SOURCE: Excess frost not keeping food frozen
you have a refrigeration issue. let me guess. is the frost real thick around a small area not the entire lining? if so you have a restriction or leak. cheaper to replace by the way
SOURCE: freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
SOURCE: freezer has developed some frost in the back
This is a fairly easy problem to solve. First thing you will need to do is defrost the ice on the inside back panel of the freezer. Then remove the back inside freezer panel. You will need to remove your freezer shelves to do this. Once the panel is removed you will need to defrost the coils and surrounding area. Once defrosted you will see your defrost heather on the bottom of the coil and a defrost thermostat on the top of the coil. The defrost thermostat is about the size of a quarter and about 3/4 inch thick. It will be mounted on the coil line. If you have a multi tester you will be able to check continuity through the heater by unpluging it. The defrost thermostat is a bit more tricky to check. It will not read continuity once it is warmer than 50 degrees. The defrost thermostat is a fairly inexpensive part so if your heater is good you may want to just replace the defrost thermostat and see if the problem goes away. The other possibility would be your control board. It is located on the back of the refrigerator and has a metal plate covering it, with sever 1/4 inch screws. This board causes most failures on your model refrigerator. Also a point to remember. This board has had several new upgrades from the one originally installed on your refrigerator. So make sure if you get a new one that you get the listed number I have given you. The older ones are cheaper but they are also not updated and will not function properly on your refrigerator. The following parts listed are the possible parts you will need. Please let me know if you need one and I can ship it to you in about 1-2 days. I do not charge shipping and I give free advise. Thanks and good luck with your frost problem. you can reach us at.
Michael Anderson
Anderson Appliance
(865)945-3808
[email protected]
defrost thermostat. #WR50X10068 $21.57
defrost heater #WR51X10042 $56.50
control board #WR55X10656 $185.50
SOURCE: Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
