Question about Westinghouse Washing Machines
We have moved to a property with an old Westinghouse CSB 140 top load machine - but have no idea what the program settings mean - does anyone have a manual please?
Washer moves during spin cycle
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
May 27, 2012 | Westinghouse WWS833ES Super Capacity Top...
My Westinghouse lt908s washing machine has started bundling clothes up and knocking sides of machine. Even after opening lid and redistributing load evenly it keeps spinning then bundles up load and knocks...
May be a problem with agitator gear box,open on wash cycle and use screwdriver to by pass cut off switch by pushing screwdriver down on little switch that is located where tab on lid is.If agitator is traveling at too much of a rotation that may be cause,also agitator mat be lose if you can grab and move up and down.Then remove cap on top of agitator and tighten bolt,if lose if not agitator may need to be replaced!
Jun 12, 2011 | Westinghouse Washing Machines
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
Screen won't work on new computer
Reconnect the old monitor.
Start Windows.
Right-mouse click anywhere on your "wallpaper".
Click Properties.
Click Settings.
Move the slider to 800-by-600 or 1024-by-768.
Click Apply
In 'Advanced', set the refresh-rate to 60 Hertz.
Click OK.
Shutdown.
Reconnect the new monitor.
Restart your computer.
Click Properties.
Click Settings.
Now try moving the slider to higher values.
If the screen goes blank, wait 15 seconds, and Windows will cancel your change to a higher value.
Apr 07, 2010 | Westinghouse 25.5" Widescreen Flat Panel...
Excessive vibration since moving--not before
is the place you moved the washing machine level are the legs level if so you have a blocked sump
Jun 24, 2009 | Washing Machines
Machine will not operate
If you are getting a flashing "0" and a buzzing sound it means you needed to hit the Skip/Reset button at the end of the last program. Shut everything off, then hit the Skip/Reset button a few times and then put in a new program and see if it works.
Mar 06, 2008 | Zanussi ZWF1440 Front Load Washer
Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Nov 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Westinghouse Top Load Washing Machine
Possible your outlet filter is blocked, it need periodic cleaning, which the user can do himself. Locate where this is from your user's manual. Clean out, re-fix. Next it could be the hose that goes from the bottom of the tub to the filter pump; check the former first. Well, you have a record of sorts, 30 years!!
Jun 13, 2007 | Westinghouse WWS833ES Super Capacity Top...
Baumatic washing machine instructions
the twelve programs are explained on the detergeant drawer.if not i will post them for you.
to use the dryer turn the middle knob clockwise to the amount of time you desire upto 140 minutes then select the temperature on the far left knob and then depress the half load button your dryer should now work.
Jan 11, 2007 | Baumatic BTWM4 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Harjeet Singh
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
