Question about Microwave Ovens
I have the sauter f9500 oven and its stuck on demo mode and on its instructions its says to click on the light button for five secs after power fail and its dosent works nothing is responding.
SOURCE: DEMO MODE
Had the same problem- we unplugged it and plugged it back in. All is well!
Posted on Jun 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Stuck in Demo mode
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If that doesn't work, check the owner's manual.
You should be able to download your Panasonic owner's manual here.
Posted on Dec 07, 2008
SOURCE: Microwave oven (nn-sd997s) stuck in
Pressing "timer/clock" button 4 times turns on and off demo mode.
Posted on May 18, 2009
  • 864 Answers
SOURCE: Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Posted on Aug 12, 2009
Testimonial: "Thanks very much, it was driving me crazy!!"
  • 41 Answers
SOURCE: microwave stuck in demo mode
press 'function' '0' '2'
Posted on Sep 14, 2009
How i release SAUTER OVEN SAI 1090 from DEMO MODE?
It does not work , please help me to have a Sauter oven Model 1090
Nov 12, 2014 | Microwave Ovens
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
Feb 03, 2012 | Panasonic Microwave Ovens
Stuck on demo mode. how do i get it back to working
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://service.us.panasonic.com/OPERMANPDF/NNC994S.PDF
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 24 of the manual for instructions on how to deactivate the DEMO MODE.
Basically, if your Panasonic microwave display shows DEMO MODE, then just press the CLOCK button on the control panel 3 times in a row.
The display should then go blank indicating that it has successfully returned to normal cooking mode and can be operated as usual.
A few models require you to push the CLOCK button 4 times to clear the DEMO mode, so try that as well if the above instructions do not work for you.
I truly hope that was helpful to you Monique.
Good luck and take care.
Joe.
Dec 04, 2011 | Panasonic NN-C994S Convection/Microwave...
Microwave stuck in demo mode
try unplugging it for 10 minutes. Otherwise, try looking at the instructions:
Sep 14, 2009 | Panasonic NN-C980 Convection/Microwave...
Stuck in demo mode after power outage - any ideas on how to get it out? model is JVM2070
Talked to GE Help Line (1-800-626-2005) and found out the magic key combination for this microwave. Plug in after being unplugged for at least 30 sec. and then press Help plus Boost at same time for 3-4 seconds (until it beeps). The microwave will now be in normal mode (I assume you do this to put it in demo mode as well).
Sep 13, 2009 | GE Profile Spacemaker Over-the-Range...
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
We had a power blackout now my panasonic genius microwave is stuck on demo mode. How do I get it off demo mode?Is it fried or fixable?
DEMO MODE ON/OFF
Demo mode is designed for retail store display. In this mode, the oven can be demonstrated with no power in the oven.
On the "Timer/Clock: button:
4 taps ON The oven is in Demo mode.
4 more taps OFF The oven is not in Demo mode.
Mar 07, 2009 | Microwave Ovens
DEMO MODE
how do i change the bulb inside the microwave ge xl 1800
Feb 13, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Microwave DEMO MODE
I just bought a condo with a GE Spacemaker Mod# JVM1860SD
that was stuck in demo mode. (This mod# has been replaced by the JVM1870*** series)
I called GE twice in two days, and finally got someone who had the solution (and it worked):
  1. Unplug the unit for at least 30 seconds
  2. Plug the unit back in DO NOT SET THE CLOCK
  3. While the unit is still "booting up" and the display screen is lit with gibberish, HOLD THE POWER LEVEL AND THE ZERO BUTTON for at least 5 seconds.
  4. After 5 seconds, the screen will display "demo mode off"
It messed me up at first because the power level and zero pads don't beep when the unit is booting up... but it worked.
- Again, this is for the GE Spacemaker 1860-1870 series models only - The women who gave me instructions said she had different demo mode unlock methods for the 1400, 3670, 2070 etc... so call GE if you have a different model.
P.S. my model looks like this - the keypad setup is key http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=JVM1870SK&SITEID=GEA
Mar 01, 2007 | GE Advantium SCA2000B Microwave Oven
Microwave Ovens Logo
112 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
