Which button ejects dvd - Televison & Video
  • kakima Dec 24, 2016
    Hi Alan wright, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model device is the button attached to?
Cannot find eject button or what to use to eject DVD from bauhn atv-32hdc1n. Lost the manual first time to use DVD and now cannot get it out. Hope you can help
On page v of the manual (if you had one), under the heading "DVD Mode", the first item in the list is an up-arrow symbol, with "Press to eject the disc" next to it.
That's simple enough, IF you have a user guide. But if you don't, and you weren't familiar with standard symbology for these types of buttons, you would be stumped by the moronic design of the remote control.
The up-arrow button is on the top row of the Remote Control buttons, next to the red Standby button. It's a standard Eject symbol, but not only did they just assume you'd know that, they obfuscated the situation further by marking it as "TV/Radio". So if you weren't familiar with the symbology, you certainly wouldn't be looking for something marked TV/Radio to eject a DVD.
But there's another catch: The up-arrow/eject button will only work if your Source is set to DVD. If for any reason you switched away from the DVD before wanting to eject it, you would find that the Eject button no longer works. You have to switch back to Source = DVD, then press the eject button.
IMO, there is no excuse for a Remote Control design that can't be figured out without the manual.
Aug 28, 2013 | Televison & Video
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Where is the EJECT BUTTON on mytwo year old model # PP25L Dell Windows Vista laptop computer
If there is no physical eject button on your dvd drive, you can eject it with your operating system.
Go to My computer and right-click on your dvd drive. Your dvd drive should eject.
Mar 05, 2011 | Dell (0F146) Internal DVD Drive
How do I get the DVD player to eject a DVD? I seems to be not responding to the eject button.
First thing to try is to unplug it, (not just power off) then plug it in while holding the eject button.
Apr 03, 2010 | Samsung DVD-V4600 DVD Player/VCR
Where do I find the eject key to eject a cd from my Dell studio laptop?
There should be a button on the DVD/CD drive itself, just push that small button and the tray should eject.
If you can't fine the button double click on "Computer" or "My Computer" highlight the DVD/CD in the list, right click on the DVD/CD and select "eject" from the list.
The tray should now eject.
Regards.
Jan 11, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Eject lock
Get a paper clip and unbend it so you have a straight wire. Then look closely at the dvd tray and next to the eject button you will see a tiny hole. Push the paperclip wire into the hole and manually release the dvd tray.
Feb 09, 2009 | LG LFD790 System
Go Video DVD will not eject
this suggestion made on this forum worked great for me.
I don't care if it does sound silly.. smack the unit smartly over the eject tray when you press the eject button.
Dec 23, 2008 | GoVideo Go Video DVD/VCR Combo
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
Televison & Video Logo
Top Televison & Video Experts
