Question about Karcher Garden
Karcher HDS 745 boiler not igniting - Karcher Garden
5 Suggested Answers
SOURCE: karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Did you check if the igniters? they may be cloged up with ****. Unscrew the Sight glass on top of the boiler and run the machine (in cold or hot mode, doesn't matter, as the igniters are running all the time) and see if there are working, you should take them out anyway and give them a wipe with a rag as general maintenance item, and when you put them back in there should be about 5mm gap between them.
Less common reasons for the boiler to not work
- Faulty fuel solenoid valve, (You should hear a click sound about 5 - 10 seconds after you pull the trigger)
- Dirty fuel filter,
Take a look at those simple things and let me know if its any of these.
I have a Karcher HDS 750 1989 Year model
This machine just keeps going, it's had a fairly tough life but it has stood up to it all,
i hadent spent anything on it until about 6 months ago when i purchased a new fuel pump for it as the old was wasn't pushing 170PSI to the Disiel injector it had slowly droped 70psi, and it doesn't create a hotter burn in the boiler, but still very good for a 19yr old pump,
other than that thats all it's needed, it's still going strong to date
Very robust machine.
my e-mail is cgodfx@internode.on.net
Cheers Matt.
Posted on Nov 07, 2008
SOURCE: KARCHER HDS 1000 de
hi jim i have the same unit diesel burner and diesel engine have you tryed a new accelorater cable?
Posted on Jan 08, 2009
  • 33 Answers
SOURCE: my karcher hds 745 has started blowing fuses. it
you have an electrical short in the motor windings. you'll have to either replace the motor or buy another washer. also check to see if the motor isn't locked up with a piece of trash. to do that you'll have to dissassemble housing until you get to the motor. it should turn easily by hand. if so you have a short.
Posted on Apr 21, 2009
  • 92 Answers
Dear dumbelldaveb,
Having a 13A fuse I am concluding that the machine is single phase. Most probably you have a faulty capacitor. Check the capacitor and if you find it expanded and leaking...then you must change it with a new one. If you see the capacitor is normal just the same it could be shorted. So change the capacitor with a new one and try to start the machine WITHOUT LOAD. Which means no water inlet and no gun attached. Doing this you can also remove temporarly the micro switches. If the motor still hums, then most probably there is a fault in the electric motor.
Now if you find out that the fault is the capacitor (which in my opinion it is the case)...you must see why the capacitor broke. If when using the machine and the gun is closed, the machine starts on and off on its own,...this will damage the capacitor. This on and off fault could come from a leaking gun. Or a leak from the seals. Whatever....the machine must not be left going ON and Off when the gun is closed. This ON and OFF could be due to faulty micro switches and control valves.
I am very sorry to mention a lot of things, but I hope as in many cases,..the changing of the capacitor will solve the problem. I wish to add that the electrical lead wire must be checked. On many occasions I found that the electrical lead wire from the plug to the machine was damaged and shorted, ..due to pulling, wear and tear.
Regards,
Fulltech.
Posted on Apr 22, 2009
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
May 01, 2016 | Karcher Garden
Why is my HDS 745 hunting
Please define hunting?
Sep 24, 2014 | Karcher Garden
Karcher HDS 7/10-4M has the oil light giving 4 flashes, what does this indicate as the fault.
Ive got a brand new HDS 10/20 and its crapped out on me already, water line filters were blocked, cleaned them out and now it splutters after 2mins of pressure washing, oil light flashing x3, nothing in any of their **** manuals to assist, any ideas before i set it on fire?
Jan 19, 2013 | Karcher Garden
Karcher HDS 601 C Burner not ignited
hi i have a archer has 601 with problems. the boilers not igniting properly and I'm getting a roaring noise and thick white smoke. the fuel sides working fine iv changed the igniter and the coil still the same works when it wants to. any ideas thanks
May 20, 2012 | Karcher Garden
My karcher hds 745 has started blowing fuses. it switches on the power light comes on and it makes a buzzing noise for about five seconds and then blows the mains 13amp fuse. i have replaced it twice but...
Dear dumbelldaveb,
Regards,
Fulltech.
Apr 19, 2009 | Karcher Garden
Apr 19, 2009 | Karcher 2500 PSI Pressure Washer
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Cheers Matt.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
121 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
