Question about Comfort Zone Heating & Cooling
How do i check the bulbs to see which one or ones are out i have comfort zone cv 1500 p i have it tore down and tring to find out which bulb out to replace
SOURCE: settings on my CZ 1500
To switch between C and F, hold DOWN and ENTER for three seconds.
( I sell these. )
Posted on Apr 26, 2009
  • 83 Answers
SOURCE: Need to replace instrument cluster/AC bulbs
Hello, You can obtain a 2004 Ram Factory Service Manual with all of that information available from The reason why it may be so important is because right before the removal instructions the service manual has diagnostic instructions to try. There are numerous pages on removing the instrument cluster, and cluster bezel.
(1) Disconnect and isolate the battery negative
cable. (For Airbag)
(2) Remove the cluster bezel from the instrument
panel. (Refer to 23 - BODY/INSTRUMENT PANEL/
(3) Remove the four screws that secure the instrument
cluster to the instrument panel structural support
(Fig. 5).
(4) Pull the instrument cluster rearward far
enough to access and disconnect the instrument
panel wire harness connectors for the cluster from
the connector receptacles on the back of the cluster
(5) Remove the instrument cluster from the instrument
Posted on Oct 02, 2009
SOURCE: 2004 CTS Cadillac front passenger turn signal bulb is out.
Actually no you don't. Crank your steering wheel all the way to the right so yo have the maxumum clearance for your hands and arms in the front of the wheel well. Remove the plastic clips that hold the wheel well splash guard and pull it back enough to allow access to the interior of your bumper.
Replace bulbs as needed.
Yes, a jack is nice and makes it a touch easier to access, but I did this in an AutoZone parking lot during a cross country road trip.
5 mins tops to complete.
Posted on Mar 14, 2010
  • 2777 Answers
SOURCE: I have an AO5 error
This indicates a power fault inside the actual heater. Have you tried unplugging the heater, letting it sit for a good 2 minutes, and replugging it back in? If the problem persists you will unfortunately need a repair. Please let me know if you need more information on this. You can also contact comfort zone, the manufacturer, located in Canada, at 780-420-6572.
Thanks so much for the question,
Posted on Sep 09, 2010
  • 74 Answers
SOURCE: where is headlight relay ,on
Get your hands on a scan tool and erase the codes u find.sometimes there's an interruption in the headlight circuit and a code will be set.erasing it will reset the headlights
Posted on Dec 20, 2010
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
The infrared wont turn on , no heat
Because it is an infrared... It likely uses a common heat lamp bulb. (yes just like in the restaurants where they keep your entree warm until picked up by the waitress, or the type in a chicken coop). Locate and replace the bulb.
Oct 17, 2013 | Comfort Zone Heating & Cooling
90HP Yamaha won't turn over
It sounds like you have a air line busted somewhere i had one of my outboards do that it wouldnt prime for anything so i ran everything down checked the fuel pump and cleaned that out tore apart the carbs cleaned them bought brand new fuel hose still scratching my head i took off the air lines for the carbs and put new ones worked like a champ
Aug 22, 2012 | Boating
Comfort Zone CZ 1500 A04 CONTINUES TO COME ON
The AO4 is a board used by Earthwise on the Comfort Zone Heater. The reading is the board being used. If the heater just gives that reading it may need to be reset. This can be done by pressing up, down and enter at the same time. If this does not work unplug and try it again. Hope this helps
May 04, 2011 | Comfort Zone CZ1500WC Infra-Red...
My comfort zone infrared hearter has a display message of A05 and will not run, what does that mean? How can I fix it?
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Nov 16, 2010 | Comfort Zone Heating & Cooling
My comfort zone is not heating I had a infarared bulb that went out replace the bulb the heater still want come on it is hard to get techical support to tell what's wrong.
The bulbs on the older (pre-fall of 2010) Comfort zone heaters are in pairs... if one bulb of the pair is burnt out the other will not work. Also they are not easy to line up when replacing them back into the recepticle...they must line up perfectly to work.
Oct 05, 2010 | Comfort Zone NEW 09 Electric Portable...
How do you change from celcius to farieheit on comfort zone heater
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release.
- VS
Nov 28, 2009 | RTO Comfort Zone Electric Portable Space...
DLP won't turn on, whinning noise
It takes a trained eye to see failure in the bulb. I susppect the lamo is gone. You hear the color wheel spin up and the lamp tring to arc. (crackling sound)
Jun 25, 2009 | Televison & Video
Settings on my CZ 1500
( I sell these. )
Mar 11, 2009 | Comfort Zone NEW 09 Electric Portable...
Heating & Cooling Logo
29 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
