Haw can fix 990 cod in nashutec d422 - Office Equipment & Supplies
How to fix 990 erro code without changing a drum ?
what model is it. that sounds like more of a hard drive issue than a drum issue.
Nov 22, 2014 | Ricoh 888073 Genuine Aficio 1035/1045 Type...
Reset codes 6500c
cod reset problem haw i can reset my phone security code?
Nov 24, 2013 | Nokia 6500 Classic Cellular Phone
Forgot patern unlock for alcatel 990
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Sep 02, 2012 | Alcatel Ot 990 Black Unlocked Android...
Changin batery radio is asking for sam sort of cod .end I dont haw a clu wat is it .can you halp plase.thanks.
It is an anit theft radio code, you should have a card with the number in the manual that came with the vehicle or should contact a dealership for the code.
Jun 07, 2011 | Volkswagen Jetta Cars & Trucks
IN RICOH AF 2045 SC 990
This error code could be related to a Physical problem (machine) or Network Problem.
Physical problem:
Try to clean the ID sensor.
Probably you will also need to clean or replace the Drum Unit.
Network problem:
Upgrade your firmware.
(If you do not have technical skills a advise you to call your provider)
See you!
Jun 06, 2011 | Ricoh Aficio 2035 Copier
My Aiwa NSX 990 wont come on. Only timer icon come in display and volumew LED keeps coming on and going off at regular intervals
Unplug the power cable completely to turn off and then turn back on again. Check whether there are no lose parts with missing contact.
Most probably it looks like a deeply digital problem with no do it yourself solutions - bring it to the repairman, but I even doubt he would fix it.
You can also download the Aiwa NSX-990 service manual and analyze more specifically your case. Download it from here: or from here: (click "Download Now", not any other button).
Dec 06, 2010 | Aiwa AV-S17 Receiver
990 cod in 1045
990 B Software performance error
The software attempted to perform an
unexpected operation.
• Software defective
• Internal parameter incorrect
• Insufficient working memory
• When this SC occurs, the file name,
address, and data will be stored in
NVRAM. This information can be
checked by using SP7-403. Note the
above data and the situation in which
this SC occurs. Then report the data
and conditions to your technical
control center.
It is a firmware issue u need to upgrade firmware on the copier
ull need a service engineer to do that
Nov 14, 2010 | Ricoh Aficio 1035 Copier
Error 990 keeps blinking on machine
This is an error that has to do with the ink drying up on the maintenance unit. This cannot be fixed by the end user and must be fixed by Ricoh. Error 990 is a Ricoh defect in which the printer should qualify for replacement.
Feb 12, 2010 | Ricoh Aficio GX5050N Printer
What is this nashutec error sc581
Hi you not say what printer you have, the only error I know is Cartridge error.installation of new black hp 27
Feb 10, 2010 | Office Equipment & Supplies
Error code 350 error code 990 error code 540
Error code 990 indicates software problems yuo can check in SP7-403 for information.
Error code 540 will proberly indicate some heating trouble in the fix, you have to reset the machine with service code SP5-810.
Code 350 will disappear if you restart the copier.
Oct 09, 2009 | Ricoh Aficio 1035 Copier
