Question about Stryker Stretcher, Gurney, Patient Transport Bed In Excellent Condition
We have a striker 1005 stretcher it has lost hyd fluid over time and cannot be raised to full height how could I fill it for use until new parts come in
  • 2,783 Answers
SADLY Stryker seems to use their service and "manuals "
sections to FURTHER ADVERTISE their EQUIPMENT...
I was hoping to find, 10W oil, dextron... etc...
(but alas.. I found NOTHING (sorry)).
Contact them directly at
Phone:
800-STRYKER (787-9537)
Option 1 for Field Service
Option 2 for Tech Support Fax:
866-787-9095
Email:
medservicedesk@stryker.com
Posted on Dec 23, 2016
  • deton8 von Splosion Dec 23, 2016
    If it is **truly** an EMERGENCY any OIL...
    WOULD WORK FINE...
    auto transmission would be your best grab... but don't run past engine oil...
    They will all give lift...!!!
Hello, i have a New Holland t1520 and can not raise the mower deck for the life of me, fluids are good. Any help would be fantastic. Thankyou
guessing the deck is hyd lift system on it? does it sound like the pump is loading up? if not check the linkage from the handel to the valve body, there is most of the time a cotter pin the goes from the control rod to the valve body.
Apr 04, 2017 | Garden
1952 Fordson major diesel hyd fluid gets into front tranny
Sounds as if the input shaft seal for the hydraulic pump that is driven off the transmission is bad and allowing the fluid to enter the transmission housing. When the fluid gets too full it aerates and causes the "root beer float" fluid.
Mar 05, 2015 | Cars & Trucks
Tilt leaking down
low fluid in unit and air in the system raise all the way up put safety lever down remove fill plug and top unit off replace fill plug then cycle up and down 3 complete cycles raise back up check fill level again you may hear air leak out when removing fill plug if low fill again repeat this cycle until unit stays full this should fix the problem if not the pressure relief valve is faulty if there is no external leaks
Apr 19, 2014 | Seloc Mercury Outboard Engine Repair...
My 2 stage floor jack raises to load point, butbut no further -- at this point you cannot pump the handle
raise the head all the way up remove plug and fill with hyd fluid replace plug and try to jack it should go all the way up...i had same problem..
Feb 27, 2012 | Cars & Trucks
Have hyd.clutch need to drain and replace fluid?
If you have steel lines, you should replace the fluid since it can absorb water over time and rust the lines from the inside, causing a leak. If there is a bleeder for the clutch, the easiest way to change the fluid is with a vacuum pump (mighty mite) connected to the bleeder. Ensure the resivoir stays full and use the vacuum pump on the open bleeder until you see the new fluid coming through then close the bleeder. If there is no bleeder you'll need a helper. Have someone hold the clutch lever down while you loosen the fitting that attaches the line to the slave cylinder and allow the fluid to escape. tighten the fitting and then let the lever back up and squeeze down again repeat the loosening and squeezing peocedure until you see the fresh fluid emerging. (Same procedure as bleeding the brakes except you use the fitting instead of a bleeder screw).
Jun 29, 2011 | 1994 Suzuki VS 1400 Intruder
How to repair a power steering pump hyundai coupe 1996
SIPHON OUT POWER STEERING FLUID.USING A HAND PUMP SIPHON TYPE YOU BUY AT ANY AUTO PARTS STORES.PLACE DRAIN PAN UNDER CAR NEAR POWER STEERING PUMP CATCH FLUID WHEN YOU REMOVE POWER STEERING LINES AT THE PUMP.REMOVE DRIVE BELT.THEN REMOVE POWER STEERING PUMP.YOU NEED TO TAKE OLD PUMP WITH YOU.TAKE NEW PUMP AND OLD PUMP TO MACHINE SHOP THEY WILL REMOVE POWER STEERING PUMP PULLEY FROM THE OLD PUMP TRANSFER PULLEY TO THE NEW POWER STEERING PUMP YOU NEED TO BUY NEW POWER.STEERING HOSES O RINGS TO GO ON NEW POWER STEERING PUMP.HOSES THE OLD ORINGS WILL LEAK. THEN TAKE NEW POWER STEERING PUMP ON INSTALL IN VECHICLE THEN BLEED POWER STEERING SYSTEM.FILL POWER STEERING PUMP UP NEW FLUID.WAIT FEW MINUTES.WHEN LEVEL DROP ADD MORE FLUID UNTIL YOU GET TO FULL COLD MARK.START ENGINE 15 SECONDS SHUT OFF CHECK FOR LEAKS. NOW CHECK POWER STEERING AGAIN ADD TO FULL COLD MARK.NOW RAISE FRONT WHEELS OFF GROUND.START ENGINES TURN STEERING LEFT TO RIGHT WITH OUT STOPPING IT DO SEVERAL TIMES THEN CHECK FLUID.ADD TO THE COLD MARK DONT OVER FILL.IF FLUID LOOKS TAN HAS AIR BUBBLES IN SYSTEM WAIT A WHILE UNTIL FLUID SETTLE CHECK FLUID LEVEL.DONT DRIVE VECHICLE UNTIL STEERING FEELS NORMAL.AND IF YOU HEAR NOISES.LOCATE PROBLEM FIX BEFORE DRIVING VECHICLE.
Jan 24, 2011 | Hyundai Genesis Coupe Cars & Trucks
WeMy power steering fluid was leaking I tool it to the shop they told me It was the pump so I brought a new pump and got It put in and now I still cant turn my steering wheel
HEY DO THIS,YOU NEED TO BLEED SYSTEM. TO BLEED POWER STEERING SYSTEM.TO DO THIS.FILL THE POWER STEERING RESERVOIR TO COLD FULL MARK ON DIP STICK.WAIT A FEW MINITES,FLUID LEVEL DROP ADD MORE FLUID UNTIL REACH COLD MARK ON THE DIP STICK..WAIT FEW MINUTES.START ENGINE LET IT RUN FOR 2 OR 3 SECONDS.TURN OFF ENGINE CHECK POWER STEERING FLUID ADD MORE FLUID.DO THIS UNTIL FLUID LEVEL STOP DROPPING.WHEN FLUID LEVEL STOP DROPPING.SAFELY RAISE FRONT OF THE VECHICLE UNTIL FRONT WHEELS DONT TOUCH THE GROUND.START ENGINE UP.TURN THE STEERING WHEEL GENTLY FROM STOP TO STOP,CHECK THE RESERVOIR FLUID LEVEL LOOKS GOOD TURN OFF ENGINE LOWER VECHICLE .LOWER VECHICLE TO GROUND. LET VECHICLE SET FOR 2 MINUTES CHECK POWER STEERING FLUID LEVEL.IF STILL LOW ADD LITTLE MORE.TO THE COLD FULL MARK ON DIP STICK. DONT OVER FILL BECAUSE FLUID LEVEL RISES WHEN IT GET HOT.WHEN DONE IF STEERING WHEEL STILL FEEL HARD TO TURN YOU SEE AIR BUBBLES IN FLUID THATS WHEN FLUID HAS A TAN LOOKING COLOR WAIT 5 MINUTES AND.REPEAT THE BLEEDING PROCESS. DONT DRIVE OR OPERATE VECHICLE ON HIGHWAY UNTIL POWER STEERING HAS NORMAL OPERATION.
Sep 26, 2010 | 1999 Oldsmobile Alero
Ford TRactor 1710 hydraulic problem
raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
Nov 16, 2009 | Plumbing
Check automatic transmission fluid 2001 pontiac sunfire
You need to raise the vehicle and start it. Remove the plug near where the passenger side driveshaft comes out. The head of the plug is 7/16. Trans fluid will stream out of the hole when the engine is running when the transmission is full, If fluid doesn't run out, fill the trans until fluid runs out. The fill cap is red and it is on top under and around the air cleaner box. If you need more help let me know.
May 26, 2009 | 2001 Pontiac Sunfire
Stryker Stretcher, Gurney, Patient Transport Bed In Excellent Condition Logo
1,394 people viewed this question
Top Stryker Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Stryker Science and Laboratory Expert? Answer questions, earn points and help others
