Question about Exercise & Fitness
How do I stop the squeaking noise when pedaling the bike or using the elliptical option? I've tried lubrication. Only getting worse.
    Welcome Back:
    Visited the website for 2 consecutive days.
With regard to the clunking/squeaking in our NordicTrack E7sv it turned out to be the left side wheel to crankshaft connection. It had come loose. I removed the left side foot rods and wheel cover plate for access. I re-seated the wheel on the shaft and tightened the hardware. Noise gone. So is all the squeaking associated with it loosening.
Posted on Feb 26, 2018
  • 2,290 Answers
Have you lubricated all moving parts. Wheel bearings Chain and sprockets? Are there fenders if so are they a little loose?. Anything that is loose will vibrate and make a noise. Even dry pedals will make a noise. Crank also.Just a thought.
Posted on Dec 23, 2016
How to lubricate an Edge 385 d/a magnetic bike
Locate what part is making the noise and spray it with a light lubricant like WD40
Sep 07, 2016 | Exercise & Fitness
Lifefitness elliptical. How do I fix a squeaky pedal?
There are several areas that could create squeaking in an elliptical,
  • Check the floor where your elliptical sits to verify the floor is level. An uneven floor could create strain on moving parts which would create squeaking
  • Spray an aerosol multipurpose lubricant onto any moving joints, especially metal on metal high friction areas like bolts and washers.
  • Apply grease around the rollers on the roller arms beneath the pedals. Operate your machine to spread the grease onto the roller ramps. Wipe away any excess grease.
Synthetic grease works best and will last you longer also.
I will be attaching a link to the grease we recommend, if any other questions come up please do not hesitate to call on our Tech Support Team at 888-713-2280 or visit us online at
May 28, 2015 | Exercise & Fitness
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
May 29, 2014 | Exercise & Fitness
Schwinn 220 recumbent bike alternates between pedeling fine to barely being barely able to move every 20-30 seconds no matter what setting. There is also a squeak/noise while the unit is plugged in,
make this steps and fix it. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
    • 2
Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
    • 3
Do not be concerned if you see small particles left on the guide rails. Over time, the roller wheels gradually wear down. When this occurs, they leave residue on the rails. Because this is considered to be normal wear, all you need to do to fix the problem is wipe the rails off with a damp cloth.
    • 4
Minimize the risk of receiving erratic readouts on the monitors by avoiding outside interference. For example, gripping the heart rate handlebars too tightly can affect the monitor. Similarly, the heart rate grips can be rendered less effective when there is too much vibration. Consider not holding these monitors throughout the workout to minimize vibration. The readouts also can be affected by jewelry. To minimize errors, take off rings and other jewelry before working out on an elliptical machine.
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Dec 05, 2013 | Schwinn 220 Recumbent Bike
My Nordictrack E9.0 Elliptical machine has a loud squeek
I have found a possible source for your squeak. I have the same elliptical and had an annoying squeak in the front end of the machine. The squeak could be coming from the roller arm flex bracket and/or the pedal arm flex bracket. These brackets are secured to the front of the roller arms and the pedal arms with a single bolt. Tightening these bolts may help get rid of the squeak. If you don't have your manual, you can download the manual at the nordictrack website. The manual will have an exploded drawing of the elliptical. The roller arm bracket and the pedal arm bracket are numbered 135 and 136 and you will see which bolt I am talking about. I have had numerous issues with my elliptical but after changing some parts under warranty, it is working like new. Good luck.
Mar 19, 2013 | Exercise & Fitness
Where and how often do I lubricate Spirit XE295 Elliptical
The manual for this Elliptical doesn't show any lubrication needed.
Is the unit starting to make abnormal noises like squeaks, thumps, or extra/less resistance?
This is from the owners manual for the Spirit XE295.
1. Wipe down all areas in the sweat path with a damp cloth after each workout.
2. If a squeak, thump, clicking or rough feeling develops the main cause is most likely one of two
i. The hardware was not sufficiently tightened during assembly. All bolts that were
installed during assembly need to be tightened as much as possible. It may be
necessary to use a larger wrench than the one provided if you cannot tighten the
bolts sufficiently. I cannot stress this point enough; 90% of calls to the service
department for noise issues can be traced to loose hardware or the rear rails being
ii. Dirt build-up on the rear rails and polyurethane wheels are also a source of noise.
Noise from build-up on the rails can cause a thumping sound that you would swear
is coming from inside the main body of the machine because noise travels, and is
amplified, in the tubing of the frame. Clean the rails and wheels with a lint free cloth
and rubbing alcohol. Stubborn build-up can be removed with your thumbnail or a
non-metallic scraper, like the back edge of a plastic knife. After cleaning, apply a
small amount of lubricant on the rails with your fingers or a lint free cloth. You only
need a thin coat of lubrication, wipe off any excess.
3. If squeaks or other noises persist, check that the unit is properly leveled. There are 4 leveling
pads on the bottom of the rear rails, use a 14mm wrench (or adjustable wrench) to adjust the
Jan 18, 2013 | Spirit XE295 Elliptical
Life Fitness 9100 Elliptical Squeaks
You can use the link below to purchase a suggested form of lubrication. You may end up needing to replace a bearing or bushing.
Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
Nov 24, 2012 | Life Fitness 9100 Elliptical Cross Trainer
Left side its sqeak when i peddle
My Precor EFX 546 elliptical trainer began squeaking when my weight was on the pedals. I thoroughly cleaned the track and wheels with Windex and then used my finger to apply a thin coat of teflon based lubricant (Tri-Flow brand) to the outer surface of the wheels. After 2 applications of lubricant, the squeaking has been eliminated completely. Hope this helps!
Sep 24, 2012 | Exercise & Fitness
Scraping/Squeaking noise on recumbent stationary bicycle
There are most likely some sort of bearings inside the wheel hub that are causing this.
Jan 13, 2010 | Cycling
Proform XP110 R recumbent bike makes clanking noise.
I have the same problem with my XP 110. After taking the ENTIRE thing apart and independently testing every single moving mechanism, I found out that it wasn't the motor, pedals, armbars, or any internal mechanism. Instead, it was the front stabilizer foot that made the annoying noise. There is a plastic mechanism around the front stabilizer legs that holds the front wheels in place (for moving the elliptical). Whenever a rotation forward occurs, the plastic squeaks and the noise resonates to make it sound like the pedals or motor is squeaking. I am still trying to find a solution to fixing the feet, but may end up ordering a new set from the manufacturer. Good luck with your elliptical!
Mar 22, 2009 | Exercise & Fitness
Exercise & Fitness Logo
1,266 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
