Hello I have a Dewalt D55153 electric air compressor it was cold outside i tried to start it it started for a minute then quit not will not do anything I can not find reset switch?
  • Richard
    Richard Dec 23, 2016
    Power is good to compressor need to find Reset on Compressor?
  • Richard
  • 2,321 Answers
Check your electrical supply. Try plugging something in the receptacle the compressor is plugged into. If that does not work then start going back to the electrical supply box. If its plugged into a GFI maybe the GFI needs resetting. If not then check your main box and see if you have blown a fuse or circuit breaker. Sometimes when compressors start up cold they pull a lot of hydro.
Posted on Dec 23, 2016
My dewalt d55153 starts runs then trips breaker can anyone point me in the right direction. Brushes. Windings?
if there is sever arcing at the brushes, it could be the armature , armature bearings or the windings
tripping a breaker is either overload ( short) or insulation failure causing an imbalance in the breaker causing it to trip
take the machine in for a proper inspection and diagnosis
Dec 29, 2016 | Dewalt Air Tools & Compressors
Dewalt d55153 air compressor. Why won't it turn on?
DEWALT Service and Support ' Manuals and FAQs
www.dewalt.com/parts-and-service.aspx
DeWaltDownload instruction manuals for your registered tools ... the "D"-shaped air intake grill; the array of pyramids on the handgrip; the kit box configuration; and the ...
Oct 09, 2015 | Air Tools & Compressors
Do I need a new control panel if my compressor kicks off every 2 to 3 minutes?
check the outside unit is clear and has lots of air flow, try cleaning the outside with a garden hose, most likely the compressor is cutting out because it is getting too hot.
Jul 19, 2015 | Heating & Cooling
Dewalt d55153 runs continually trying to get up to pressure, but can't.
Just a guess but I think you have broken the rings inside. If you keep running it with broken rings you will trash the cylinder inside. I think you can buy a new pump for it if you are not mechanically minded.
Apr 22, 2014 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
Air compressor not unloading
Check the pressure switch. The unloader valve is actually in the pressure switch where the small air line from the tank check valve attaches to it. When the pressure switch turns the motor off it then lets the head pressure bleed off so the motor can restart the next time pressure drops in the tank. If it's not working and bleeding off the head pressure the cold start valve (the one with the pin in it) also won't open so the motor can restart and warn up properly.
Sep 09, 2012 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
Hey there. I am having problems with my Emglo Dewalt d55151 compressor. I have taken it apart and and cleaned everything up. The reason I did all this was..because the cold start valve stays open and its...
The cold start valve will close when volume of air from compressor is sufficient to overcome spring under pin (allows the motor to come up to speed). Evidently your compressor is producing very little air. Usually the problem is leaking or broken reed valves or gaskets. Remove the head and look for torn/ leaking gaskets and replace as needed. Examing the reed valves and seats and look for broken cracked reeds or worn seats. Some of the valve plates used in Dewalt compressors are made of aluminum and would fail. Parts are available at www.toolpartsdirect.com or local dewalt service center. Good luck with your repair.
Apr 25, 2011 | Dewalt d55151 factory reconditioned emglo...
How do I know if compressor of my house air conditioner is turning on when I start my air conditioner? When I start my air conditioner the fan outside the house turns on, the air is blowing from the vents...
if the compressor is starting there will be a very small dimming in the house lights,if you go outside to the unit and start it from the outside disconnect when the compressor starts you will hear a whine type noise coming from the outside condenser unit that is the hermetic compressor motor operating,no cold air can be a number of issues,low on refrigerant(not likely on the new sealed systems) a bad motor start/run capacitor(quite likely) a bad contactor on the outside unit that supplies power to the compressor,one leg of the 240volts that supplies the compressor power,the fan will run on 120 volts,but the compressor needs 240 volts check the fuses.breaker in the power panel
Apr 02, 2010 | Heating & Cooling
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
