Whats error sc329 reccho mp 3500 - Office Equipment & Supplies
Aficio error sc329
I AM SURE THE ENTIRE MEMORY HAS BEEN FORMATTED.
PLEASE ENTER SP MODE AND ENTER SP 21039 AND 21094
AND THIS ERROR WILL NOT APPEAR AGAIN.
Jul 11, 2014 | Ricoh Aficio 450 Copier
I want to relocate my Ricoh Aficio MP 3300
disconnect the finisher reset it and then it will be a monster roll
Jan 05, 2014 | Ricoh SR 790 - Finisher - 1000 sheets -...
My probleme ricoh aficio mp 4500 sc 329
sc329 on the MP4500 is a laser pitch error. The most likely fix is either to have a technician initialize the laser beam pitch adjustments or examine the laser unit to make sure none of the harnesses are getting in the way of anything.
Aug 14, 2011 | Ricoh Aficio 450 Copier
Code 326 329
still sc329 error
Nov 26, 2010 | Ricoh Aficio 2035 Copier
SC329-00
HOPE YOU SPEAK ENGLISH the error is due to the laser unit malfunction..after memory clear usually..you need to press the yellow clear button then 107 then hold down the stop/cancel button for 5 secs till the screen changes.. then copier sp section 2 drum then look for laser pitch beam adjustment you need the 400dpi and 600dpi initialisation to be done.. this should clear it then turn off the machine and wait 10 secs and turn back on.. hope this helps ..Adios
Jul 14, 2010 | Ricoh Aficio 1035 Copier
ERROR CODE SC329 IN NASHUA AFICIO 3445
ca 107 c then inter the sp mode then clear error
Jan 14, 2010 | Ricoh Aficio 450 Copier
ERROR CODE SC329 IN AFICIO 450
Laser synchronization error
The main scan synchronization
detector board cannot detect the laser
synchronization signal for more than 5
consecutive 100 ms intervals
Lanier 5245 it has an error code SC329-00,
Did this happen after the machine was serviced? this is typically when it would occur...."LD pitch error"
Perform LD pitch adjustment with SP109-3, and SP109-4 (400dpi & 600dpi) or the ribbon cable on LD unit is blocking proper movement of the unit.
Apr 18, 2009 | Office Equipment & Supplies
Error code
Thats not good. Its a laser problem. You are probably going to need a service call.
Mar 09, 2008 | Ricoh Aficio AP410N Laser Printer
22 people viewed this question
k24674
jasbo
jasbo
