Question about Exercise & Fitness
My roger black fitness is too tigh to use, even when the knob is turned onto 1
  • 6,694 Answers
If you wish to get some details About treadmill repair; check the site linked here. Pull up older posts.
Posted on Dec 23, 2016
Iwaant t know how to recharge a/c on 2012 ford escape
Get a recharge kit from an auto parts store. There'll be a rubber line in the kit with a T-handle or a knob on it that must be turned out until the can lid piercing pin is up and clear of placing it on the can. Mount/push this connection onto the can but don't turn the handle in yet. Find the 2 caps on the AC lines and remove the smaller cap. It's black like the one on your tire fill. Only one of the fittings will fit the line. One is too large. The smaller one is the fill line fitting. Attach the rubber line to this fitting, start the engine and now pierce the can with the T-handle/knob so the compressor will suck the Freon into the system until the can is empty. You can use my trick of placing the Freon can in a container of hot water to be sure it empties completely. Now check to see is your AC working. Normally only 1 can will suffice to get the AC working. Too much Freon is just as bad as not enough. Remove the rubber line from the system after screwing the T-handle/ knob back into the canister to close it. Put the cap back on the line and your done. Open the canister back up with the end in a wet rag in case there's a little Freon left in the can, and dispose of the canister properly. Hide the rubber line somewhere for later use. You can purchase the Freon canisters singly now.
Oct 17, 2014 | 2012 Ford Escape
Bandsaw blade
Dec 16, 2011 | Saws
Alternative replacement knob for lg #LRG30357ST, originals are plastic and all broken
Last time I bought replacement knobs (LG) from amazon. Take a look here Amazon com LRG30357ST knob. I hope this was helpful. cheers
Feb 05, 2011 | LG LRG30855ST Stainless Steel Gas Range
I have an stainless LG gas range and the knobs are loose and crinkled. LG will not replace them even though it is within the 1 year warranty period. They want to sell me a set for several hundred dollars....
I have the same problem. I have gone thru 2 sets of knobs for my LG Gas Stove. Even when I put JB Weld inside the knob to hold it together the knobs only last for 7-8 months of use. I am looking for a universal know with the same stem configuration to slip onto the shaft of the LG stove. It looks like a D
Jun 11, 2010 | LG LRG30855ST Stainless Steel Gas Range
I recently bought a house w/ a Marco gas fireplace. There is no owners manual and the company has gone out of business. I have never used a gas fireplace, so I have no experience w/ this. It has a direct...
Hi the key turns the gas on there is a arrow saying on /off turn to on .
remove front panel should lift up then down look for large metal plate should have lighting instrutions on them?
if not you will see a gas valve 1 maybe 2 black knobs look for the one with off pilot on , look for small knob red or black this the spark igniton , okay turn first knob to pilot and press in and hold in depress spark knob keep doing this untill pilotlights there might be air in the line so this might take time , when the pilot lights HOLD BUTTON IN STILL for 30 secs then release turn knob to on pilot should stay on if not do again , if stays on turn up thermosat if fitted or turn power on at switch you will have to find that will be near fireplace the other black knob turn sthe flame up and down hope this helps
Feb 09, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Let the expporte of carte mimory
put head set on the chuck,or get a set of jack cable one end fit to chuck make it tigh and other jack cable the red on amplipier w/ 500 watts power
and black one on video of your tv set.cheers
Apr 29, 2009 | Bosch 1/2" 6.5 Amp High Speed Drill With...
Hi. Mike here. Two "most likely" causes. (1) You simply have a leak at the lower right "cleanout trap". Remove the little white plastic "pull-out" assy. Check the black seal that looks like a little "tire". Is anything caught in it, or wrapped around it, or has it become deformed? Also, check that white plastic (2") washer, in front of it, is not warped (due to overtightening). Unscrew the "knob" (handle) part, all the way out, and separate all 4 parts. Clean knob, washer, tire (seal), and trap assy. Slip washer, then tire, onto knob's threaded "shaft". Flat side of washer goes against knob. Screw knob, washer and tire into trap assy, but only one or two turns. Then, slip entire assy back into machine's recess - and turn Clockwise to tighten. Only tighten hand tight (and I don't mean Macho tight!)
(2) If that doesn't fix, you may very well be using WAY too much detergent. These machines use only 2 or 3 (Max!) Tablespoons of HE liquid detergent. I've seen cases where folks were using 1/2 cup of liquid (or powder) and even more. That causes so much foaming that there have been overflows, from the lower right corner, even though nothing was wrong with the machine. To remedy, run a load empty, with NO detergent.
Good luck, and God bless.
Mar 06, 2009 | Malber WD1000 Front Load Washer/Dryer
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
