How to fix a Nima digital-decorating instant light show? Reset button does not seem to pop out or activate/reset.
2 Suggested Answers
How to fix a Nona Digital-Decorating instant light show. Reset button will not push in did it popout, hard to tell. O.L. Is the only display.
Sounds like the switch has popped out of it's housing. Try to reseat it after cleaning around the area. If that doesn't work, try unscrewing the housing (usually at least 4 phillips screws) and pop the switch back in that way. Of course I don't have to tell you to make sure it's unplugged before you operate on it. Good luck!
Dec 23, 2016 | Miscellaneous
I have a Noma Digital Decorating Instant Light Show Timer and I cannot find the instruction sheet on how to use it. It has 19 preprogrammed light shows and the display shows OL and will not let me reset...
the manual says each unit has a maximum load of 3 amps (abt 7 one hundred mini light sets). when ANY INDIVIDUAL outlet is overloaded,ALL lights will turn off and an outlet overload message (OL) will be displayed. To reset,unplug unit,then unplug some of the lights in the outlet that appears to be overloaded and plug unit back in
Dec 02, 2011 | Hardware & Accessories
After being reset and plugged back into computer to charge, a red light pops on as soon as plugged back into usb port to charge and will not turn on.
Put a pin in the reset button situated in the tripod hole.Do it three times for about thirty seconds each time.Also depress the on off switch for about thirty seconds.Put it in the usb port of your computer to charge.After about thirty minutes or an hour the screen should go white.A battery shows on the screen.Wait till the battery shows all green,then it is fully charged.
Oct 28, 2010 | Pure Digital Flip Mino Digital Camera
Conversation area does not show after tapping enter botton and i cannot add emotions when chatting.
make sure you have the latest version, if you do then you will have to uninstall and reinstall messenger
Sep 05, 2009 | Yahoo Messenger
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
Zune 8GB - Won't turn off
Warranty activated yet? Get it done. Then create a Repair Order online, or call Zune support at 1-877-438-9863, if you dare.
That is your best bet. Y'all got mechanical problems and nuthin ain't gonna help that in FixYa. Sorry, chum
Feb 03, 2009 | Microsoft Zune JS8-00001 Digital Media...
Wont turn on
You can reset the player without losing the music, but Repairs and firmware Updates will result in songs being erased.
Make sure the hold/lock switch is not activated.
If it is not, then try a different USB port on your computer.
If you get the same result:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Dec 27, 2008 | Philips SA3025/37 Flash MP3 Player
Olymp. DS-330,None of the Buttons respond at all,only hold slider
If you remove the batteries and reinstall, does the display indicate Hold at some point? The hold button sometimes breakes and doesn't activate the switch. Pop off the hold button and move the internal switch manually.
Nov 21, 2008 | VXI Corporation VTR-3200 Handheld Digital...
Garmin Etrex Vista Date problem
Thanks to a hint from a user on another web forum, I have found a fix, at least for now.
Specifically, a normal "master rest" on the eTrex Vista is accomplished by holding down the "Page" button and "Enter" (i.e. the click stick) while powering up. You are prompted that a full reset will occur, and after confirming, the machine is reset. However, in my case, this achieved a full reset, but did not fix the date problem.
However, the undocumented "super master reset" on the eTrex Vista is achieved by simultaneously holding down the "Page, "Enter" and "Find" buttons while powering up. You have to hold all buttons in for about 5 to 7 seconds, and you DON'T get the warning message, but when the machine finally restarts, it is fully reset. After acquiring a satellite fix (took several minutes) - lo and behold - my time AND date both seem to be correct!
Oddly, neither Garmin tech support nor the local reseller seemed to know about this method of REALLY resetting the machine - I will pass on the information to them, for future reference.
The link which documents the "super master reset" procedure is here:
Hope this might also help other eTrex Vista owners who are experiencing the same date problem.
Nov 17, 2007 | Garmin eTrex Vista GPS Receiver
23 people viewed this question
