Question about Coffee Makers & Espresso Machines
Jura capressa S9...turns on and select product on screen and when I hold button in to go to maint. only goes to filter...no coffee ready even when I press exit
SOURCE: Rinse error
How do we take the top of the Capressa Jura E8 machine off. The machine appears to be clogged and the Capresso people think that air has gotten into the machine do to a filter that was not soaked prior to putting in. Any suggestions? Thanks Mary
Posted on Oct 07, 2008
SOURCE: jura capressa 8
After contacting Capresso Customer Service - the solution is simple. You pull out the drawer and dump the grounds. Look into the machine and you will see a plastic flap. Reach your hand in and up behind the flap and you should feel a round screen. Using a paper towel, clean off the screen. Replace everything. Works like a champ! So glad I didn't have to return our 3 day old machine!
The rep states that this is a common problem - asked him why it isn't in the manual and he had no explanation! Plus I can't believe that someone else didn't post this solution since it is soo easy!
Posted on Dec 08, 2008
SOURCE: I have a Jura-Capressa S9
I have fixed this problem..................there is a small attachment on the back (2 in fact). the inlet & out let of the boiler.
The start to leak for some silly reason. U need to replace this
Posted on Apr 30, 2009
  • 143 Answers
SOURCE: jura capressa imprezzo z5 coffee machine, did not
return to service centre this one's a *****
Posted on Sep 21, 2009
  • 60 Answers
SOURCE: Hi,
This is a really strange error, but it makes some sense if you own a S9 One Touch model. Then there`s a problem with the squeezing valve located behind the steam/cappuccino outlet. If this is an older model, then it could be a problem with the ceramic valve, but normally this makes the water flud all over the frontpanel and inside. In both cases, i would recommend to send the machine to the nearest servicecenter.
Posted on Nov 11, 2009
Filter change
this was absolutely the problem with my Jura Capressa E-8 machine. I followed instructions after changing the filter. I opened tap-machine stated that it was filling system- I closed tap when instruction. The open tap remained on because no water was filling system. I took the frother tip off and opened tap. Water filled system (container under frother). I closed tap without the frother tip. Machine Ready.... (I heated water in microwave for three minutes) I placed the frother tip in there and used a wooden skewer to ensure frother was clear of debris... Worked like a charm!
Nov 26, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
Hi, no coffee is coming out of Jura S9. The water comes out of steam exit - even in cleaning program rgds
Nov 10, 2009 | Jura Capresso Impressa S9 Coffee...
Machine says malfunction and won't froth milk
If you have a rotarywheel; Press and hold to enter the menu, turn to Maintenance, select Decalcify unit; empty tray as requested, fill up 600ml water in a container. Disolve 3 Descaling tablets in the water, and then fill it in the watertank. Press Maintenance button and you`re off.
If you don`t have a Rotary; Turn off the machine and let it cool down for a while, then push the Rinse/Maintenance button for a few seconds; then you will get the message Empty tray. Fill the solution in the watertank and press button.
It`s important that you use the right amount of water, or else the process will "never" finish.
Dec 24, 2008 | Jura Capresso Impressa S9 Coffee...
Rinse error
I'm not exactly sure what was going on as I tried again to push the rinse button possibly a little harder this time and now it is working fine.
Sep 26, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
I have a Jura-Capressa S9 that is leaking near the water intake. How do you open one of these to check it. They want $250 (flat fee) to repair it.
Apr 04, 2008 | Jura Capresso Impressa S90 Espresso...
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
