Question about Coffee Makers & Espresso Machines
I have a problem with the water tank float and my De Longhi Magnifica S Cappuccino, ECAM 22.360. They top of the float chamber has come loose and floats free when the tank if filled with water.
Is there an obvious way to fix it to prevent the magnetic float floating free of its chamber? Should I just glue it in place or buy a new tank? Thanks very much, Eric
    Top Expert:
  • Coffee Maker... Master
  • 52,135 Answers
Buy a new coffee maker .
Posted on Dec 23, 2016
Can I use vinegar to sanitize my coffeemaker ? By putting 50/50 with water in the water tank and starting the descaling-cleaning program.
vinegar can be used to descale but BLEACH will kill the mold better and diluted will not hurt the machine either
Mar 17, 2016 | De'Longhi Magnifica S ECAM 22.110.SB...
Bun cappuccino maker water over filling tank
float/fill valve may be leaking, municipal water is ******* many synthetics used for seals and shut off valves.
Another possibility is the float is taking in water.
Dec 19, 2011 | Coffee Makers & Espresso Machines
Every time I turn on my de'longhi magnifica coffee
Have to up the breaker at panel that controls that line of outlet circuits, but sometimes can not do this as wires in walls that control those outlets are on same circuit and rated at a curtain size breaker. Best and safest way to solve this is plug machine on different circuit that maybe not so many other items are sharing, like if your fridge or microwave is on that same circuit (breaker) it most likely will always trip. Let me know results if this solved problem, thanks Mr Bean Man
Jun 08, 2011 | DeLonghi Magnifica 3300 Espresso Machine
The Sensor Magnet for water tank does not float to the top
OK, first of all, I do not recommend my solution if you are forgetful or do not check your water level manually daily.
However, I found a super easy solution.
The way the unit works is to use a float in the water chamber with a magnet on the bottom. When their is enough water in the tank, the float rises and the magnet on the bottom floats to the top of the magnet chamber. When it floats up, it aligns with a sensor in the machine that allows the machine to operate. When the the water level lowers, so does the magnet and drops below the internal sensor disabling the machine with a "Fill Water Tank" error message.
To eliminate this error and allow the machine to operate, I simply popped off the lid to the magnet chamber with a butter knife and turned the water chamber up side down to let the magnet float fall out. Remember to empty the water first.
Here comes the highly technical part. Turn the magnet float upside down and slide it back into the float chamber. Since the actual magnet is on the bottom of the float it now is at the top allowing the internal sensor to turn off. No more error message!
The reason I do recommend this is because this completely defeats the purpose of the sensor and will most likely damage your machine if you run it without water. Keep you tank filled however and you will eliminate the frustration of a "float gone bad" keeping you from your morning caffeine.
Apr 08, 2009 | Saeco Incanto Classic Espresso Machine
Water container full but low indication on
I think the water level is read by a magnetic pick up driven by a black floater located 3/4 way towards the back of the water tank.
Make sure this floater can move up and down in its pocket: you can see it through the walls so just shake the tank to see it move, and check that it floats up when you fill water
Mar 30, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Water tank level indicator sinks to the bottom when water tank is full.
I think the float is up and down, try to take it out and turn it.
Look at the float in the other tank to see if it is same position, the rounded side should be down.
Let me know if you get it to work.
Best regards
/Mirran
Sep 04, 2008 | Saeco Royal Cappuccino Espresso Machine
Saeco Primea Cappuccino Touch Plus Coffee Maker fill water tank
The Primea do not have a float, it have a magnet and inside the machine there are a printed circuit card, this send a signal to the powerboard.
Jun 20, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Fill water tank warning stays on even when tank is full.
I've had this problem. Looks like its the float in the back corner of the water tank, which contains something magnetic that must trigger a sensor. I put a piece of plastic in the float chamber to push the float closer to the side of the tank. Be careful, if you jam the float (in the up position) then you may run out of water without any warning. Very annoying when you can't get your morning coffee.
Apr 09, 2008 | Saeco V-spresso Espresso Machine
Fill watertank
float valve stuck. try unplugging and then empty tank.check to see that nothing is visable in water reserve. fill water tank to full and then plug unit back in. hope this solves your problem
Nov 16, 2007 | Saeco Vienna De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
99 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
