Question about Alesis M1-Active MkII Main / Stereo Speaker
Woofer not working
Dealing with a similar problem here.
the woofer just stopped working. blue light is on and the top speaker is working just fine.
Is this something I can fix or do I need to take it somewhere?
  • 744 Answers
Hi..
sounds like the voice coil could be open or damaged. the woofer can be reconed. reconing replaces all the moving parts in the speaker frame returning to new condition in most cases.
thank u
rate me
Posted on Jul 21, 2009
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
Can I replacement the woofer on a swa1501 with any woofer
Yes, with the appropriate replacement driver in size and similar specs regardless of the brand. P-audio drivers worked fine in this unit.
Apr 22, 2013 | Mackie SWA1501 Subwoofer
Does the woofer inside the srm 350 take the blue or yellow wires? I forgot.Thanks
I haven't looked inside this particular model but have worked on similar. If you trace the wires back to the PCB it should be marked LF (for the woofer) and HF (for the horn).
Sep 08, 2011 | Bob Mackie SRM350 Main / Stereo Speaker
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
The woofer on one of my speakers stopped working. The tweeter seems fine. My DMM shows that the resistance across the 2 internal leads that connect to the woofer continuously cycles from 0 through...
The voice coil is open, you can look real close at the spider wires that are soldered from the two terminals to the cone to see if they are bad, otherwise you will need new woofer, you can try getting the woofer from partsexpress.com
Feb 14, 2010 | Boston Acoustics Micro90X Speaker
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
Jan 05, 2009 | 1994 Chevrolet Suburban
JVC Sub-Woofer
Well, sort of. It's part of a typical JVC shelf system. The gray and blue are for the left woofer and the red and black are for the right woofer. It's basically just two small "woofers" in a box. So unless you have a small amplifier that has 2 subwoofer outputs with a built in crossover, they are essentially useless.
Aug 04, 2008 | Audio Players & Recorders
Alesis M1-Active MkII Main / Stereo Speaker Logo
353 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
