Bonjour j ai un copieur couleur de marque gestenaire afecio ds 432 sa signala le code sc571
jerryg50
  • 1689 Answers
SOURCE: disque cod?
To have answers in these types of groups it is best to translate in to English.
The question in English:
Hello, I have a problem with a laptop which called for a password bios. Well, I removed the battery for a moment and that is installed. I launched the boot on the disc cd then it did the restart, it asks me a password hard disk. I then passes through several means even SKY_FOX I tried but nothing.C 'is a brand Fujitsu Siemens Lifebook and I do even more started on the system' exploitation. I really need help, if you could do something without needing expensive experts. Thank you. __ Have you contacted the former owner to get the password? If the hard disk is pass-word protected and you do not have the password, the fix would be to un-install the partition, and re-make it. Then do the full re-installation of the operating system, and the re-registration for ownership. In some cases where the hard disk is password locked, there may be no possible way to be allowed to undo and re-make the partition to do a full re-install. If this is the case, changing the hard disk will fix it. The old hard disk would be scrapped unless you can have its password. BIOS Level Password Procedure: With some models of computers, you can remove the BIOS battery and wait until the BIOS setup is depleted. Then you should then be able to have access to re-set up the BIOS. You will have the choice to put in a new password or simply not to. If the computer hardware is pass-worded at the BIOS level and it does not deplete with the battery removal, you will have to send the computer back to the manufacture to have the computer un-locked. You will have to pay the shipping and the service fee. When sending the computer back to the manufacture for the unlock, you will be asked for proof of ownership of the computer with proof of identification. With most computer companies, a copy of the purchase invoice, and a copy of your driver's permit or citizenship card should be acceptable. ________________________________
Google Translated, Answer in French: Avez-vous contacté l'ancien propriétaire pour obtenir le mot de passe?
Si le disque dur est mot de passe protégé et vous n'avez pas le mot de passe, le correctif serait d'installer un-la partition, et re-faire. Ensuite, faites le plein de nouveau l'installation du système d'exploitation, et le ré-enregistrement de la propriété.
Dans certains cas où le disque dur mot de passe est verrouillé, mai il ne peut être moyen d'être autorisé à annuler et re-faites une partition de faire une re-installer. Si tel est le cas, changer le disque dur fixe. L'ancien disque dur serait supprimé à moins que vous ne peut avoir son mot de passe.
Mot de passe BIOS niveau procédure:
Avec certains modèles d'ordinateurs, vous pouvez supprimer le BIOS batterie et attendez jusqu'à ce que le BIOS est épuisé. Ensuite, vous devez alors être en mesure d'avoir accès à re-configurer le BIOS. Vous aurez le choix de mettre en un nouveau mot de passe ou tout simplement ne pas le faire.
Si le matériel est libellée au passage à niveau le BIOS et ne pas épuiser la batterie avec le déménagement, vous aurez à envoyer l'ordinateur à la fabrication d'avoir un ordinateur sans littoral. Vous devrez payer les frais de livraison et les frais de service. Lors de l'envoi de l'ordinateur à la fabrication pour la déverrouiller, il vous sera demandé une preuve de propriété de l'ordinateur avec la preuve d'identification. Avec la plupart des sociétés informatiques, une copie de la facture d'achat, et une copie de votre permis de conduire ou carte de citoyenneté devrait être acceptable.
Jerry G.
Posted on Sep 13, 2008
raycolinashb
SOURCE: janome mermory craft 8000 drop feed dog
I hate to sound dismissive but: read the manual. Duh. It is not as written above: drop dog........
The feed dog is the toothed pieces in the sewing machine deck, under the needle, which move the material away from you when you push the operating pedal.
Dropping the dog - ie making it inoperative - (see manual for how to on your machine) means the material has to be propelled by hand under the needle. This is especially good for freehand machine embroidery as it means you can move the material in any direction whilst sewing.
It can be easier to freehand embroider if your material is fixed in to an embroidery hoop to hold it flat while you work.
Posted on Apr 24, 2009
  • 4889 Answers
SOURCE: Bonjour . S'il vous plait , donnez - moi le
Try code  0086
Posted on Nov 19, 2009
SOURCE: jai un probleme avec un copieur Gesttner 3220 . A
Gestetner 3220 is similar to ricoh brand
sc542 means your termistor had to be replaced with new one.
if you know the technique, switch off th copier,the open the lateral door,take out the fuser unit.
under or below it you will find 2 unit termistor with red
contact . Properly replaced both with new unit then reinsert the fuser unit in.
Switch on th copier,reset the machine to sp mode
to get into sp mode ,you have to push yellow[C] button follow by button 1,0,7 then push red button[cancel] for several sconds until the screen show sp mode.
When you in sp mode, switch off the machine,then wait for 1-2 min then switch on the copier, wa la it's working. You should try it and it save your cost.
Posted on Apr 16, 2010
SOURCE: bonjour, nous avons acheter un
Vous n'avez pas besoin du CD. Il a ?t? un programme de plan?tarium. Vous pouvez t?l?charger un programme plan?tarium gratuite sur:
www.stellarium.org
Clear skies!
Posted on Jan 07, 2011
Code couleur radio
bonjours a vous !
es ce que quelqu'un connait le code de couleur derriere le radio,ou un site ou je pourrais trouver ca ,car j'ai fait des recherche sans aucune reponse ,pi mon dealer ne peut pas me les fournir
merci
Sep 11, 2012 | 2001 Chrysler Concorde
Bonjour mes amis ofait j'ai un probleme avec mon blackberry 8520. ;j'ai besoin de connaitre mon MEP et et MEP2 si vous pouvez m'aider en ce moment je n'ai pas un autre phone pour dire
You have not menti0oned what is the problem with your Blackberry mobile. About the MEP andMEP2 codes, I dont know about MEP code. But MEP2 code is used to unlock mobiles. Hope you too know that. I know a good website to get the MEP2 code. You can check out ClassicUnlocking.com . You can select all the mobile information from the list of models provided and buy the code. Hope this will solve your problem of MEP2 code. Sorry i couldn't help you with MEP code.
May 20, 2012 | RIM BlackBerry Curve 8520 Smartphone
J'ai perdu mon cd d'instalation de mon impremente du marque panasonic kx-flb802 laser multi-function
Bonjour zohra_benmaz
selon la page de compatibilité de Windows 7 ce type d'imparimante est inclus dans les pilotes. Si par contre vous n'avez pas Windows 7 vous pouvez télécharger le logiciel de multi fonction ici http://panasonic.net/pcc/support/fax/usa/table/us_flb851.htm
J'espère que ce texte vous aaidé a régler votre problme S.V.P. n'oubliez pas de noter \voter pour toute solution qui vous a aidé a régler votre problème Si vous avez des questions laisez un commentaire Merci d'avoir utilisé le service Fixya.
Aug 09, 2011 | Panasonic KX-FLB801 All-In-One Laser...
Bonjour au depart c'etait un probleme d'alimentation du papier et quand j'ai nettoye l'imprimante j'ai trouve un crayon de couleur a l'interieur maintenant je veux relancer l'imprimante mais j'ai le...
Bonjour ipty2004
Je suppose que vous avez vérifié si le capot ou tout autre couvercle sont bien verrouillés .
Je crois que si vous désinstallez le logiciel / pilote et le réinstallez ensuite après un redémarrage de votre ordinateur , le problème ne se posera plus .
Cordialement ,
fanaudi .
Mar 28, 2011 | Lexmark X5470 All-In-One InkJet Printer
Bonjour Que faire manque une couleur ne fonctione pas et les couleurs ne sont pas net ? les cartouches sont origine ! urgent cordialement.
Bonjour ahlam_rifai
Si tu emploies des cartouches d origine et qu elles sont toutes d' un niveau d encre suffisant , c' est peut - etre unn probleme de logiciel / pilote .
Eteint l' imprimante et efface le programme dans le panneau de configuration \ programmes ( Win 7 ) . Fait redemarrer ton pc . Reinstalle le logociel / pilote . Allume l' imprimante et attends confirmation que l' installation a réussi .
Si ça ne marche toujours pas , il faudra sans doute nettoyer les tetes d' impression .
Cordialement ,
fanaudi .
Mar 14, 2011 | Brother MFC 490cw Color Inkjet...
Bonjour, nous avons acheter un téléscope de marque édu-science chez toys r us au canada. Il n,y avais pas le cd à l'intérieur pour le mode d'emploi. pouvons...
www.stellarium.org
Clear skies!
Jan 07, 2011 | Edu-Science Optics
Tout les codes de san andreas sur ps2
http://www.gtasanandreas.net/cheats/ps2.php
désolé, mon français est horrible.
J'espère que cela vous aide!
Jul 11, 2009 | Video Game Consoles & Games
EASYSHARE 5300 All-In-One
j aimerais si possible que vous me répondiez en français s.v.p
A la première installation , tout allait bien et les couleurs y étaient toute ...
par ignorance , dans la fenêtre Propriété de Document Kodak 5300 AIO
dans l'onglet général, à la question Mes Préférences . j'ai pris pris un des 2 choix et je me souviens pas quoi, et a partir de là , les couleurs on changé.
ce n'est pas grand chose, mais je ne comprends pas pourquoi
les couleurs n'ont pas d'éclat
le pire c'est la couleur rouge
c'est très décevant
C'est n'est pas la première imprimante que j'aie,
sur la page de démonstration , le lettrage est gris pâle , et le tour des yeux sur la photo des enfants est blanc.....
et lorsque que je lui demande un diagnostic il n'y a rien s'écrit sur la page
merci à l'avance ....
Lucie
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
23 people viewed this question
jasbo
jasbo
