Question about Car Audio & Video
Ihave akurio10s when I try to turn on the screen is dark and the screen says KD INTERACTIVE why wont it turn on
I forgot the password to my Kurio interactive. How do I reset it?
Password Was Forgotten ΒΆ If you forget your Kurio log-in password, you will not be able to get past the lock screen. The only solution is to perform a factory reset. Performing a factory reset will erase everything on the Kurio and return it to exactly how it was when you took it out of the box. To perform a factory reset, unplug the Kurio and turn it off by holding the power button for 5 seconds until the screen displays "Power Off, Shutting Down..." Once the device is off, press and hold the volume down button and power button at the same time until the screen lights up with "KD Interactive." Release the power button, but continue to hold the volume down button until the "DROIDBOOT" screen appears. Then, navigate to the "RECOVERY" option and select it by pressing the power button. This will prompt a new menu, from here select "Wipe Data / Factory Reset." Your Kurio will go through a long restart phase and then welcome you to your new Kurio
Jan 13, 2017 | Tablets & eReaders
How do I reset a kurio 4s please somebody help me
Dec 09, 2017 | Tablets & eReaders
How do i fix my kurio 7s it is stuck on the KD interactive screen?
You might try asking your question at a fan forum related to your device such as this one:
Jul 26, 2014 | Kurio 7S Tablet
MY SAMSUNG TV WHEN I TUTN IT ON HALF LEFT SIDE TURNS DARK AND NOT AS BRITE IS THE RIGHT ONE . IHAVE TO WAIT 30-40 MINUTES BEFORE THE FULL SCREEN COME TO REGULAR STATE.
try reconnecting the Tcon connections that have the plastic lock bar often they develope connection issues and often unlocking them reseating the ribbon cables then locking them down again solves the issues quite often
Jun 01, 2012 | Samsung Televison & Video
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
I'm trying to improve the picture- seems to be TOO DARK- tv is 10 yr old ser3 935351541- ihave tried color adj etc
Rca Screen Control These sets have screen control adjustment usually located behind the speaker grill(pops off -velcro or press tabs) and convergence front board. There are 6 contols on a black molded assembly about 31/2"x21/2" square. adjust only the top controls marked "Screen R G B" the bottom ones are focus
Method:
-turn on set and let warm up for 30 min at least
-switch tv to blank unused video input channel
-adjust each control in turn until you see the picture glow (with the corresponding color) and slightly back off the control - repeat for each color - this will increase screen brightness and ballance your color
Hope this helped.
Oct 18, 2009 | RCA P52945 52" Rear Projection Television
Turn LAPTOP ON
push the screen to you and push it away so far as he can.
you hear a click the screen is fixed
May 14, 2008 | HP OmniBook XE3 Notebook
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
