Question about Cell Phones
Binatone M312 mobile. Person who I'm calling can only hear when on H-free mode - H-Held doesn't work. Can't find anything in menu to help?
SOURCE: can't hear caller
I expierenced the same problem with my V265 phone. First, note that performing this repair as I did will most likely void any warranties on the phone, and also is an electrical shock hazard. This repair should only be performed if the person/s performing the repair understand these risks and have at least basic technical knowledge in circuits, electricity, and audio. I take NO RESPONSIBILITY for damage or injury in any way, shape, or form. Please to prevent errors or any more damage, read directions fully before starting this repair. - Remove the Battery and make sure no chargers, headsets, etc., are currently plugged into phone. - Remove the housing on the phone which is on the same side of the camera and the external display by gently and carefully prying, making sure not to break the latches or any of the external parts. - Using a Torx bit (I believe it was either a T15 or T20 I used but not sure) or a small flat head screwdriver, remove the 4 screws holding down the board. - Now examine the speaker located at the earpiece of the phone and the two contacts which are on the board you just removed. Look to see if they were properly alligned and if contact is being made between the speaker and the board. (a PINK pencil eraser works great as a cleaner for circuit board contact points) - If contact is being mad and no obvious obstruction is found to prevent contact with the two, the easiest way for me was to take a speaker from another phone, and using it in place of the old one. (If you are willing to use extra time, you could also try finding an actual replacement from a manufacturer.) - I used a speaker from a motorola phone which was actually a few years older than my V265. - After finding a replacement speaker, you'll need to use some trial and error to properly allign it with the contacts on the board and to make it stay in position during everyday use. - For my V265, I had to use a razor and shave away the plastic molding which held the old speaker in place. Then use a VERY small amount of super glue to hold the speaker in position. Then I used a little bit of hot glue to give it some flexible strength. All together, it took me about 1 hour to complete this task and start using my phone again normally. - If any additional assistance is needed, feel free to e-mail at spike8551@comcast.net leaving your name and prefirably a phone number and best time to call, as a return contact. This will make it easier for me to help the best I can. Thank you and good luck.
Posted on Dec 21, 2006
deepakonly
  • 87 Answers
SOURCE: Voice sound has gone on phone (but ringtones and all other sound working).
there is problem inside ur phone. the speaker which gives sound to listen in caller's voice that has spoiled. take it to technician it need to be replaced
Posted on Feb 23, 2008
Phone Squad
  • 32 Answers
SOURCE: Person I call can't hear me
Hello alvarado,
Based on the information provided it sound like the microphone has malfunctioned and these microphones can be replaced. BUT FIRST CHECK TO MAKE SURE DEBRIS IS NOT CLOGGING THE MICROPHONE HOLE. LOOK OVER THE PHONE TO FIND A SMALL HOLE WHICH MAY POSSIBLY BE FILLED WITH SOMETHING. ( hope this is all but...)
If the phoneis less than a year old, it was purchased by you from the provider andit is in the exact condition is was when purchased you should attempt awarranty claim through your cell phone provider.
Canyou recall an incident that occurred to cause the device to begin tomalfunction?. ie Dropped, exposed to liquid? If so, you can visit thisrecommended repair center for an out of pocket solution.
Cell Phone Technicians
Possible temporary solution:
Use a wired / bluetooth headset or speaker phone option until in a position to find a permanent solution.
ERIC the PHONE GUY
Posted on Dec 16, 2008
SOURCE: i am unable to hear sound when i make call or receive call in normal mode.
Hi everyone, after spending sometime scouring the internet to no avail in order to fix this problem it suddenly occurred to me that the little holes in the earpiece may have become blocked from sitting around in my pocket. I have carefully cleaned all three of them with a pin and Hey Presto I can hear fine again without going on loudspeaker. Rgds Bill
Posted on Jan 16, 2009
e-Guru
  • 3917 Answers
SOURCE: mobile
Please check the right hand button to maximum while ur on the call. This should increase the volume.
Let me know if u require the manual for details,
Posted on Apr 27, 2009
I need binatone m312 manual in large print can you help
Hi the manufacturer might b the only one to help U ......,.phone 852-28027388 if no good try Amazon.co.uk 1-888-280-3321. good luck
Nov 04, 2016 | Binatone Lands Phones
How do I rotate to landscape from portrait on a Binatone ereader?
If you have a Binatone ReadMe Mobile press on Menu, then select more and choose settings.
If you have a Binatone ReadMe Daily, in reading or picture mode, press the rotate button.
Hope this helps.
Jul 11, 2014 | Mach Speed Trio Portable MP3 Player
I have a fake Iphone model A1241 g4gb sw:BYT.A608W.04_A1.1.1 HW:HAOCHENG35_09A_HW i would like to enter engineering mode to set volume because when someone calls me doesn't hear anything. it...
It looks like your loud speaker is burnt off/set to off or anything problematic related to your loud speaker. I'd suggest you to get it repaired by a skilled personnel
Jun 20, 2017 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Why am I unable to text on my binatone mobile phone when I try to send a text message to someone it reads 'please wait'.
It should say "Please Wait" briefly, if it does for any length of time it may be worth contacting your network provider. If it still doesn't work call Binatone Helpline on 0845 345 9677.
Apr 05, 2011 | Motorola Mobility W510 Mobile Phone
Cordless phone e3300 Binatone blocked
A friendly person sent me a manual for the e3300 and I managed to correct the problem.Thank-you for your concern and support.
Apr 19, 2009 | Lands Phones
Philips CD240 2nd phone wont connect - keeps saying searching
Hi, I solved this issue this morning. What you cannot confuse here is that handset and base. To do the registration successfully, the both must be in "Registering" mode. First, to get the base in the registration mode, you have to press <page> (a paging function for handset in case you cannot find where they are - usually button that says <page>or speaker with sound symbol on the base) more than 5 seconds, then the base is in the "Register Mode"(though you will hear no beep). You can then go through the procedure you describe on the handset and the handset should beep with assigned number no more than 10 seconds after it flashed "Waiting". The above, however, works only if the Base is still functioning. In my case, sadly, the base was more likely dead (if I press any button on the base, i.e. answer phone etc., there is no response). Hence I went and bought a new cheap GAP compatible BINATONE 1800 Single at Comet (14.99). I then set up the base, put it in the registration mode as per the BINATONE instruction. Then on the Phillips CD240 handset and gone through the above registration procedure... and Voila! It worked. Now I have a brand new base that came with 1 handset of its own, and 3 additional CD245 handsets which are all registered with this base. So far, the sound quality is good and they retained all the telephone numbers registered with the handset. The BINATONE base came with 12 months manufacturer's guarantee so I am sorted with the base problem for at least a year, which is nice. I hope this is helpful. Best, Ken
Feb 03, 2009 | Philips Lands Phones
Dropped in water
I got my i870 from my sister a week ago, i got it for boost mobile but the ear speaker doesnt work either, i took it apart and i ordered the flip part of the phone which comes with the whole top section. It should work after i put the new part. it was only $26 off of ebay. the parts were only held up five screws. really easy but you have to be careful and gentle.
Dec 31, 2008 | Motorola Mobility i870 Cellular Phone
Cell Phones Logo
76 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
