Como puedro. Programar. Mi. Tv santo. Con. Un. Control. Dish
    Top Expert:
  • Televison & ... Master
  • 73,647 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. ..
Posted on Dec 23, 2016
  • 8 Answers
SOURCE: como programar un control remoto Gemini Quik30 para un TV RCA
diplodocs.com
Posted on Feb 11, 2009
mayradiaz
  • 19 Answers
SOURCE: como programar un control de dish
Hola, mi nombre es Mayra Diaz con DISH Nerwork. Primero q todo muchas disculpas por los problemas que le a causado nuestro equipo. Porfavor si me puede dar el numero de su recividor de DISH Network. Para poder darle la instrucsiones correctas en como programar su control. Gracias que tenga un buen dia.
Posted on Jan 08, 2011
mayradiaz
  • 19 Answers
SOURCE: Como puedo programar mi control
Hola mi nombre es Mayra Diaz con DISH Network. Con mucho gusto le puedo asistir programando su control a su televisor APEX. Lo primero que vamos a verificar es que su control tenga bater?as nuevas. Vamos a presionar el bot?n de TV es color blanco o cristalino, lo va a presionar hasta que las cuatro luces se prendan. Suelta el bot?n de tv y presiona 745, 743, 020, 731 siguiendo por el signo de numero localizado de abajo del n?mero nueve. Finalmente, trate su volumen. Recuerde presionar su bot?n de SAT para poder seguir usando las funciones de su sat?lite
Posted on Jan 21, 2011
  • 55 Answers
SOURCE: como programar un control de dish a una tele
Depende del modelo del control remoto. Pero en general:
Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
Use the number pad buttons to enter the three-digit number corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works, try several functions for that equipment.
Panasonic TV: 508, 509, 510, 511, 512, 566, 574, 575, 628, 644, 651, 662, 663, 668, 672, 673, 676, 685, 687, 689, 698, 697, 700, 706, 714, 716, 234, 247
Panasonic: 008, 009, 010, 011, 012, 066, 074, 075
Posted on Mar 05, 2011
kimberlyesco
  • 184 Answers
    Verified Fixya Pro
    SOURCE: como programar tv vizio a control dish
    Estimado Chuy, primeramente le quiero pedir una disculpa por responderle tan tarde, estoy consiente que en este momento posiblemente su control ya este programado a su televisor. De cualquier manera quiero tomar el tiempo para proveerle los pasos y codigos a programar el control, puede ser que en un futuro los necesite. Para programar su control ala t.v hay ciertos codigos que permiten que el control se programe a las funciones de la t.v. Los codigos para una t.v Vizio son 627, 505 y 506 Oprima el boton transparente de T.V localizado en la parte de arriba del control por 5 segundos hasta que los demas botones se iluminen en rojo, una vez se iluminen ingrese un codigo seguido por el signo de numero por ejemplo: 627#, luego el boton de 'Record' 3 veces (es el boton ***** con un punto rojo) una vez haga esto vera que el boton de t.v se iluminara 3 veces. Esto debera programar el control a su t.v. Si necesita ayuda puede contactarme directamente a kimberly.escobar@dish.com. Gracias por su tiempo.
    Posted on Mar 15, 2012
    Como puedo programar una tv samsung con el control de dish
    Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a kimberly.escobar@dishnetwork.com
    Kimberly Escobar
    DISH Network
    Aug 07, 2011 | DISH Network IR Remote Control
    Como programar comtrol dish
    Hola! Soy Kimberly Escobar con DISH Network, Sera un placer asistirle con la informacion que necesita. Para poder programar un control y proveerle los pasos exactos a seguir necesitariamos saber si esta programando el control al recibidor o a su televisor. Este link le ayuda en como programar el control a su recibidor o televisor. http://www.dishnetwork.com/SupportSection/remote-setup. Si tiene preguntas adicionales me puede contactar directamente a mi correo electronico kimberly.escobar@dishnetwork.com sera un placer ayudarle con cualquier pregunta que tenga.
    DISH Network
    Kimberly Escobar
    Jun 01, 2011 | DISH Network IR Remote Control
    Como programar un control nuevo a la caja de dish.
    hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
    May 12, 2011 | DISH Network IR Remote Control
    Como programo un control remoto de dish uhf pro para usar una tele aoc muchas gracias
    Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
    Feb 17, 2011 | DISH Network IR Remote Control
    Como puedo programar mi control de dish en la segunda tv la tv es panasonic
    Hola mi nombre es Mayra Diaz con DISH Network. La manera m?s f?cil para programar el control de DIsh a su tele Panasonic es siguiendo estos siguientes pasos. Presione el bot?n de blanco de TV hasta que las cuatro luces se han prendido luego presione 700,734,673, siguiendo con el bot?n # localizado abajo del 9. Ahora intente subir su volumen para verificar si funciona. Los tres c?digos se tienen q tratar individualmente siguiendo los mismos pasos. Si tiene alguna otra pregunt? por favor escribanos.
    Dec 13, 2010 | DISH Network IR Remote Control
    Como programar un control de dish
    Como programarla ala tv
    Hola mi nombre es Mayra Diaz con Dish Network. Con much gusto le puedo ayudar a programar su control a su televisor. Primero que todo necesitamos saber cual es la marca de su televisor para darle los c?digos que funcionen con su televisor espec?ficamente.
    Aug 15, 2010 | DISH Network IR Remote Control
    Como programo la caja del dish
    Hola mi nombre es Mayra Diaz con DISH Network con mucho gusto le puedo ayudar a programar su caja de DISH. Si por favor me puede dar mas detalles de lo que pasa como el modelo de la caja, es un recibidor nuevo? Ya teniendo estos detalles le puedo asistir con un mejor conocimiento.
    Aug 04, 2010 | DISH Network IR Remote Control
    Televison & Video Logo
    20 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
