Question about Home Security
I cannot login to my multistar vision 24/7 dvr.
ANNKE DVR standard cctv cameras forgot my password cant view recording is there a way to reset the dvr
Good Morning,
Put here a photo of the front of the DVR, a photo of the login screen and a photo of the login page by the browser.
Sep 08, 2017 | The Home Security
Login Once the DVR boots, the [POWER] indicator will show constant red. The default factory password is blank. After the DVR boots, press the [MENU] key on the front panel or right click the mouse. Choose "Login" interface as shown below:
Pic 2.2 user login
Jul 29, 2017 | The Home Security
Sannce DVR-DH81NK1T i am lock out need code or password
Connect dvr to local network
boot up the dvr
connect to local network with a computer (eg Mac)
login into admin screen of your router to identify the assigned ip address of the router
start a terminal session
telnet to the ip address
default user name : root
default password : xc3511
mbaad@MBAADs-MacBook-Air:~$ telnet
Connected to
Escape character is '^]'.
YourCCTVDVR login: root
BusyBox v1.16.1 (2014-12-24 15:47:14 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
Welcome to Monitor Tech.
[root@YourCCTVDVR /]$ cd /
[root@YourCCTVDVR /]$ ls
bin etc linuxrc proc share usr
boot home mnt root slv var
dev lib opt sbin sys
[root@YourCCTVDVR /]$ cd mnt
[root@YourCCTVDVR /mnt]$ ls
custom dvs logo mtd usb web
[root@YourCCTVDVR /mnt]$ cd mtd
[root@YourCCTVDVR mtd]$ ls
Config Log
[root@YourCCTVDVR mtd]$ cd Config
[root@YourCCTVDVR Config]$ ls
Account1 StorageCfg network
HvrMode SysComs ppp
Json SysTime resolv.conf
RT2870STA.dat dhcp.cfg uboot_env_lang_video
There will be an Account## file for each account you have set up
Remove all of these files
[root@YourCCTVDVR Config]$ rm Account1
Reboot your dvr box and it is at the first setup screen
Here are the commands - note you can't send password as part of the telnet command
telnet 192.168.0.XX
cd /mnt/mtd/Config
rm Account*
CCTV Networking Technical Support
Apr 10, 2017 | Home Security
I have Lh126000 lorex dvr. After upgrade can't login in to dvr how to restore dvr without login
u need to conect it to internet. login signals canot pass thru walls
Sep 08, 2016 | Lorex Home Security
Why can't I login to my DVR web interface?
If you on are the same network as the DVR, you should be using the DVR's IP. Usually a 192.168......., depending on your service or router (COMCAST, AT&T etc...)
Aug 31, 2014 | Home Security
i have the same
ZEN TECH DVR 36584 V u can remove the battery and turn on the dvr but i cant log in i fogot the default password ....anyone rem it?
Aug 19, 2013 | Computers & Internet
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
I have forgotten the admin password of dvr (H.264) the motherboard serial is BS160 V1.01 20101009. how could i recover my system or change the password
Remove the top cover, remove the lithium battery, turn it on and check if the time is Mon 01-01-2001 00:00:00 Then enter this password: ecdGqv (respecting uppercase and lowercase). Message will appear with super login password, and the DVR will restart and return patterns of manufactures.
Jun 19, 2011 | FPS 4 Channel Standalone DVR system,...
How do iI hardware reset factory Multistar dvr h264 beacuse I forgute admin pass.
I forgate my multistar dvr password plz give me any solution
Jan 19, 2011 | Cameras
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Nov 05, 2010 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Home Security Logo
50 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
