Question about Kitchen Ranges
4 out of 6 gas knobs do not initiate a spark - Kitchen Ranges
  • Patrick Keates
    Patrick Keates Dec 23, 2016
    this question relates to a smug 6 burner hob.. Turning and depressing the other two gives a spark at all 6 burners
  • deton8 von Splosion Dec 23, 2016
    Hello Patrick Keates,
    I am supposing "smug" & "hob" actually means something where you are... (not here).
    This is actually a USA fixya site... You will have to make a sincere attempt to identify what we are referring to... (make, model... range/cook-top).
    The FREE advice gets no MORE EXPENSIVE if you want to give us a meaningful question...
    I'm just saying... Try it...
    it's still FREE.
2 Suggested Answers
SOURCE: Almost brand new gas range with electric ignition. One burner doesn't light no clicking when knob is turned however, if a different knob is turned, burner in question sparks. If two knobs are turned s
It'll be a switch problem on the valve in question.
Posted on Feb 09, 2015
Is there a trick to starting the Pyrox 400? Turned the fan on and press on low then repeatedly press the ignition pilot light, start to smell of gas after a minute. Won't start Help please
Is the ignition sparking? When you press and hold down the buttons, the ignition should be sparking at the centre electrode. At the same time when you hold the buttons down, the gas valve is manually held open to release the gas. The spark is then supposed to ignite the gas. Hold the knobs down for about 3 to 5 seconds after ignition and the gas valve will stay on. If it lights but the flame wont stay on, it could be anything from a partially blocked aeration port to a worn knob. When you push down on the knob, it is supposed to press down on an electromagnetic lock which keeps the gas valve open when the flame is burning. When the knob or shaft isn't pushing down enough, it doesn't keep the gas valve locked and the flame will go out as soon as you let the knob go.
Apr 19, 2015 | Heating & Cooling
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
When I go to start my grill, I turn on the gas and then the knob on the right side to spark the gas for the fire. When I turn the knob it does not spark the gas. Hoe do I troubleshoot what is wrong....
It sounds like you have a rotary piezo igniter, which means you get one click, or spark, per rotation. If there is no click when you turn the knob, or the knob spins freely when you turn it, it has probably broken. If you pull the knob of, there should be two screws behind the knob that holds the igniter to the front panel. Hopefully you can remove the screws and reach behind the panel to remove the igniter. If this wont work, you have to remove the front panel. If the igniter is not broken, then check the wires and electrode for shorts.
Jul 03, 2011 | Ducane 1005A (LP) Grill
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Igniter
Does the knob control both the gas and spark, try turning on the knob only, if it starts to spark right away then it is possible that the switch is bad. because most of these units are designed where you turn on the gas then push in and hold the knob to ignite then release and spark should stop.
Dec 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
