Question about RIM BlackBerry 7290
Blackberry 7290 issue
I can't get my blackberry 7290 to work. there is just a small box wih a circle, a square and a triangle in it. surrounding this is a circle with a half check through it as to say "no". at the bottom is the number 507.
  • 5 more comments
  • loulouda Nov 28, 2007
    error code 507
  • ValerieMcB Dec 30, 2007
    I have exactly the same problem, box with circle around it etc. i don't understand what you mean by "go to options". Is this on my Blackberry or somewhere on my computer? If you mean for me to go to options on my Blackberry, that is impossible because I can't get beyond the above described screen, it it is somewhere on my computer, cna you be more specific? I guess I need Fixya for dummies. :-)
  • Anonymous Jun 19, 2008
    how to reload my blackberry7290 on my computer with usb card
  • WENDYGMARTIN Dec 01, 2008
    HOW DO YOU TURN THE BLACKBERRY 7290 ON??? WHERE EXAXTLY IS THE ON SWITCH LOCATED ON THE OUTER SURFACE OF THE BLACKBERRY?
  • usgrunt12 Mar 30, 2009
    i can't get my blackberry 7290 to work. there is just a small box wih a circle, a square and a triangle in it. surrounding this is a circle with a half check through it as to say "no". at the bottom is the number 507.
  • feker May 11, 2010
    can black berry 7290 cingular accept external memory pls answer me
  • Anonymous Mar 17, 2014
    mine has reload software 507 and a little rectangle with a circle,square and tringle in it and aline going accross.. how can i solve this please?
My blackberry 7290 keeps saying device error:400 then below says reset i keep reseting it and nothing comes but it keeps saying reset .. wat can i do ?
Posted on Apr 23, 2008
  • lori1975 Apr 23, 2008
    wat if i didnt back up the black berry and did the upgrading and it shows the triangle and circle error 507 what you need to do to get it back and working ???
    Novelist:
    Champion:
  • 244 Answers
Pull the battery out of your device.
With the battery out connect the device to the computer.
Go to Options and select "connection settings"
Select USB PIN this may take a few moments since there is no battery in the device. you might even have to select detect device in some rare cases.
Select the application loader icon.
Select all software you want installed.
Proceed to the end portion untill you see the "Finish" button.
Very IMPORTANT. do not hit the finish button, instead select the ADVANCED button.
Make sure both boxes are checked.
Proceed until it asks you if you want to automatically back up and restore. Select DO NOT AUTOMATICALLY BACK UP MY HANDHELD.
Once the process starts re-insert the battery. Again on some rare occasions you might have to wait until it finishes saying connect to insert the battery.
Posted on Nov 21, 2007
Posted on Dec 20, 2010
I dropped my phone :( now when i put the battery in...the hourglass just keeps going in circles and thats it....i cant turn it off...it wont go to the home screen....nothing....is it broken...should i take it to get it checked out??
Posted on Oct 05, 2008
The software in your device is corrupted and you have no java, hence cannot access your password Installing BlackBerry Handheld Software
For reloading the BlackBerry handheld code onto your device, please follow these simple instructions.
Make sure you've loaded the BlackBerry desktop software, included in the box, onto your PC (When installing the BlackBerry desktop software, please select the option to integrate with a new email or existing Internet Service Provider (ISP) email account.
If you have the BlackBerry Desktop software open on your PC, please close it before downloading the software.
Step 1: Click on the desired handheld software link to download the software and follow the installation wizard.
Step 2: Open the BlackBerry Desktop Software and connect your BlackBerry to your PC
Step 3: If you'd like to keep any of the data that's already on your BlackBerry, and restore after reloading the handheld software, select the Back up and Restore option, and select Back up. If you'd prefer not to keep any of the data on your BlackBerry, follow Step 4.
Step 4: From the BlackBerry Desktop Manager > double-click Application Loader icon. The Application Loader wizard appears.
Step 5: Click Next. The Handheld Application Selection window appears.
Step 6: In the Handheld Application Selection window, ensure the appropriate applications are selected and click Next.
Step 7: The Completing the Application Loader Wizard appears, and states no actions required. Click Advanced.
Step 8: In the Handheld Data Preservation window, select Erase all application data and Erase all currently installed applications and click Next.
Step 9: Click Finish. The handheld resets.
Note: This process will take several minutes.
This is easy, delete the software from your computer and reload it, move up to a 7290M_PBr4.1.0_rel210_PL1.8.0.143_A4.1.0.256_Orange, for your orange U.K. or a 7290M_PBr4[1].1.0_rel466_PL1.8.0.149_A4.1.0.351, 02, First install, Desktop Software v4.2 SP2 (English)(2), this way you will have Roxio.
If you live in the U.K. i will do it for you
Posted on Apr 20, 2008
This did not work for me, but it did help to point me in the right direction. I had to reload the latest version of the blackberry operating system on my device to clear the 507 error.
Posted on Mar 21, 2008
I hav the same problem... i connected my device to the PC. further i have the disk came with my blackberry... when i run application loader it doesnt fine the any file with the extention .alx... how can i refresh my device software? plz give me details solution
thnx
Posted on May 27, 2008
2 Suggested Answers
SOURCE: blackberry 7290
may be you should try the newly lunched NOKIA N97 featuring a big enough keyboard if your pocket is laded enough.
Posted on Jun 01, 2009
Gta4 cheat codes ps3
Enter one of the following codes during game play. A small box will appear to confirm correct code entry.
Code: Result:
Circle, X, Circle, Square, Triangle, L1, R1, L2, R2. Any truck with trailer
R1, L2, R2, L1, Up, Down, Up, Down, Up, Down. Cop
Triangle, Left, Right, Circle, X, Up, Down. Drink beer
R1(2), L1, R2, Triangle, Left, Right, Square. Fly in the air
R1, L1, L2, Square, R2, Left, Right, Left, Right. Health
X, Circle, Circle, R1, Square, L1, Triangle. Helicopter
Up, Down, L2, R1, X, L1(2), Right, Left, Up. Listen to Back On My Grizzy in car
R2(2), Up, Circle, L1, L2, Down, Triangle, R1, Right(2). Listen to Crank That SouljaBoy in car
Circle, Right, Circle, Right, Left, Square, Triangle, Up. Lock wanted level
Up, Down, L1, L2, Left, Right, R1, R2, Square. Money
L1, Circle, X, R1, L2, R2, Square, Triangle, Triangle, X. Monster Truck
R1, Circle(2), L2, R2, Triangle, X, L1, Right. Never die
Press X, Circle, Triangle, Up, Down, Left, Right, Circle(2) while in an area with a lot of space. Private jet with pilot
R1(2), Left, Right, L2, Square, Triangle, L1, Circle. Run quickly
L1, R1, X, Circle, Triangle, X, R1, Square. Semi truck with trailer
R1, Circle, L1, X, Left, Down, L2, Up. Smoke
Up, Down, Left, Right, Circle(2), Left, Right. Tank
Square, Circle, X(3), Triangle, Square, Circle(3). Unlimited bullets
Square, Left, R2, Down(2), L1, Up, Circle. Unlimited money
R1, L2, R2, L1, Right, Down, Left, Up, Right, Down, Left, Up, Right(2) Weapon tier 3
R1, L2, R2, L1, Up, Down, Left, Right, Up. Weapons tier 1
R1, L2, R2, L1, Right, Down, Left, Up, Right, Down, Left, Up. Weapons tier 2
Cell Phone Passwords
At any time during the game, pull out Niko's phone and dial these numbers for the desired effect.
Password: Result:
468-555-0100 Change weather
486-555-0150 Get a different selection of weapons
486-555-0100 Get a selection of weapons
267-555-0150 Raise wanted level
267-555-0100 Remove wanted level
362-555-0100 Restore armour
482-555-0100 Restore health
227-555-0142 Spawn a Cognoscenti
227-555-0175 Spawn a Comet
938-555-0100 Spawn a Jetmax
625-555-0150 Spawn a Sanchez
227-555-0168 Spawn a SuperGT
227-555-0147 Spawn a Turismo
359-555-0100 Spawn an Annihiliator
227-555-0100 Spawn an FIB Buffalo
625-555-0100 Spawn an NRG-900
Jun 04, 2014 | Video Game Consoles & Games
How many cheats on liberty
CodesEnter these during gameplay
Effect Code 2 Gangs+14 Characters (Multiplayer) UP, UP, UP, SQUARE, SQUARE, TRIANGLE, R1, L1 4 Gangs+28 Characters (Multiplayer) UP, UP, UP, CIRCLE, CIRCLE, X, L1, R1 7 Gangs+43 Characters (Multiplayrer) UP, UP, UP, X, X, SQUARE, R1, L1 Aggressive Drivers SQUARE, SQUARE, R1, X, X, L1, CIRCLE, CIRCLE All Green Lights TRIANGLE, TRIANGLE, R1, SQUARE, SQUARE, L1, X, X All Vehicles Chrome Plated TRIANGLE, R1, L1, DOWN, DOWN, R1, R1, TRIANGLE Black Cars CIRCLE, CIRCLE, R1, TRIANGLE, TRIANGLE, L1, SQUARE, SQUARE Bobble Head World DOWN, DOWN, DOWN, CIRCLE, CIRCLE, X, L1, R1 Calls closest Ped to come hop on/in your vehicle. X, Square, Down, X, Square, Up, R1, R1 Cars Drive On Water CIRCLE, X, DOWN, CIRCLE, X, UP, L1, L1 Change Bike Tire Size CIRCLE, RIGHT, X, UP, RIGHT, X, L1, SQUARE Clear Weather UP, DOWN, CIRCLE, UP, DOWN, SQUARE, L1, R1 Commit Suicide L1, DOWN, LEFT, R1, X, CIRCLE, UP, TRIANGLE Destroy All Cars L1, L1, LEFT, L1, L1, RIGHT, X, SQUARE Display Game Credits L1, R1, L1, R1, UP, DOWN, L1, R1 Faster Clock L1, L1, LEFT, L1, L1, RIGHT, CIRCLE, X Faster Gameplay R1, R1, L1, R1, R1, L1, DOWN, X Foggy Weather UP, DOWN, TRIANGLE, UP, DOWN, X, L1, R1 Full Armor (Blue Bar) L1, R1, CIRCLE, L1, R1, X, L1, R1 Full Health (Red Bar) L1, R1, X, L1, R1, SQUARE, L1, R1 Have People Follow You DOWN, DOWN, DOWN, TRIANGLE, TRIANGLE, CIRCLE, L1, R1 Money Cheat ($250,000) L1, R1, TRIANGLE, L1, R1, CIRCLE, L1, R1 Never Wanted L1, L1, TRIANGLE, R1, R1, X, SQUARE, CIRCLE Overcast Weather UP, DOWN, X, UP, DOWN, TRIANGLE, L1, R1 Peds Attack You L1, L1, R1, L1, L1, R1, UP, TRIANGLE Peds Have Weapons R1, R1, L1, R1, R1, L1, RIGHT, CIRCLE Peds Riot L1, L1, R1, L1, L1, R1, LEFT, SQUARE Perfect Traction L1, UP, LEFT, R1, TRIANGLE, CIRCLE, DOWN, X Rainy Weather UP, DOWN, SQUARE, UP, DOWN, CIRCLE, L1, R1 Raise Media Attention L1, UP, RIGHT, R1, TRIANGLE, SQUARE, DOWN, X Raise Wanted Level L1, R1, SQUARE, L1, R1, TRIANGLE, L1, R1 Random Ped Outfit L1, L1, LEFT, L1, L1, RIGHT, SQUARE, TRIANGLE Slower Gameplay R1, TRIANGLE, X, R1, SQUARE, CIRCLE, LEFT, RIGHT Spawn Rhino L1, L1, LEFT, L1, L1, RIGHT, TRIANGLE, CIRCLE Spawn Trashmaster TRIANGLE, CIRCLE, DOWN, TRIANGLE, CIRCLE, UP, L1, L1 Sunny Weather L1, L1, CIRCLE, R1, R1, SQUARE, TRIANGLE, X Unlock multiplayer skins UP, UP, UP, TRIANGLE, TRIANGLE, CIRCLE, L1, R1 Upside Down Gameplay DOWN, DOWN, DOWN, X, X, SQUARE, R1, L1 Upside Down Gameplay2 X, X, X, DOWN, DOWN, RIGHT, L1, R1 Upside Up Triangle, Triangle, Triangle, Up, Up, Right, L, R Weapon set 1 UP, SQUARE, SQUARE, DOWN, LEFT, SQUARE, SQUARE, RIGHT Weapon set 2 UP, CIRCLE, CIRCLE, DOWN, LEFT, CIRCLE, CIRCLE, RIGHT Weapon set 3 UP, X, X, DOWN, LEFT, X, X, RIGHT White Cars X, X, R1, CIRCLE, CIRCLE, L1, TRIANGLE, TRIANGLE
Hope this helps and please rate my solution!!
Jan 04, 2011 | Rockstar Games Grand Theft Auto: Liberty...
Gta liberty cheats
Cheat Effect UP, SQUARE, SQUARE, DOWN, LEFT, SQUARE, SQUARE, RIGHT Weapon set 1 UP, CIRCLE, CIRCLE, DOWN, LEFT, CIRCLE, CIRCLE, RIGHT Weapon set 2 UP, X, X, DOWN, LEFT, X, X, RIGHT Weapon set 3 L1, R1, TRIANGLE, L1, R1, CIRCLE, L1, R1 Money Cheat ($250,000) L1, R1, CIRCLE, L1, R1, X, L1, R1 Full Armor (Blue Bar) L1, R1, X, L1, R1, SQUARE, L1, R1 Full Health (Red Bar) L1, R1, SQUARE, L1, R1, TRIANGLE, L1, R1 Raise Wanted Level L1, L1, TRIANGLE, R1, R1, X, SQUARE, CIRCLE Never Wanted CIRCLE, X, DOWN, CIRCLE, X, UP, L1, L1 Cars Drive On Water X, X, R1, CIRCLE, CIRCLE, L1, TRIANGLE, TRIANGLE White Cars CIRCLE, CIRCLE, R1, TRIANGLE, TRIANGLE, L1, SQUARE, SQUARE Black Cars L1, UP, RIGHT, R1, TRIANGLE, SQUARE, DOWN, X Raise Media Attention TRIANGLE, CIRCLE, DOWN, TRIANGLE, CIRCLE, UP, L1, L1 Spawn Trashmaster L1, L1, LEFT, L1, L1, RIGHT, SQUARE, TRIANGLE Random Ped Outfit L1, L1, CIRCLE, R1, R1, SQUARE, TRIANGLE, X Sunny Weather UP, DOWN, CIRCLE, UP, DOWN, SQUARE, L1, R1 Clear Weather UP, DOWN, X, UP, DOWN, TRIANGLE, L1, R1 Overcast Weather UP, DOWN, SQUARE, UP, DOWN, CIRCLE, L1, R1 Rainy Weather UP, DOWN, TRIANGLE, UP, DOWN, X, L1, R1 Foggy Weather L1, L1, LEFT, L1, L1, RIGHT, TRIANGLE, CIRCLE Spawn Rhino L1, L1, LEFT, L1, L1, RIGHT, CIRCLE, X Faster Clock L1, L1, LEFT, L1, L1, RIGHT, X, SQUARE Destroy All Cars L1, L1, R1, L1, L1, R1, LEFT, SQUARE Peds Riot L1, L1, R1, L1, L1, R1, UP, TRIANGLE Peds Attack You R1, R1, L1, R1, R1, L1, RIGHT, CIRCLE Peds Have Weapons R1, R1, L1, R1, R1, L1, DOWN, X Faster Gameplay R1, TRIANGLE, X, R1, SQUARE, CIRCLE, LEFT, RIGHT Slower Gameplay L1, UP, LEFT, R1, TRIANGLE, CIRCLE, DOWN, X Perfect Traction L1, DOWN, LEFT, R1, X, CIRCLE, UP, TRIANGLE Commit Suicide TRIANGLE, TRIANGLE, R1, SQUARE, SQUARE, L1, X, X All Green Lights SQUARE, SQUARE, R1, X, X, L1, CIRCLE, CIRCLE Aggressive Drivers DOWN, DOWN, DOWN, TRIANGLE, TRIANGLE, CIRCLE, L1, R1 Have People Follow You DOWN, DOWN, DOWN, CIRCLE, CIRCLE, X, L1, R1 Bobble Head World L1, R1, L1, R1, UP, DOWN, L1, R1 Display Game Credits DOWN, DOWN, DOWN, X, X, SQUARE, R1, L1 Upside Down Gameplay CIRCLE, RIGHT, X, UP, RIGHT, X, L1, SQUARE Change Bike Tire Size TRIANGLE, R1, L1, DOWN, DOWN, R1, R1, TRIANGLE All Vehicles Chrome Plated Triangle, Triangle, Triangle, Up, Up, Right, L, R Upside Up UP, UP, UP, TRIANGLE, TRIANGLE, CIRCLE, L1, R1 Unlock multiplayer skins UP, UP, UP, CIRCLE, CIRCLE, X, L1, R1 4 Gangs+28 Characters (Multiplayer) UP, UP, UP, X, X, SQUARE, R1, L1 7 Gangs+43 Characters (Multiplayrer) UP, UP, UP, SQUARE, SQUARE, TRIANGLE, R1, L1 2 Gangs+14 Characters (Multiplayer) X, X, X, DOWN, DOWN, RIGHT, L1, R1 Upside Down Gameplay2 X, Square, Down, X, Square, Up, R1, R1 Calls closest Ped to come hop on/in your vehicle.
Oct 30, 2010 | Computers & Internet
What Are Cheats In grand theft auto Liberty CityStories
Cheat Effect
Dec 19, 2009 | Sony PlayStation Portable (PSP) Console
8310 BlackBerry start-up symbol
you must fullflash your BB to work it again.you can use desktop manager 4.7 to flash your phone.
and here you can download firmware:http://na.blackberry.com/eng/support/downloads/download_sites.jsp
Jul 25, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry 7290
Jun 01, 2009 | RIM BlackBerry 7290
Blackberry wont work box circle square triangle keep popping and wont go to main screen
the 507 error refers to no operating system on your phone.
here is the solution.
open the desktop manager and go to application loader.
and reinstall all the software you have in your apps loader.
if you have never used blackberry desktop manager you can go to blackberry.com
and download it for free. then install the software.
you may need to install the usb drivers also get those there also.
then download the latest version firmware for your phone which you will find on the site also.
depending on your provider and what phone you have.
once you have all that and it's installed, plug your phone in with a usb cord to your computer and reinstall the software through the desktop manager and app loader.
if you have any problems let me know and I will hook you up
May 23, 2009 | RIM BlackBerry 7100t
Black berry 7290 is not working
Its mean you need to purchase new blackberry
Aug 27, 2008 | RIM BlackBerry 7290
Error Screen when turned on
You need to reinstall the reinstall the phones firmware. Go HERE to download the firmware.
Mar 21, 2008 | RIM BlackBerry 7290
RIM BlackBerry 7290 Logo
4,153 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
