Why paper 128 gm jam in summer - Office Equipment & Supplies
My hp laserjet p2015dn printer is not pickup the paper.
The typical cause of failing to pickup paper and paper jams is worn out pickup rollers. These are easy to replace. The kit of pickup rollers and separation pads can be found here:
http://www.ccl-la.com/catalog/product_info.php?products_id=128
Mar 29, 2012 | HP LaserJet P2015dn Printer
Tried to copy photo using scanner used photo glossy paper , paper got jammed in printer pulled out paper from front of printer , now printer wont print from computur , help needed .thank you
Hello.
Simply unplug it from the wall for 10 mins, then plug it back in and try again. Sometimes after a jam a re-start is needed.
Regards GM
Aug 01, 2011 | HP Office Equipment & Supplies
My printer jammed and after removing the jammed paper, the printer will no longer print correctly. It skips lines and the text that it does print is blurred and lightened.
Hello.
Check under the print head itself to see if there is any clogged pieces of paper. you will need a torch as the bits may be soaked in ink and black in colour. sometimes small pieces can get stuck under after a jam.
Also make sure the print head is sitting low enough to the paper being printed on. you may have shifted it up when pulling out the jam.
I hope this helps Regards GM
Jun 05, 2011 | Epson CX8400 All-In-One InkJet Printer
I inserted a paper while printing, and it jammed. I caanot turn off the printer, and I cannot eject the paper that jammed.
Hello.
Unplug the printer from the power, open all the covers and remove the jam. It will take some strength to get the paper out, but once you have plug it into the wall and it should work correctly.
Regards GM
May 27, 2011 | Office Equipment & Supplies
Paper jam
Hello.
Open all the covers of your printer, remove the cartridges and check for any paper of obstructions that are in the paper path.
Regards GM
May 27, 2011 | HP Photosmart C5280 Printer
Paper jam light is blinking, cannot find any jam
You may be having a problem with your paper sensors. You may need to have the printer serviced by a technician to verify. This problem seems to be a regular event with this model.
Jun 08, 2010 | HP LaserJet P2015dn Printer
Jamming
Have you tried cleaning the paper pickup and registration rollers? See page 128 in the HL-2700CN User Guide available from the Brother Solutions Center
Jun 02, 2010 | Brother HL 2700CN Laser Printer
Printer pulls paper to the right...causes paper jam
possibly some paper is stuck in the printer. Can you manage to open the printer and check this out. If no paper at all then possibly carry it in for in-warranty service to the company outlet.
Jun 25, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Data error
Epson DX4000 saying paper jam there is no paper in printer how can i solve this problem
Oct 10, 2008 | HP LaserJet 1010 Printer
20 people viewed this question
k24674
jasbo
jasbo
