Question about Miscellaneous
How to fix a Nona Digital-Decorating instant light show. Reset button will not push in did it popout, hard to tell. O.L. Is the only display.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Sounds like the switch has popped out of it's housing. Try to reseat it after cleaning around the area. If that doesn't work, try unscrewing the housing (usually at least 4 phillips screws) and pop the switch back in that way. Of course I don't have to tell you to make sure it's unplugged before you operate on it. Good luck!
Posted on Feb 03, 2017
How do I fix a Roland Digital Piano FP-8 that has refused to play sounds despite the fact that it displays lights?
If everything lights up and responds to button pushes like normal, and you've done a hard reset as described in the manual, check to see if you have sound out of the headphone jack. It's most likely not a user serviceable problem and will need to go to the shop, but it will probably be the output amp rather than the main board.
Mar 07, 2015 | Roland Fp-8 Digital Piano Email Us For A...
False empty toner reading
The problem can be may this however hard resetting it can fix the issue
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Jul 12, 2008 | OKI C5500n Printer
I have a Noma Digital Decorating Instant Light Show Timer and I cannot find the instruction sheet on how to use it. It has 19 preprogrammed light shows and the display shows OL and will not let me reset...
the manual says each unit has a maximum load of 3 amps (abt 7 one hundred mini light sets). when ANY INDIVIDUAL outlet is overloaded,ALL lights will turn off and an outlet overload message (OL) will be displayed. To reset,unplug unit,then unplug some of the lights in the outlet that appears to be overloaded and plug unit back in
Dec 02, 2011 | Hardware & Accessories
The wall timer to my outside lights says "noop"
noop means no operation.
This usually shows on older timer.
You posted under Intermatic ST01C.
Other have written to fixya with same symptoms.
CR2 battery might be bad. Replace battery.
Replace battery quickly and current time remains in memory.
Battery out of timer longer than 30 seconds, then current time and day disappear.
Programming remains inside timer forever with or without battery until timer is reset.
Others report they changed battery and timer never came back to life afterward.
http://waterheatertimer.org/ST01C-program.html#battery
Manual troubleshoot section also suggests resetting timer, and then re-programming.
Manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
To reset timer, hold down ON-OFF button and push small round reset button with paper clip.
Push reset for 3 seconds and release.
Keep holding down ON-OFF until INIT shows on display.
Release ON-OFF and wait for display to show.
If display never shows, then battery is dead or timer is bad.
ST01C comes with 1 year limited warranty.
Advantage of Intermatic battery operated timer is simple wiring, plus astronomic function (dawn-dusk).
All in-wall timers have advantages and disadvantages.
Nextag shows new ST01C sellers
http://www.nextag.com/intermatic-st01c/products-html?nxtg=90ff0a280507-C4F7FB4C58223A3F
Page also shows Intermatic EI600 astronomic timer that comes with 5 year limited warranty
Nov 29, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Lexus RX330 - "Maintence Required Light" flashes 7 times?
reset: turn ignition on...push odometer button till it displays mileage on car...not trip milage but actual mileage. Turn car off. Open driver's door, press and hold odometer button....turn ignition to on....hold odometer button for 10 seconds....odometer display will show -----,----,---,--,-,0000000....maintenance lights are reset...lights will come on every 7500 miles to remind you to change oil and check fluids etec....
May 15, 2009 | 2005 Lexus RX330
Intermatic hb65r residual outdoor timer
Here is the instruction manual for your model:
HB65R Timer
Hope this helps!
Also consult this website for sunrise, sunset information for your area:
Sunrise sunset calendar
Dec 05, 2008 | Hardware & Accessories
Unlock problem
Do a hard reset. To do a hard reset hold down the red and green buttons on the front of the phone and push the reset button on the bottom of the phone at the same time with the stylus. This just fixed my problem
Sep 18, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Sharp LC-37HV4U
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Dec 28, 2017 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Microwave display window shows locked!!!!
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
There may be grease or soot on the control panel causing a lockup, and it may need circuit board cleaning / repair or a new keypad.
Sep 01, 2008 | Microwave Ovens
Sony Bean 1gb "Format Error"
I have the solution. Push the menu button (the one ne with the file folder) until "search" is displayed. push the down arrow key on the jog button,10 times, until "advanced menu" is displayed. Pushe the right button on the jog until "format" is displayed. Use the jog buttons until "format ok" is displayed. Then push the play button and the problem is sorted. Good luck.
Apr 28, 2008 | Sony Walkman Bean NW-E305 MP3 Player
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
