Question about Samsung Televison & Video
Which screws need to be removed to remove left hand rear panel on Samsung DMS500TMR
    Top Expert:
  • Samsung Master
  • 75,452 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Disassemble & reassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Posted on Dec 23, 2016
How do I remove the front panel etc. from a Maytag MDG6700AWW dryer. But not standard Maytag assembly.
This appears to be the Samsung made dryer built for Maytag. Remove the screws for the main top located in the rear left and right, the rest should be down hill from there. This model may have screws one left and one right under the bottom of the front panel too. Pleazer Appliance...
May 19, 2014 | Maytag Dryers
How to remove casing
To make sure there is a clear understanding here's a complete diagram
Overall Parts Diagram
To Remove the Outside Plastics on the HP Color LaserJet CP5220 Series Printer
1) Remove Right-front cover and control-panel assembly
a) Open the front door and the right door.
b) Remove two screws (callout 1).
c) Release 3 tabs (callout 1) on the right side of the assembly.
d) While holding the assembly up, pull the cable holder (callout1)
disconnect one connector (callout 2).
2) Remove Left cover
a) Remove Tray 2 from the product.
b) Open the front door.
c) Remove three screws (callout 1). Starting from the left side
tabs (callout 2),and then remove the cover from the product.
TIP: Opening the toner-collection door might make it easier to release the tabs on the left side of the cover.
Reinstallation TIP: If the front door will not close after the left cover has been reinstalled, verify that the two tabs on the right side of the cover have been aligned correctly with the product chassis.
3) Remove Rear cover
a) Remove six screws (callout 1), and then remove the cover
from the product.
4) Remove Toner collection unit access door
a) Open the toner collection unit access door (callout 1), remove the toner collection unit, and then release the link arm (callout 2) on the left side of the door. 18798043-wfiifre4chsxw5xgazxianfb-1-48.jpg
b) Partially close the door, and then disconnect the right-hand link arm (callout 1) from the door.
CAUTION: Do not disconnect the right-hand link arm when the door is completely open. Doing so can disconnect the link arm spring. 18798043-wfiifre4chsxw5xgazxianfb-1-63.jpg
c) Rotate the access door down 90 degrees, and then pull on the left side of the door to remove the access door.
5) Remove Right-rear cover
a) Remove the rear cover. See Rear cover on page 93.
b) Open the right-door assembly.
c) Remove two screws (callout 1), release one tab (callout 2),
and then remove the cover.
CAUTION: The grounding spring on the back of the cover falls off easily. Be careful not to lose it.
6) Remove Top cover
a) Remove four screws (callout 1).
b) Open the toner-collection door.
c) Release two tabs (callout 1), and then remove the cover.
7) To Reassemble Follow Instructions in Reverse
Jul 08, 2013 | HEWLETT-PACKARD Color LaserJet CP5225...
How to change the third break light bulb in a 2007 hyundai sonata ?
From 2006 to 2010, the Sonata's 3rd brake lamp requires the rear package deck be removed to access that bulb.
1. Remove the rear passenger seat bottom (remove two12mm bolts between the seat back and the seat bottom - tilt the seat back forward to locate these bolts).
a. Press the two bottom front edge tabs to release the front of the seat bottom from the floor.
b. Remove seat bottom & set aside w/two 12mm bolts
c. Tilt both seat backs downward
2. Remove the left & right hand shoulder cushions (12 mm bolt at the bottom of each cushion)
a. Remove seat belt from shoulder cushion guide at the top of the cushion
b. Lift up and forward on shoulder cushions to remove them (if equipped with side airbags, disconnect wire harness connector).
c. Set shoulder cushions aside w/two 12mm bolts
3. Using a small flathead screwdriver, pop out the 'SRS' button cover from the C pillar panels on the left & right hand side to access either the phillips head screws, 10mm bolts, or #30 Torque Screws
a. Remove screws and set aside
b. Using a standard flathead screwdriver, pop out the C pillar panels on both sides (clips hold these panels in place)
c. Set these panels aside after removal w/screws/bolts
4. Trunk Access-way panels are held in place by phillips head screws (two at the bottom (left and right hand sides) and 4 to 5 at the top .
a. Remove left and right hand panels and set aside w/screws.
5. Rear package deck held in place with two plastic clips (white, yellow or pink)
a. lie on your back inside the trunk (trunk lid open to allow for more light). Looking through access hole find 3rd brake light wire harness connector & disconnect.
b. locate package deck clips, one on the left and another on the right on the underside of the pckage deck
c. Squeeze clips to push them out - package deck will come loose
d. Remove package deck & remove 3rd brake lamp bulb socket (turn counter clockwise to remove). Replace bulb & reassemble in reverse order.
Sep 05, 2011 | Hyundai Sonata Cars & Trucks
I have a Maytag MDE4700A electric dryer. It quit working (turning) but still heated up. I took the cabinet apart and found that the belt was broke. Need some assistance on beginner steps for replacing...
Disconnect power to the dryer then open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening. Grasp the door with both hands and lift the door in the hinge area then draw the door assembly away from the dryer to disengage the hinges from the slots in the front shroud.
Remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Disconnect the wires from the door switch, sensor bar, and the lamp holder then unsnap the lamp holder wire harness from the front shroud wire retaining clip.
Remove the four perimeter screws holding the shroud and tumbler front assembly to the cabinet. Remove the lowest outside screw at each corner then the top screw on each side.
Pull the shroud and tumbler front assembly out and away from the tumbler while slightly lifting the top cover.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then grasp the idler puller with your left hand and pull the idler upward and to the left.
Slip the belt off the motor pulley and the back of the tumbler then pull the tumbler out of the cabinet while lifting the top cover.
Place the belt onto the outside of the tumbler and position it 1 1/2 inches in front of the rear baffle mounting screws with the ribbed side facing the tumbler.
Position the tumbler into the rear felt seal and resting it onto the rear rollers then lower the front of the tumbler onto the blower housing.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then locate the belt and create a small loop with your right hand, ensuring the belt is free of twist.
Position the open end of the loop onto the motor pulley with your right hand. Grasp the idler pulley with your left hand then pull the idler upward and to the left to clear the drive belt.
Relax your left hand and allow the idler pulley to rest down onto the belt. Grasp the baffles with both hands and rotate the tumbler clockwise for the belt to align itself.
Reinstall the shroud and tumbler front assembly in reverse of the removal steps. Lift the front inner edge of the tumbler to allow the front of the tumbler to rest on the teflon bearings on the shroud and tumbler front assembly. Check the felt seal to ensure that it is outside the lip of the tumbler.
Secure the top cover with the hold down brackets then push the front panel posts against the clips in the cabinet until it engage.
Insert the door hinge tabs into the slots in the front shroud and secure the hinges with the screws removed previously to complete the procedure.
Aug 22, 2010 | Dryers
Need to open the Dell Inspiron 530 in order to clean it
Facing the computer your left side is the left side of the computer.
Going around to the back of the computer, there are two screws to remove, so that you can slide the left panel off.
They are along the outside edge of the left panel, and on the backside of the computer.
One is located approximately 3 inches down from the top.
One is located approximately three inches up from the bottom.
In-between the two screws is a bulge. A formed place in the back edge of the left panel.
Once the two screws are removed, hold onto the computer with one hand, and place the fingers of your other hand into that 'bulge'.
Pull back to slide the panel towards the rear of the computer, then lift the panel up, and out.
This Dell Support, and the Owners Manual for the Inspiron 530 desktop computer,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In this main menu scroll down to Removing and Installing Parts, and click on it.
Now on Removing the Computer Cover
Feb 28, 2010 | Dell Computers & Internet
Heater core replacement
The instrument panel and steering column must be removed to remove the heater assembly. Two people are required to remove the assembly from the vehicle.
Disconnect negative battery cable. Disconnect positive battery cable and wait one minute for air bag diagnostic monitor to deplete the backup power supply.
Loosen main wiring connector bolt in the engine compartment at the left side of dash panel and separate connectors.
Remove radio antenna stanchion and disconnect cable from base of the radio antenna stanchion.
Remove both the right hand and left hand windshield side garnish mouldings.
Do not remove safety belt retaining bolts in next step.
Remove the screws retaining both the right and left front door scuff plates and remove the front door opening weather-strips from body flanges.
Remove the right and left cowl side trim panels.
Remove the steering column cover by removing the three screws along the bottom and pull on the cover to unsnap the three clips across the top of the instrument panel steering column cover.
Remove the ignition switch lock cylinder.
Remove the four screws retaining the steering column shrouds together and remove the steering column shrouds.
Install the ignition switch lock cylinder to prevent the steering wheel from turning.
Disconnect the wiring connectors at the turn signal and windshield wiper switch.
Remove the one screw and A/C evaporator register duct from under the steering column tube.
Disconnect the wiring connectors at the bottom of the steering column tube.
Remove the pinch bolt attaching the steering column tube to the steering column lower yoke and slightly spread the joint with a screwdriver.
While supporting the steering column tube, remove the four steering column tube retaining nuts.
Remove the interlock cable retaining screws and shift actuator cable fitting.
Carefully remove the steering column tube from the vehicle.
Loosen the main wiring connector bolt at the left side of the steering column opening and separate the connectors.
Disconnect the stoplight switch wiring connector. On the manual transmission, disconnect the clutch pedal position switch wiring connector.
Pull back the floor carpet as required on the left and right sides of the vehicle and disconnect the window regulator safety relay switch wiring, and the powertrain control module from the main wiring.
Open the glove compartment to the stop, unsnap the hydraulic lift from the right side.
Remove the three screws at the bottom retaining the glove compartment door hinge and glove compartment to the instrument panel.
Remove the glove compartment.
Reach through the glove compartment opening and disconnect the wiring and vacuum hoses/connector from the heater-A/C evaporator housing.
Disconnect the wiring connector from the speed control amplifier and bracket assembly.
Remove floor console panel:
Open the console panel glove compartment door to access screws to console finish panel.
Remove the two screws, and lift the rear of the console finish panel to unsnap retainers.
Reach under the console finish panel and disconnect wires to fog lamp and ride control switches (if equipped) and cigar lighter socket and retainer.
Lift the rear of the console finish panel and slide rearward to release the two front locating tabs, remove console finish panel.
With the console panel door open, remove the console glove compartment mat.
Remove the center screw from the console (rear of shifter) bin, then lift the bin from the console panel. Disconnect the luggage compartment door release switch and fuel filler door lock switch (if equipped).
Remove the two screws from the bottom of the console panel bin to floor pan.
Remove the two cups and screws. Remove the floor console panel.
Remove the two screws retaining the front of the floor console panel to the instrument panel. Disconnect the remaining wires (main jumper wire) and main wiring, then lift the console panel from the vehicle.Protect the instrument panel surface during next step.
Using a putty knife or similar tool, insert under the left or right corner of the instrument panel upper finish panel and pry up on the instrument panel upper finish panel to release one snap clip.
Unsnap the remaining four clips pulling up by hand, working toward the opposite side of the vehicle.
Remove the two nuts retaining the left side of the instrument panel to the cowl side.
Remove the two nuts and one bolt retaining the instrument panel to the console bracket.
Remove the nut attaching the right side of the instrument panel to cowl side.
The following steps require two people
Nov 16, 2009 | 1996 Ford Thunderbird LX
How do I access the color wheel on my Samsung HLP4663W?
Looking from the rear of the set, the color wheel is just to the left of the lamp, underneat an aluminum heat sink. You have to remove 7 screws to get to it.
May 12, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Can anyone give me step by step instructions on how to remove light engine from sony kdf60wf655 tv thanks
I have the same Sony TV and just replaced my bulb. I ordered the bulb from sony.com and the package included the allen wrench you will need and simple step by step instructions are also included. There are two hand tightened screws on the lower rear corners of your TB. Remove these screws by hand and remove the botton gray panel of the TV. You will see the light package in the bottom center. Remove the hand tightened screw and swing the metal holder away. The gray cover now will come off by pulling lightly on the bottom. This will expose the lamp. You will need the allen wrench supplied with the bulb to remove the allen screw on the left. Once removed, the plastic cage containing the bulb will slide straight out. Push the new bulb in and tighten the allen screw. Replace the gray cover and swing the hold back in place the hand tighten the screw that holds it in place. Replace the gray bottom panel and hand tighten the two screws on the lower rear corners. That's the whole deal.
Jan 17, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Oven fan zannusi zbf360x
Remove rear panel in back of oven, there you will see the fan,remove fan blade,usually left hand thread, and remove screws that hold fan, if they are not accessable from inside the oven then you will have to remove oven from housing, and remove rear outer panel to access fan screws and connections.
Remove fan and replace in reverse order.,don't forget the nut that holds the fan is a left hand thread.
Plz rate this solution.
Thanks.
Dec 14, 2008 | Zanussi ZBF360X Electric Single Oven
Televison & Video Logo
26 people viewed this question
Jerry Greenberg
Jerry Greenberg
