I have a Samsing tv. Model number BN64-02175A-00. I have a black screen with sound. Nothing happens when I push the menu button. I have tried soft reset. What is my next step?
  • Televison & ... Master
  • 6,694 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/ some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board . In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 23, 2016
Black TV screen: no image, just sound
Sounds like the brightness might have been turned down. Does it have a manual brightness control? Sometimes there is a combination of buttons you can push on the remote to reset the TV to factory specs. Add some more info about the TV, Make, Model #
Feb 17, 2014 | Televison & Video
Black screen and no sound no menu no anything after remote hit
test with another remote.
buy a cheapy remote at dollar general
and see if you can connect it to the tv with code number
code numbers on internet
Jul 31, 2017 | DISH Network 322 DTV Receiver
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
Video is snow. no images just lines and snow. the only menu that appears on the screen is the net command set up menu. after a couple of minutes the TV powers OFF no matter what i try. i tried pushing the...
A suggestion: try with the original Mitsubishi remote to do the soft restore: Menu, 1,2,3, enter.
BEFORE YOU RATE THIS SOLUTION LET ME KNOW WHAT YOU FIND.
SD TECH
Jul 05, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Tv continually changes from video 1 to video 2 to video 3 etc... sometimes get black screen as well + menu items. Based on a suggestion, I removed the batteries from the remote but that does not help. This...
It sounds like a switch problem inside the TV if you have already tried removing the remote batts. Try replacing the switches behind the push buttons on the front of the TV. Also, if glass cleaner or some other foreign substance has run down the front of the screen and into the set, this can cause switches to short out and cause this problem. The part number for the switches is 23145227. Thanks for using fixya.
Jan 20, 2010 | Toshiba 32AF43 32" TV
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
