left on the back shelves so was able to get that one. This one started doing the exact same thing within the month. Now, it will not READ discs. It will simply read, 'Read"..and then when it comes up showing the disc number it has all zeros. I tried skipping to the next disc and then the next, and suddenly it read. That was fine for two days, then it would not even do that. I tried using compressed air inside all of the open disc drawer, and on all the discs but to no avail. Just now I tried tilting the entire unit Back at about a 30 degree angle and while in that position hit the 'disc change' button on the remote and suddenly it read. How long will this work? Have no idea. Very irritating - and it's hard to find this kind of player anymore, apart from a Component System which is a whole new playing field. Amazingly , I had bought my first changer, a 6 CD changer, cheap one at wal mart long ago and it lasted me about 10 years and never had a problem. It was a no-name brand too, I would expect better from RCA but alas, tis not the case.
Jun 05, 2014 | RCA Audio Players & Recorders
Radio works fine. cd player wont read discs in either of four slots. Message - Disc error.
This can often be solved by opening the cover and blowing on the optical head to displace dust and any debris that is fouling between the optics and the actuator that controls the head position. It isn't fool proof but will fix perhaps 40% of units. Take a can of air duster (aerosol blower) and blow the little pick-up form the distance of about 1 inch. It will bounce around in the wind but don't blow to hard. Give it a gentle blast and then try the player. If it doesn't work then try again this time but blow harder.
Feb 27, 2012 | Bose Wave Music System CD Shelf System
Six to eight years ago I purchased this system that included a cd exchange system. The cd exchange system stopped working and I threw it away last year. Now my cd played states it can not read the disc...
The Bose Wave System was very expensive, and should be at least checked with someone that can give an honest assessment. It is possible the Laser Pickup Assembly may need a good cleaning, if it works you can enjoy more time with it. If it fails then it is a matter of choice.
Jan 07, 2011 | Bose Wave music system Multi-CD Changer...
After placing several discs in the bose wave radio
Buy a quality CD radio. Bose is not quality. It is overpriced overhyped so-so quality stuff. Repairs by Bose will cost more than a better quality replacement.
Mar 01, 2010 | Bose Wave Radio
6 disc cd changer skipping
Laser is loose or out of alignment return to factory for adjustment.RICHARDM69
Dec 14, 2008 | Pyle PLCDCHK6 6-Disc CD Changer
Bose Wave Radio skips CDs
it seems taht motor that spins the cd is going bad.
Jan 31, 2008 | Bose & Wave& Music System
Can't read the disc !!
I replayced dvd cd-rom myself it's very simple repair and it cost me $20.00 for new dvd rom. Don't buy CD-RW but just simple black dvd-rom.
I hope this will get you going again.
Jan 28, 2008 | Bose (321GS) System
Songs and radio skips like a scratched cd
Your mp3 player works like a hard disk, make sure that it was not moving when you are listening to your music. If the problem is the same try to use a new headset/earphone on it. Loose connections on your headset/earphone makes you think that your mp3 player skips.
A Simple Thank you is Good enough
Jan 16, 2008 | SanDisk Sansa e200 MP3 Player
RS2635 5 disk changer skipping
your cdplayer is probably at intro
Aug 05, 2007 | RCA RS2635 CD Shelf System
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
