Have 19 year old breezair harmony evap air cooler is dumping water even when not on
5 Suggested Answers
  • 659 Answers
SOURCE: just received sunpentown sf 616 evaporative air cooler
Sounds like you have a hole in the tubing somewhere within the unit. You will need to remove it and take it outdoors and start it up to trace where the water is coming from.
Posted on Apr 18, 2009
Ed Phillips
  • 11 Answers
SOURCE: air coming out of an adobeair portable evap cooler isnt cold
paula298,
A new unit will take a while for the pad to become wet and more efficient. Remember, there may be two switches: fan and water pump. The unit must be full of water and the pump ON to work correctly.
If the unit has a water pump only setting, run the pump without the fan for about 20 minutes. That will get the pads nice and wet and you should get a good result. A rule of thumb in the desert is 20 to 25 degrees of cooling compared to the ambient air.
Don't use a cooler in closed area. The cooler will simply act like a room humidifier. Use in an open garage or porch for the best result.
I hope that helps.
Ed Phillips ed@azalmanac.com
Posted on May 31, 2009
SOURCE: Breezair swamp cooler parts
Contact Convair cooler corporation.
Phone # 1- (602) 353-8066
Will send your parts out the same day.
Posted on Sep 03, 2010
WCISERVICE
  • 50 Answers
SOURCE: Have Breezaire WKE3000, unit runs
POSIBLE FREON LEAK
Posted on Aug 16, 2011
My breezair evaporative cooling system can not cool.the air flow is very worm,anyone can tell me this problem?
what is the weather like is it humid ?
Humid weather will render any evaporative cooler ineffective !
Have you got the windows and doors open to the building ?
Evaporative cooling relies on putting water in the air and pumping the air out of the building. If it is humid the air already contains water and no extra water is added to the air and no cooling occurs.
Jan 02, 2015 | Heating & Cooling
I have a breezair evaporative aircondioner. Ive turned the cooler off however the water has been leaking continually for several hours , even though ive switched the mains off . Sometimes ive often...
There is a water shut off valve connected to a float. The float may have a hole in it or the valve itself won't shut the water supply off before it overflows.
May 04, 2017 | Heating & Cooling
This unit is 15 years old and the drain tube was never hooked up believe it or not and it leaked terribly with now a rusted out bottom. The unit works however and I was wanting to fix it. Can a new...
IF YOUR UIT IS IN FACT 15 YEARS OLD IT CAN NOT BE A WKL MODEL, WKL ARE DIGITAL UNITS, WHAT YOU HAVE IS A WK4000 WITH A SCREW TEMPERATURE ADJUSTMENT IN BETWEEN THE GRILLS.
A 15 YEAR OLD WK 4000 IS AN R-22 SYSTEM AND NOT WORTH REPAIRING AND IF THE METAL IS RUSTED YOU CAN NOT BUY MORE METAL BASES FOR THAT UNIT FROM THE MANUFACTURER, BREEZAIRE HAS DROPPED ALMOST ALL THE COMPONENTS FOR THE UNIT ONLY THINGS AVAILABLE ARE FANS,COILS AND THERMOSTAT.
BUY THE REPLACEMENT WKL4000 DIGITAL SAME DIMENSIONS AND COOLING CAPACITY.
http://www.breezaire.com/wp-content/uploads/2011/04/WKL-Insrructions-3-11.pdf.pdf
CHECK THE LINK FOR THE INSTRUCTIONS ON THE NEW WKL UNITS
Sep 19, 2011 | Breezaire WKL 4000 Wine Cooler
WKL 3000 is creating excessive condensation and icing on the bottom of the unit. It is about 13 years old.
There will always be condensation. The problem may be that the drain that carries the water off is partially plugged.
Sep 20, 2010 | Breezaire WKL 4000 Wine Cooler
Unit runs gets only to 62 degrees. Top exhaust clean. 5 yrs old
CONTACT THE MANUFACTURER BREEZAIRE 858-566-7473 THEY WILL CONECT YOU WITH A DEALER THAT STILL MODIFIES UNIT TOP VENT.
BREEZAIRE DOES NOT MODIFY THE UNIT TOP VENT THEM SELF NOR DO THEY SELL DIRECT BUT THEY WILL PUT YOU IN CONTACT WITH THEIR DEALER THAT DOES.
Jun 06, 2010 | Breezaire WKCE 2200 Wine Cooler
Inside coils are getting iced up.
One or both coils (indoor and outdoor) are dirty or plugged. Take the unit to a reputable repair shop and have it cleaned and oiled. This should be done at least once a year anyway.
It's possible that it might have a leak. The shop that cleans it can check it for you after they clean it. If this is an old unit, it probably wouldn't hurt to have that done.
Jul 08, 2009 | Breezaire WKL 4000 Wine Cooler
Jun 28, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
