Question about Indesit Washing Machines
How can I remove the front panel on an indesit pwe91672w
Indesit washing machine how do I open door sock stuck in door water leaking out
Look at the front of the machine, directly beneath the door lock is a cable, behind the front panel at kick panel level.
Mar 04, 2018 | Indesit Washing Machines
F05
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Indesit W 123 Front Load Washer
Need to replace carbon brushes on Indesit Omega 1200
The brushes are located inside the motor. Remove rear panel of washer, remove drive belt, from motor and drum, unplug the motor, undo screws that secure motor, and remove motor.
At the opposite end to the motor pulley, you will find the brushes located, undo 2 screws that secure the brushes, remove and replace brushes.
I would also check the pump filter, which should be located behind a removable panel at bottom of washer, unscrew anti-clockwise, remove and clean.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Indesit W 123 Front Load Washer
Getting to water pump
To gain access to the pump, remove lower plastic cover at front by prising down with a screwdriver, and remove same.
You will see the pump pre-chamber cover, unscrew it anticlockwise,and check for anything in there .
Refit cover and refit plastic panel.
Thanks.
Jan 31, 2009 | Indesit W 123 Front Load Washer
Indesit 123 not rotating
Mine did this today, but we fixed it. Just the belt had come off.
Disconnect from electric.
Remove back panel by removing 5 or 6 screws with a screwdriver.
Put belt back on.
Screw back panel on to machine again.
Sorted !
Dec 12, 2008 | Indesit W 123 Front Load Washer
It starts off ok but 5 mins in to the cycle (any cycle)all the lights start flashing and it just makes a sloshing noise but the drum is still.... .it an indesit wia111
Check the drain pump they haave a catch sleeve inside the drain line before the drain pump. Remove the lower front panel to access the pump and remove the large hose from the drum. Inside the hose is the sleeve, take out the sleeve and clean it.
Dec 11, 2008 | Indesit W 123 Front Load Washer
HI MY INDESIT 1063W WILL NOT SPIN PUMP KEEPS ON GOING DOOR LOCK NEW NO FILTER ON FRONT OF MACHINE
There should be a removable plastic panel at the bottom front of the m/c.
I f there is and you remove it, you should see the filter there.
Dec 03, 2008 | Indesit Washing Machines
Indesit wil 133
The filter is located behind a removable plastic panel on the bottom front of the m/c.
Apr 16, 2008 | Indesit WA 125 Front Load Washer
Wil133 indesit 1300 washer dryer
look for debris in the filter,
remove the bottom front panel ( 3 screws on bottom)
Unplug washer ,
open the large access filter screw on in center , be ready for excess water to spill on floor, clean filter and be sure the pump impellers spin freely.
Feb 25, 2008 | Indesit W 123 Front Load Washer
Filter on indesit washing machine
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Nov 30, 2007 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
