When downloading tv says no device - Televison & Video
How do I watch Netflix on a non-smart Vizio TV?
Here are several answers--but keep in mind, they all involve attaching a device of some sort--whether it's a computer, a laptop, a tablet, a phone, or a device like Google's Chromecast, Amazon's Fire Stick or FireTV, or other devices similar to those I just mentioned from Google and Amazon.
You will usually need an HDMI cable to attach your device to the TV (whether it needs an HDMI cable or not depends on whether the device plugs directly into your TV's port or whether it needs a separate cable--of which there are standard HDMI, mini HDMI, and micro HDMI).
The simplest, easiest, and least expensive types of equipment to enable your non-"Smart TV" to view Netflix are the "key-fob" type devices like the Chromecast and Amazon Fire Stick (there are others, but these are the most common, most popular, and well-supported devices.)
You would simply plug the device into your TV's HDMI port, attach the power cable (these devices may be able to draw power from your TV's HDMI port, but often require a separate power adapter to be plugged into them) log onto your Google Play account or Amazon account, download and install Netflix, and log onto Netflix. Usually (but not always) the Chromecast and Fire Stick have Netflix installed, but you may need to update or download and install/reinstall the Netflix app.
Oct 04, 2014 | Vizio Televison & Video
How can I watch movies from android on tv
ChromeCast Hardware device + Google Home App:
Chrome cast works with 100s of applications
Aug 17, 2014 | IMDb Movies TV
I need driver for saa7130 tv card
This particular device is tricky as Philips does not have drivers on their website, however there is a way to get this up and running.
First thing you are going to do is download two zipped folders, each containing the software that you will need. The first driver package is located here (unzip but do not install).
Second you will download the software package, located here (but do not unzip or install yet install).
Third, uninstall the TV tuner card if is showing up in Device Manager. You can get to Device manager by right clicking on My Computer and selecting Manage. In the left side click Device Manager. When all the devices are shown, right-click on the TV tuner card and click uninstall. Also, because the TV tuner card may be hooked up and no drivers are installed, you may see an "unknown device". Uninstall the "unknown device". Now run the installation/setup program from the first download and follow the step by step instructions.
After setup has finished installing the drivers, go ahead and restart your computer. After you have logged back into your computer, your operating system will recognize the TV tuner and may prompt you for the driver files via the Found New Hardware wizard. When prompted for a driver, browse to the first folder that you downloaded and select the driver file. Now that your computer has recognized and successfully installed the hardware, you will unzip and run the setup file from the second folder you downloaded. This is the software application that will use to interact with your new tuner card.
Oct 29, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
I need to download the remote codes for Tohisba tv
You can doenload the codes for your toshiba TV from below website.
http://remotefinder.rca.com/default.aspx?site=rca
Please select your
1.Remote model
2.The type of device you want code(DVD/TV/VCR)
3.The make of your device(Toshiba,Samsung)
It will provide you the CODE for your device
Thanx
Jul 23, 2010 | Toshiba 32A33 32" TV
Adcom tv tuner driver of multimedia controller
A driver can be downloaded from DriverGuide.com
http://members.driverguide.com/driver/detail.php?driverid=1281766&action=download
Also Supports: AD-TV878R - ADCOM TV/CAPTURE -, Bt848 Video Capture Device, Bt849 Video Capture Device BtTuner, Temic WDM TvTuner, BtTuner, Philips WDM TvTuner (PAL BG), BtTuner, Alps WDM TvTuner, BtXBar, WDM Crossbar, BtCap, WDM Video Capture, Bt878 Fusion Capture Device - Video Section, BtTuner, Philips WDM TvTuner (PAL I) Manufactured By: Other Companies, Brooktree Corporation, Conexant, Brooktree File Name: PCTV.rar (6.5 MB) -------------
If required register for free donload, driver is available on that forum
Kind regards
Jul 21, 2010 | Adcom GCD-750 CD Player
I need installation cd for philips saa7130 tv tuner. where do i go get one?
May 18, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have the card, but I dont't know how can I see tv. Download a driver(which)?
You need a driver, unless windows automatically installs. Do you see the device under Device Manager? If yes, do you have the antenna connected?
If not, you can download the driver or the software located here
Feb 28, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
How do i get a software upgrade for my tv
You will need a USB port or SD Card reader on the TV set in order to update the TV's Firmware. (note: some TV manufactures specify what types of memory are compatible with their TV sets i.e. magic gate, etc.)
Use the appropriate storage device for your TV set and go to:
http://www.support.philips.com/support/downloads.jsp?userLanguage=en&userCountry=us
Enter the model number in the search box. It will search for available software/firmware for your TV set. Download it and save it to your storage device.
Insert the storage device into the TV set. If the software/firmware update screen does not come up automatically, select update software/firmware from the TV's menu.
I hope this helps.
Feb 12, 2010 | Philips Televison & Video
Where can i find a software download load for teac usb 2.0 tv tuner
To download TV Wonder USB 2.0 driver read the instructions below. If you have any other questions please let us know by contact form.
ar.gifDownload ATI TV Tuner / Card Driver dev_img.gif May be useful for you: Please, enter verification code:
verimg.php Refresh
Download Clicking this button you agree with our Disclaimer a
DOWNLOAD LINK:::: http://www.nodevice.com/driver/TV_Wonder_USB_2_0/get34949.html
vote for me
Aug 15, 2009 | Teac CD224U 24X CD-ROM EXTERNAL DRIVE SLIM...
Televison & Video Logo
Top Televison & Video Experts
