Question about Sewing Machines
To increase the stitching size. still very low on its maximum
Stitching size is upto 40 max. but in my machine its still on a very low stitching size. how to enhance little more. is there any other technique to do that. Thanks
  • Sewing Machines Master
  • 11,524 Answers
Possibly the feed dogs are not moving like they should. If it is an older mechanical machine, the old oil may be turning to glue and preventing them from moving like they should. Otherwise, perhaps there is a gear or belt that is not working like it should.
Posted on Dec 23, 2016
Singer 29k71 stitch length on the longest still not enough about 2 mm..! What can be done..!?
If that is the maximum stitch length and you do not have a basting stitch, then you can't make a larger stitch. You could try free motion stitching where you drop the feed dogs, use a darning foot and manually move the fabric, but getting the stitches even would be quite difficult.
Aug 15, 2017 | Singer Sewing Machines
I am knitting an afghan with Taku mi 13 needles.
are you working a pattern or is it a straight stitch like garter or stockinette?
I would make a stitch gauge sample with the smaller needles to see how many stitches per inch.
Figure out how many stitches you will need to match the width of the current piece.
Take that number and subtract the number of stitches you currently have with the size 13 needles. (new stitch count - original stitch count = difference)
Divide the original number of stitches by the difference.
that is how many stitches I would do between increases
Let me use an example:
Say your original work had 75 stitches
From the gauge sample you know you need 100 stitches to make the same width
Now divide 75 by 25=3
Ffter every third stitch, I would put in an increase
that way the increases should work evenly across your piece.
This will be more challenging if you are working a pattern but the goal is to work the increases in as evenly as possible with as little impact as possible on the pattern being knitted. That might mean doing 2 increases every 6 stitches because it fits the pattern better.
good luck.
Oct 05, 2014 | Sewing Machines
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
Where can i get a manual for the janome760 platnium
About Janome Jem Platinum 760...
3/4 Size Computerized Sewing Machine
Horizontal Full Rotary Hook
Free Arm/Flat Bed Convertible
Skeleton Body Construction
Fold Down Carrying Handle
Machine Size: W 354 x H 255 x D 164 mm
Machine Weight: 12 lb
Machine Speed: 650 spm
Number of Stitches: 60 Stitches including 5 Buttonhole
1-Step Buttonhole
Stretch Stitch Adjustment
Maximum Zigzag Width: 5 mm
Maximum Stitch Length: 4 mm
Manual Thread Tension Control
Speed Control Slider
Needle Up/Down
Lever Drop Feed Dog
Declutch Bobbin Winder
Snap (clip) Presser foot
Built-in Needle Threader
Thread Cutter
Thread Take Up Lever (****)
Horizontal Spool
Try looking clicking in the previous links, we have in our database this Instrucion Book; hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jan 09, 2012 | Janome Sewing Machines
Bernina Arista 730 Check hook system - This won't sew correctly and is frustrating as I just used the system last night to do embroidery.
The 730 rotary hook is a bit sensitive to adjustment and cleaning. Make sure that the hook is clean and if you haven't oiled it for a while, give it a drop of oil (do you know where to put it ... many dont !) Check your needle is OK and, again, if used for a while, just put a new one in anyway. Load-up with different colours of the same type of thread top and bottom and sew-off a sequence of zig-zag, starting with the default and increasing the width and reducing the length until you get to a maximum width satin-stitch (dont increase the bobbin or top tension as you do it). Once you've done that, let me know what it looks like. The colours should be equal top and bottom, but maybe just a bit of top coming through to the underside on max width satin stitch. You'd also be advised to sew-off using pattern number 437 and the figure '9' - this will check the balance of the machine. If the '9' is not perfect, or the top section of the pattern 437 is not dead-central on the top of the triangular part of the pattern, the balance may need adjustment. Let me know how you get on.
Oct 16, 2011 | Bernina Sewing Machines
Can't adjust the tension on old singer!
increase top thread tension slowly till u get similar stitches on both sides
Nov 03, 2009 | Singer Sewing Machines
Broken needle sewing through Corderoy
This machine should be able to sew 9 layers with no real problems but it may be necessary to use a bridge or hump jumper to go over the big hump. Set your stitch length to almost the maximum and sew slowly(one stitch at a time). If it buzzes just turn it off, shorten the stitch length and try again. The above applies if you are using regular thread. If you are using heavy thread, you will need to use a top stitching needle size 18.( It has a larger eye)and adjust your tension as high as it will go to remove the loops on the bottom.
Dec 02, 2008 | Singer 7466 Mechanical Sewing Machine
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
