Question about Cell Phones
Juke 2000 error code po41 - Cell Phones
Nsm jukebox error codes
error 6 =cd player fault if you have the service programming it lists all error codes and what they are and there is several tests to do to try and repair or check if you dont have it email me
Mar 21, 2014 | Audio Players & Recorders
Service engine soon light code po41
you missed a digit.
P041x? what is x/?
P0 codes are federal codes.
scan the PCM. and get all DTCs stored.
then post them all.
or read the FSM
the SUZ FSM covers all that.
or read alldata.com
when you get errors, that means the mech, will do tests based on that error, guessing will be $$$$$$$$
Feb 24, 2014 | 2003 Suzuki XL-7
Engine code po41
P0xxx
your code is too short. did you get this at autozoned?
my guess, is P0401, EGR failure.
the #1 all time , common failure.
P0 means USA standard power train codes,
My jukebox is showing error PO41
if its nsm error =wrong price setting
Jan 01, 2014 | Audio Players & Recorders
Hi there my juke is coming up with e7 when i put the my foot down on the pedal can anyone help with this thank you
The model number of your Juki would help. In the mean time google the phrase
Juke (model number) error codes
Oct 27, 2013 | Sewing Machines
Code 41 for a 1999 chrysler sebring jx convertable 6 cyl 2.5
No vehicle after 1995 has a code like that
PO40 & PO41
Google OBD2 Codes P0 40
Mar 03, 2013 | 1999 Chrysler Sebring
Nsm wizard old fashion juke box error 94
hi, try factory settings it may clear it, the code is==p140-h1-h then press c to clear display, good luck. john
Jan 05, 2012 | Audio Players & Recorders
I have a Performer Wall 2000 CD juke box - Error 61
I have no idea! But you could try google to see if there are any fixes
Mar 04, 2018 | Samsung SCH-U470 Juke Cellular Phone
Code p041 diagnostic
Cam Sensor Signal problem.
CAM SENSOR is located in the distributor. It is also called a HALL EFFECT SENSOR.
Once you replace the cam sensor you MUST clear (erase) the code from the computer.
Aug 26, 2010 | 1993 Cadillac Seville
Samsung juke on verizon I don't the lock code on my phone
there are only certain lock codes to try as default codes with almost all verizon phones its the last four digits of the phone number programmed to the phone also if that doesnt work try 0000, 1111,1234, 4321, and 9999 if none of those work then you will have to take the phone to a retail location and let them hook it to a flashing station and push the software back into the phone to correct the issue its free takes five mins and its a common error my suggestion once you get it fixed if you change your code formt he default always keep a text message locked to the phone with the code or a dummy contact with it in it so you can look it up if you need to
May 28, 2010 | Samsung SCH-U470 Juke Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
