SC261FS Conn. Ant only, Scan finds 30 chan. Problem:when moving through chan. Displays a "Select Language" screen. Must navigate number of scns & scan chan. before I can get out of setup.
SOURCE: Locked into progressive scan AND Setup is Unavailable
The key is to make sure you REMOVE all DVDs and VCRs from the player, then hold the stop button on the unit down for 5 seconds.
Posted on Dec 27, 2006
  • 5 Answers
SOURCE: i can't scan
hope this will help u about CANON MX310
http://canoncanada.custhelp.com/cgi-bin/canoncanada.cfg/php/enduser/std_alp.php?p_sid=Gk-ofu2j&p_accessibility=0&p_lva=&p_sp=&p_li=
Posted on Apr 29, 2008
SOURCE: Can't Scan with MX310 hooked up to Time Capsule
guest is totally 100% correct. you cant scan wirelessly, cause it wont know where to send your copies to. you have to HARDWIRE to scan.
Posted on Aug 01, 2008
Fixe_You
  • 1800 Answers
SOURCE: I CAN'T SCAN ANY DOCUMENTS WITH MY HP J6480
hi
try this official link i think that will really help u out
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00710491&lc=en&cc=es&dlc=es&product=421990&rule=39296
plz do rate this post
Posted on Dec 12, 2008
ziraffa
  • 827 Answers
SOURCE: Hp 1410v won't scan
The all in one solution software you used in XP doen't work with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP 1410v) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Posted on Jan 05, 2009
Nokia 302 change language
Find "Device language"
  • Press the Navigation key.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Device and press the Navigation key.
  • Scroll to Language settings and press the Navigation key.
  • Scroll to Device language and press the Navigation key.
2. Select language
  • Highlight the required language and press the Navigation key.
3. Exit
  • Press Disconnect to return to standby mode
Jul 06, 2014 | Nokia 6220 classic Smartphone
Change phone language to english
Look it up on the Mfg. website. They usually have manuals posted.
May 28, 2014 | Vtech Cordless 6041 Phone
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
I am trying to set my Sanyo picture right side up. what setting do I go to?
Check Ceiling feature.
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT button(s) to move a red-frame pointer to
SETTING icon.
Language used in ON-SCREEN MENU is selectable from among
English, German, French, Italian, Spanish, Portuguese, Dutch,
Swedish, Russian, Chinese, Korean and Japanese.
Display
This function decides whether to display On-Screen Displays.
On ··· shows all On-Screen Displays.
Off ···· sets On-Screen Displays disappeared except;
? ON-SCREEN MENU
? "Power off?" message
? "No signal" message
? "Please wait...."
? P-Timer counter
Set a red frame pointer to item and press SELECT button.
Press POINT DOWN button to move a red-frame pointer to item
that you want to set and then press SELECT button. Se ting
dialog box appears.
Dec 11, 2010 | Sanyo PLC-XF46N LCD Projector
I have a uniden GMR1448 Two-Way Radio. Both handsets work but they cannot talk to one another. They used to work fine. They are tuned to the right channel and I did everything that I find obvious, like sub...
Check whether the channel and the sub code are same?If this is not same it will not work.
Put the sub code to off.Follow the below steps
1.Press chan tone/scan in channel select mode.The subcode indicator will flash. 2. Press the UP arrow  or DOWN arrow key to increase or decrease the code number displayed.You can also select oF (OFF) at this stage. 3. Press chan tone/scan to exit the Menu.
Thank You
Nov 16, 2010 | Uniden GMR1448-2CK Two Way Radio
After the re-tune session today there is no Chan
Look at the bottom of the channel list 800 onwards and you may find it there. I have not found a way of moving them to the correct channel numbers yet still trying.
Sep 30, 2009 | Televison & Video
Language change
You can change the language that displays in the screens and menus of your device. To change the display language, perform the following steps: 1. Press the Left Softkey to select Start. 2. Select Settings and then Regional Settings. 3. In the Language field, use the Navigation key to select your language. 4. To save the setting, press the Left Softkey to select Done. You must turn your device off and on again for the change to take effect.
Sep 02, 2009 | Motorola Mobility Moto Q
Scan troubleshoot
Hello Kamaleddin_e , this no scan option issue occurs when you try to scan from the printer. It usually means , you need to set the destination file type, which is currently not populated (destination file type is the file type to which you want to save the file which you are scanning. If the device finds the list is empty (list of associated file types) , then it displays the "No scan options" error on the printer.
You can populate the destination list by following these steps.
1. Open the HP Solution Center
2. Navigate to Scan Picture Settings (or Scan Settings)
3. Select "Scan to Button" tab
4. Select destination list tab. (Note: If the appropriate programs are already listed as scan destinations, discontinue this procedure. The software must be reinstalled.)
5. There will be 2 colums visible, the left column is the scan destination list on the computer and the right one is for the scan destination list on the printer.
Click each program to include on the Scan To list. Click the Add arrow. The program listing moves from the left side of the screen to the right. Click OK.
6. Now try scanning again from the front panel.
(Note: Please make sure that the HP Digital Imaging Monitor is also running as it is required for the HP software to function properly. You can find it as an icon in the system tray. If there is no icon, then you can run the application by navigating to C:\Program Files\HP\Digital Imaging\Bin\HPQTRA08.exe (Assuming C: as your system drive)
Mostly, the issue will be resolved at this stage or else you need to uninstall the software and reinstall it again.
all the best.
thx
Sep 30, 2008 | HP Photosmart 3310 Printer
Change LCD screen back to English
Issue: How do I change the language setting of the LCD?
Solution: Change the display language settings (MP170)
LCD Appears in Japanese (or other foreign language) Upon powering on the machine for the first time, the LCD will prompt to select a display language. If a language other than English is selected, the setting can be changed by following these steps.
  1. Ensure the machine is powered on.
  2. Press the <Menu> button as many times as necessary to display [SYSTEM SETTINGS].
    1. From the Copy mode standby screen, press <Menu> 7 times.
    2. From the Scan mode standby screen, press <Menu> 1 time.
    3. From the Memory card mode standby screen, press <Menu> 6 - 12 times.
  3. Use the right arrow twice to select [OTHERS] and then press the <OK> button.
  4. Use the right arrow three times to select [LANGUAGE SETTING] and then press the <OK> button.
  5. Use the right or left arrow to select the appropriate language and then press <OK>. Choose from the following language settings.
    1. JAPANESE
    2. ENGLISH
    3. GERMAN
    4. FRENCH
    5. ITALIAN
    6. SPANISH
Sep 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
