Question about Roper RGX4634KQ Gas Dryer
Dryer not heating up
Dyer heat up then shut off i believe it the cyliniod for gas valve replaced timer thought that was the problem
    President:
  • 1,136 Answers
Hi, If the dryer stops heating later in the cycle, it is most likely the coils on top of the gas valve. It is a very common issue with the gas dryer.
Here is how to change the coils
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Posted on Jul 21, 2009
Dyer no heat
Try and locate a gas valve it and you might want to try replacing the two control valves. there black with the wires going to them i Replace them on my dryer in there about 20 bucks 12_23_2013_12_12_21_am.jpg
Dec 21, 2013 | Dryers
Maytag atlantis gas dyer not heating
Can you look inside the door for your model number. I believe the problem is either a defective igniter or defective solenoid coils that open the gas valves=> 279834 Gas Valve Solenoid Set
4391996 Dryer-Igniter
Here is a Manual=> Atlantis_Neptune_Electric_and_Gas_Dryer_Service_Manual
I will be here if you have questions, Thanks Sea Breeze
Feb 28, 2013 | Dryers
Dyer heats up for about 1 minute then, no more heat.
Check the timer , the unit is shutting off when the timer is malfunctioning. If so replace the timer after trying to bypass to confirm that the gas supply is not cut off.
Aug 26, 2010 | Kenmore 74642 Gas Dryer
Kitckenaid dyer KGYe6778WH1 Dyer won't heat
This is most likely due to the coils on the gas valve, they can become unstable and cause the symptoms you are describing. The coil kit is part number 279834 and runs about $20.00. It is replaceable from the front and not too hard to do.
Side note: the '8' in your model number is actually a 'B'
Apr 22, 2010 | KitchenAid KGYS850LT Gas Dryer
Will not heat
Most common issue with gas dryer is either the ignitor, valve solonoid or high limit thermostat. The timer will not advance with no heat,
Oct 27, 2009 | Dryers
THE DRYER IS NOT GETTING HOT
Hi
Please check the following things that could stop a gas dryer from heating:- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 25, 2009 | Whirlpool GGW9250PL Gas Dryer
Amana gas dryer ALG331RAW timer does not work and no heat
HI, the timer is defective. the heating process can be affected if the timer isn't functioning correctly. replace this failed timer asap. this will fix the issue.
Jun 19, 2009 | Amana ALG331RAW Gas Dryer
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
Thanks
Vic
Jun 01, 2009 | Dryers
Heats up and then no heat again
You need a coil kit for the gas valve they will waeken over time and not open when they are energized
Jun 18, 2008 | Amana ALG331RAW Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
147 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
