Question about Arctic Pool & Spa
Arctic spa gecko mclass starts to heat no flow error then key pad locks and shows 16 degrees
    Top Expert:
  • Arctic Master
  • 6,498 Answers
Bad recirculation pump
Posted on Sep 22, 2017
PartsCenter
  • 125 Answers
SOURCE: Arctic Spa refill and a heater alarm ''HL''
HL is an error code. You will want to check out the link below to the mfg wesite. Balboa Water Group
Posted on Feb 26, 2009
  • 58 Answers
SOURCE: lock icon shows in the key pad window. key pad
Here is the manual... Maybe it can help. :)
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8184950.pdf
Posted on Aug 06, 2009
  • 2976 Answers
SOURCE: Spa / hot tub does not heat
Your temperature control is way out of calibration or, it's wired wrong. Remove it and check it in a glass of water. Use an ohm meter across the heater wires. As you add hot wwater, the heater contacts should open.
Posted on Aug 11, 2009
rsmith972278
  • 160 Answers
SOURCE: my spa heater is saying the spa is 126 degrees so
Use a thermometer to check the actual temp of the water to see if the units temp probe is accurate. Also what is the max temp allowed by the spas safety program...owners manual.
Thanks,
RSMITH972278
Posted on Oct 12, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: Calcium build up in my Arctic Spa Hot Tub
The worst calcium build-up I have seen on an Acrylic shell was actually caused by incorrect use of chemicals by the owner. The owner was dosing in very large quantities which was the cause of their issues. Little and often is the best way to go when adding any chemicals to a hot tub.
I don't rate Aqua Finesse at all. I have seen cirulation lines partially blocked due to similar products, I wont recommend it to any of my customers or use it myself.
If you were my customer, I'd be running through your chemical routine and the quantities that you add at any one time. It's possible that you are over-dosing and causing the problem to get worse.
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Posted on May 15, 2010
I have a new spa and he says an error E98 by other models it means water to hot but my water is just 13 degrees Celsius how can i fix it ?
that often happens when there is a reduced flow of water. it heats up too fast and cannot circulate to the spa causing it to overheat when the spa is in reality not hot
Apr 26, 2015 | Pool & Spa
Can't get Klondikier Arctic spa to heat higher than 80 degrees?
ck the filters , not enough flow across heaters will not allow enough heat to be added to spa
also this spa has dual heater elements I do believe one may have gone bad leaving only one to do the job
Dec 27, 2014 | Pool & Spa
Hs error code what does it mean?
Water Temperature Sensing Error
A) Inlet water temperature sensor is reporting a temperature in excess of 104 degrees. Normal operation resumes 2 minutes after inlet water temperature sensor reports temperatures of 104 degrees or less. This error functions in both normal and remote thermostat modes.
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow condition. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
Jun 19, 2014 | Hayward H400FDN Low NOx Natural Gas Pool...
Leisure Bay spa will not heat past 86 degrees. Element and sensors are new. Spa has excellent flow and correct voltage at terminals.
if the spa does not heat up to 104 degrees then the temp sensor is what you are going to need.
Are there error codes showing on the screen of the topside?
You will need to know the model number of the control box or the model number of the heater tube in order to get the proper sensor.
Rod
US Parts Center
888-521-6183
Feb 09, 2013 | Pool & Spa
Savannah Spa Sunset Dlx control pad doesn't respond
What does it mean when the word SPA comes up on the control pad window and locking up the control pad.
May 23, 2010 | Aqua Pool & Spa
Aug 11, 2009 | Jacuzzi Home
Pool & Spa Logo
299 people viewed this question
Top Arctic Pool & Spa Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
Bill Jordan
Are you an Arctic Pool and Spa Expert? Answer questions, earn points and help others
