Replaced bulb w/ new one lights still flash and won't power up 62hm15a red color was acting strange before everything else went down
SOURCE: no power,red power lights keeps flashing.
Just my coment THis tv has a complex system that include a digital signal porcessing in a high levle technology to show a good performance, i myself work on the development of that model, we was thinking we are best, for improve that many eng. dedicates almost all life to have that technology in our rooms, I offer my apologize for that but many eng dedicates all year 18 hours a day to fix that, thanks
Posted on May 13, 2007
  • 24 Answers
SOURCE: flashing red light no power
The convergence I/c's are shorted.
Posted on Jan 14, 2008
SOURCE: Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Posted on Mar 27, 2008
SOURCE: My Toshiba 62HM15A DLP television
I just had the same problem last week I had reinstalled another lamp unit on my 62hm14 DLP, and it was doing the same thing both lights were blinking but the tv would not power up and come on.
It was simple once we figured out what was wrong the lamp unit door apparently has a safely mode switch and if the screw is not screwed into the tv to keep it from being opened it will not come on. It was just a safety feature.
We dropped our screw and god knows where it went but we found another, put it in and ta da tv came straight on.
Posted on Dec 02, 2008
  • 157 Answers
SOURCE: sony xbr 60 tv has lost red color
SONY IS INVOLVED IN A CLASS ACTION SUITE-problem is a bad light engine-check into this on the web-check your model number to see what they are willing to do.
IT IS A COSTLY REPAIR IF YOU HAVE TO PAY A TECHNICIAN
Posted on Sep 03, 2009
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
I have a Toshiba DLP 62HM15A TV; I turned the TV off the night before and everything was working fine. But the next morning I went to turn it on, but the power red light came on then turned off then o
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. This should fix the problem. Check to see if your TV is still under warranty first though.
Dec 04, 2014 | Toshiba Televison & Video
Samsung HLR5667wx/xaa. Power surge took out tv. Replaced bulb and the bulb works, but tv wont come on and lamp light is flashing.
Hello, it sounds like the color wheel may have failed. Was there any noises, like a high pitch sound before it went out? If the color wheel isn't turning at proper speed, the set won't start up by shutting down the lamp protection circuit.
Jul 10, 2014 | Samsung HLR5667W 56" Rear Projection HDTV
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
Red light flashing screen is green turn off itself
your color wheel/ color main bored has gone bad (red flashing indictating one of 3 things depending on flashing. no power to main board. or to much power/bad board on one of the color boards) or you just need to replace the bulb in it. i doubt its a bulb issue bc you do see a greenness to it at first. but *** will auto shut down till the board is fixed. sorry for the bad news but this is your solution. . if you can tell me what model the tv is i cna find out exactly what it is and how many flashes.
Mar 19, 2011 | Sony Televison & Video
I was watching the TV, and heard a weird crack sound. The TV went yellow, and when I shut it down, the lights in the front flashed as if I needed a new bulb. I replaced the bulb, and it acts like it can't...
It sounds like the color wheel has failed and needs to be replaced. I don't know what brand you have but I would find a factory authorized repair center for that brand. You can usually find one by googling the manufacturers' name.
May 04, 2010 | Televison & Video
Toshiba 62hm15a- bright flashes
my toshiba 62HM15A has bright and dark flashes.
Sep 30, 2008 | Toshiba 62HM15 62" Television
Powers on shuts off after 10 seconds- red/green flash
its probably the bulb. if the red and gren lights are flashing simultaneously, than that means the bulb is burnt amd you need to order a new one and replace it.
hope this helps
Sep 22, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
