Question about Whirlpool Washing Machines
My whirlpool front load washer will not spin out. its showinf error code F25
  • 57 Answers
According to the tech sheet, F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel- remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch. Since there a various reasons for your problem, I just can suggest starting point since there is a code displayed.
Posted on Dec 28, 2016
Whirlpool model #WFC7500VW1 F25 Failure Code: won't go into high spin. Motor reaches max speed fine in diagnostics.
Please check your model number. Whirlpool has no models that start with WFC7500V0. There is a WFC7500VW1 front load washer. The F25 error indicates a problem with the drum motor tachometer. (The motor rotation speed reported to the main control isn't appropriate for the cycle.) This can happen if the shipping bolts aren't removed.
If the washer is ready to be used, then you need to unplug the washer before continuing the diagnostics. Remove any clothes from the tub first. Check that the wires between the motor control unit and the central control board are seated properly. Make sure that none of the wires in the wiring harness are broken or have corrosion at the connectors. Replace the wiring harness if it is damaged. If the wires are good, plug the washer back in. Check the resistance at the tachometer and motor. Replace any failed part. Check if the drum spins properly when you spin it by hand and when the motor is powered. If the motor is spinning at the appropriate speed, replace the motor control unit. If the drum won't spin easily when you push it by hand, replace the bearings.
Some of the parts for the WFC7500VW1 are available here: http://www.appliancepartspros.com/parts-for-whirlpool-wfc7500vw1.html .
I hope this helps.
Jul 29, 2016 | Whirlpool Washing Machines
F25 error whirlpool WFC7500VW washer machine
F25 DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
Possible Causes/Procedure
Verify the shipping system including shipping bolts, spacers and the power cord are removed.
Unplug washer or disconnect power.
Check drive motor tachometer resistance.
It should be approx. 115 ?.
Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
Plug in washer or reconnect power.
Check the MCU by looking for operations of the drive motor.
Check the drive motor for powered rotations.
attachment.php?attachmentid=24900&d=1445218637&thumb=1 Front load washer drive motor with pulley
Tach/sensor is built into the end of the motor.
Appliance Repair Forums
Mar 24, 2016 | Whirlpool Washing Machines
Hi Have a WEC7500VW whirlpool front load washer shows a F25 code . Looked at the tech sheet in washer does not show that code what is it? Also washer will not spin out on high at end of cycle. Did the...
Not sure what you mean but if the washer doesn't spin then it's probably the switch that controls the spin action.
On most washers, when you open the lid or door the spin cycle stops for safety's sake. In many cases, there is a small extension on the door or lid that engages the switch when you close it. Look where the extension is supposed to engage and that's the switch. I was able to fix my broken switch on my GE washer by cutting the edge of the plastic on a pen and gluing it to the extension so it pushed the switch mechanism down further to start the spin cycle.
Hopes this helps.
Paul
Sep 29, 2014 | Washing Machines
I have a F25 code pop up and it will not spin
If this is the washer and not the dryer then error code:
F25 = DRIVE MOTOR TACHOMETER ERROR
This is a major error you can try some of the items listed below?
after 3 minutes.
1. Verify the shipping system including shipping bolts, spacers and
cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and the Motor
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer drum won't rotate, can't rotate manually
How are ya? This is kind of technical information that i'm about to give you, so if you're not that technical then you should call a service technician to diagnose. Good luck and thanks for the inquiry :)
F25
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Aug 08, 2009 | Whirlpool WFW9200S Front Load Washer
Fault code F25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
I got this working for many on this site :)
Thanks
Fame !
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F25 error code
this is scary. I got a brand new whirlpool duet sport I ordered from Costco.com. After 19 days of waiting for delivery it finally arrived and was installed by the whirlpool dlvy people. I read the instructions and started my 1st load within an hour of being installed. It never worked. Ok it work 6 mins and stopped on every cycle I put it on and then I got the error code 25. I called their customer svc number and they could not even tell me via the phone what that meant. I am suppose to have another delivered here HOPEFULLY next week but after seeing others having repeated problems I do not know if I should just say no take it all back.
Jan 27, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
