Hi we purchase a telefunken 55 HD LED model TLEDD 55FHDA and cannot pick up signal on the HDMI mode. Its connected with an eye to our pvr. In other room
  • 1894 Answers
SOURCE: Illegal Signal DVI/RB 3
see this link...here is the user manual....
Posted on Mar 01, 2008
ginko
  • 19396 Answers
SOURCE: Samsung 40" lcd - Connecting to PC saying 'MODE NOT SUPPORTED'
First of all, check that the TV is set on PC input when you use PC video input at the back.
Then you may also need to go to video and display properties>>settings, from control panel (personalize on Vista).
There lower down resolution and ensure that frequency is set the same as tv.
Posted on Jan 02, 2009
rockitman187
  • 2559 Answers
SOURCE: No HDMI signal
The Dvd player is not sending a High Definition signal,You may be able to change the output to high definition.
Please rate this a fixya
Posted on Feb 01, 2009
SOURCE: Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
Posted on Mar 16, 2009
  • 10 Answers
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
Screen flickers on and off
If all your other HDMI inputs are out, then I recommend replacing the MAIN PCB
try the following web site: https://www.encompassparts.com/model/ZEN55UB9500UA/_/_/LG/55UB9500UA/55_INCH_UHD_4K_SMART_3D_LED_TV_W_WEBOS
page 4 lists a part number for the MAIN PCB,
HOWEVER, PLEASE MAKE SURE YOU USE YOUR COMPLETE MODEL NUMBER TO ASSURE THE CORRECT PART.
Apr 06, 2015 | LG 55UB9500 55" 4K Ultra HD TV with 2160p,...
Just purchased Asus VE248H monitor. Used a 10 pin connector and was happy, but wanted more. Hooked monitor to pc with an HDMI cable, got HDMI - NO SIGNAL. Screen went dark. Disconnected HDMI, reconnected...
Hi , just access the monitor on-screen display (OSD) menu and ensure Monitor input mode is configured for HDMI ( Asus speak the " desired input source" ) - Input select is accessed under tv with arrow icon : change from vga to hdmi
Mar 03, 2015 | ASUS Ve248h 24-inch Led Monitor
No sound from AV receiver, sound only from TV
What brand/model is the receiver. Some have a function where you can select if the audio is passed through to the tv, or output from the receiver's speaker jacks.
Jul 14, 2013 | Televison & Video
Sony KV-32FS13 TV no signal hdmi
Is ur tv a CRT tube type of a analouge tv u are asking?Yes than the tv don't have HDMI inputs hubs for HDMI cables connections.Only some projection tvs,all plasma,LCD and LED tvs have HDMI inputs hubs only and able give ur tv incomming signals HD 1080i for a broadcasting and HD pictures or throught a HD boxes or games devices like Xbox or Playstation 3 devices to get HD output picture for like 1080p.
Jul 12, 2012 | Sony KV-32FS13 TV
Hi, I have recently purchased an SR7005 which is connected to an HD PVR via Audioquest Cinammon HDMI cable. While watching programs, I lose audio immediately after an advertisement break. If I pause...
If you are watching adverts that implies a broadcast TV sound signal. What happens is that the broadcaster will switch off sound especially Dolby signals during add breaks. Therefore it could be your TV that stops sending the sound to the Marantz. So check the sound settings of you TV. It might have an auto feature that detects the signals, that could be switched to manual or just a wrong sound signal that causes the problem.
Jun 12, 2017 | Marantz SR7005 Receiver
Connecting PVR and satellite receiver
make sure you have a connection from one of your scart sockets (assuming you are using scart) on your sat to your pvr and then a connection (scart/hdmi?) to your tv from the pvr.
if you have a second scart or better still hdmi on your sat then plug that into tv
set top box scart output to tv
you do not say which tv model number you have so I dont know what input sockets you have but I will assume a couple of scart inputs and maybe a hdmi in (if hd version of tv) these days that would be considered a minimum amout of inputs so the setup suggestion above should be fine with that
Jul 22, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Hdmi
Its not designed to play HD DVDs, the model has HDMI connection in order to connect to latest output devices, viz flats panels and LCD tvs there by having a common audio and video cable. your model has a feature to upscale the normal DVD singal to match the quality output of hull HD TVs, hence the HDMI out put, do not confuse this with HD compatiability.
Go to the link below to check the full specs of your system.
http://www.consumer.philips.com/consumer/en/in/consumer/cc/_productid_HTS9800W_55_IN_CONSUMER/DVD-SACD-Home-Theater-System+HTS9800W-55
though yours is a high end set, but its not HD disc compatiable.
Regards
Benam
Nov 14, 2007 | Philips Cineos HTS9800W System
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
