Question about Furuno GPS
I have a furuno fcv582l the alarms comes on continuously how do i stop that
Antenna GPS Tram 1655 is compatible with GPS FURUNO?
If the Furuno unit you're referring to uses a GPS antenna with a coax (i.e. GP31/32) then the Tram antenna will work but the connector is wrong. The Tram antennas usually come with BNC connector and Furuno uses a TNC. Will need an adapter.
Oct 14, 2013 | Furuno GPA019S GPSDGPS HField Antenna...
LOOKING FOR OPERATORS MANUAL FOR FURUNO GPS NAVIGATOR GP-70 MARK 2
You'll find one on the Furuno site - follow the link
http://www.furunousa.com/products/productdetail.aspx?product=GP70MK2&category=Products+%3a+Previous+Products+%3a+GPS+%26+Chart+Plotters+%3a+GPS+Receivers
It's an ominous date to be looking for a manual! Has it stopped working or is it just the date that's wrong?
12 Dec 2010 is 'GPS week number rollover' for the GP-70 Mark 2. See www.furuno.co.jp/en/pdf/080531_notice_en.pdf for details.
I
Dec 12, 2010 | GPS
I want to do a master re-set on a Furuno Navnet 2 , 1944 radar/plotter. Do you know the sequence of keys? Andy
Press and hold the alarm key whilst powering up. Also try it with the clear key while powering up again.
Sep 05, 2010 | Furuno NavNet vx2 1944C/NT GPS Receiver
My 1734c will not boot past the black disclaimer
You will have to get a software update and have someone reflash the unit or perform factory reset by holding down the alarm button when pressing the power button.
May 15, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
A furuno 1715 lcd radar was wired to battery backwords
internal damage to the display, fixable by Furuno, and probably economically feasible (guess $250 with round trip to Furuno)
Nov 17, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Furuno 1715 Radar - 'NO HEADING PULSE'
More than likely the belt has come off again. This is a common problem with this radar. You'll need a small allen wrench to tighten it up again.
Jul 02, 2009 | Furuno 1715 LCD Radar System GPS Receiver
I have a Furuno 1715 and the array slows and stops frequently.
If you call 410-228-7335 and ask for the service dept, they can call Furuno and obtain the motor for you.
Jun 28, 2009 | Furuno 1715 LCD Radar System GPS Receiver
How do you activate the fishfinder for the furuno 1650 WF
pressing the "SNDR" button activates the sounder press"ALARM" tyo acces alarm menu, turn them on or off there, look "NEXT PAGE" for alarm 2 847-746-0100
Apr 16, 2009 | Furuno 1850WF Gps Fish Finder Combo...
Furuno 1833C/Dgps37 Plotter creeps
Try adjusting the GPS position offset in the GPS Sensor Settings Menu.
Jan 11, 2009 | Furuno 1833C/NT GPS Receiver
Furuno 1622 doesn't work, water coming out cable at screen!
yes the cable should be replaced if you are lucky, the unit is still OK (display) Try the new cable, draped across the boat before rigging. If fault exists with new cable, replace system, or find a new display on ebay
Nov 17, 2008 | Furuno 1715 LCD Radar System GPS Receiver
GPS Logo
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
