Question about Samsung Televison & Video
A samsung hlr 5678, had screen turn green hues and light flashing
A samsung hlr 5678, suddenly had its screen develop a blurry green and yellow hue raising from the top towards the top. then being overridden by a flashing lighter white picture.
the cable signal reception continues to play in the background. a pip picture tends to show a cleaner picture. other sources still show the flashing light hue shadow. air reception has same condition
  • 73 Answers
Replace the analog board
Posted on Jul 26, 2009
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
My background on my screen recently developed a purple hue to it, instead of a white. Can this be corrected?
This is likley a problem with the monitor's signal cable. Try moving the cable around steadily and see if the color suddenly goes back to normal or changes to a yellow hue. If this is the case and you are able to remove both ends of the cable then a replacement can easily be purchased from a local computer store or online. (Try www.amazon.com or www.monoprice.com).
Mar 17, 2011 | IBM ThinkVision L170 17" LCD Monitor
SONY KDF42A10 COLOR OFF
describe the yellow or green hue, is it eaven all over the screen or does it look like it is more noticeable on some portions of the screen. could be that you might need the light engine repair.
Jan 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Red screen on my sony kp-53s25,
That model is famous for bad green CRTs which can cause the screen to take on a red hue when the green cuts out that can also cause the set to get blurry also. Let me know if you need more assistance.
Jun 12, 2008 | Sony KP-53S65 53" Rear Projection...
Blurry picture
Did you accidentally turn on SVM? Make sure it's off. And make sure you haven't switched to a different picture mode by mistake.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
May 21, 2007 | Samsung TXN3275HF 32" TV
Televison & Video Logo
169 people viewed this question
Jerry Greenberg
Jerry Greenberg
