Question about Panasonic Televison & Video
How do i get this blue box with text to go away on tv
    President:
  • 1,273 Answers
On mine, the exit button does it.
--W/D--
Posted on Jul 21, 2009
Black box in middle of tv screen
This is a background for text, even though you aren't seeing any text at the time. Since it covers most of the screen, it sounds more like a demo mode screen than closed captioning. Go into your setup menu and make sure that neither of those is selected. If necessary, restore the factory settings. I'm assuming that this is coming from the tv itself, and that you don't have a VCR, Tivo, etc. Good luck!
Jun 15, 2009 | Hitachi 50UX57B 50" Rear Projection...
I have a black box going across my screen with blue numbers it will not go away. I have an emerson 32in hdtv flat screen
Make sure closed captioning is turned off on the TV as well as your cable box or satellite receiver (if you are using them and they have that feature). Captioning is probably on and set for text mode.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Black box when tv is on and going through channels
This worked on my tv...give it a try:
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | JVC AV-36S33 36" TV
There is a large black box that appears on my screen and makes it so that that I can not watch the TV. It takes up the entire picture and all that I can do is hear whatever my be playing. Once it comes on...
Check your closed-caption settings. You will probably find that you have captioning on and set for "text" mode. Turn it off and the problem should go away.
What's happening is that with text mode on, the set clears an area (the black box) for text to be displayed, but there's no text. On channels or programs where captions aren't being broadcast, you don't have this problem. Most TV remotes have a button for quick access to caption settings, so it's easy to get this turned on without knowing it. Then you're suddenly facing the black box.
Please take a moment to give this solution a fixya rating if it gets your box cleared up, and thanks for asking here!
Mar 06, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Black box
Make sure your closed-captioning is turned off. This box appears when you have captioning set for "text" mode and the set is on a channel where captions are being broadcast. The TV blanks the part of the screen where the text would go, but there isn't any to display. Some TV's have a single button on the remote to turn captioning on, and it's easy to set the TV for captioning without knowing it.
Dec 18, 2008 | iLO Televison & Video
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
JVC TV
The black box is called a text box and it is a selection in the
closed caption feature or CC......go thru each menu page until
you find CC....cycle thru choices until you get to off or try each selection until Text box and CC are off.................T.
Dec 23, 2007 | JVC AV-32F475 32" TV
Blue rectangle at bottom half of screen??
Try to change the Caption mode: Press ACTION to display the MAIN MENU Select TV - CAPTION - OFF It should help.
Sep 12, 2005 | Panasonic PV-M2058 20 in. Combo
Televison & Video Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
