Question about Bissell Vacuums
Bissell proheat pet brush is spinning but loud noise and vibration at same time
When you move it forward or back is grinding and no glide action as if tearing the rug up
    Master:
  • Bissell Master
  • 894 Answers
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has not work properly. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Dec 30, 2016
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
My Bissell Proheat 12 amps' brush keeps dragging on the carpet when I go to push it forwards. And it releases alot of water.
Mine is doing the exact same thing..Push it forward and it makes a awful noise. The Brush on the bottem is loose and it isnt spinning. SO i took and turned it over and there is a metal gear like part that runs the belt on the brush. I took it out and cleaned it...basically because it was just hanging in there..not Turning the belt..AND NOW I cant get it back in..I am totally disgusted as it hasnt been used very much at all. I cant get the gear metal piece back in to see if it works.IT Just falls out. and its a bear to get it in there..
Feb 07, 2010 | Bissell 8910 ProHeat Clear View Upright...
Bissell proheat perfect pass
Manuals for all Bissell machines can be downloaded from www.bissell.com.
Mar 12, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Bissell Proheat 12 amp is hard to push forward(whether on or off). There is a loud clicking noise when pushing forward and it ''jumps'' up on every loud click. It's OK when pulling backwards, sprays and...
I had this same problem and here is what solved it for me. On a previous cleaning session, my wife decided to take the two front screws out of the clear plastic shroud that covers the brushes in order to clean behind it. Upon re-installation, she did not secure the top part correctly. On the end near the water tank, there are two tiny half-moon tabs that absolutely need to be seated in their opposing slots in the chassis.This allows for a good seal which enables the machine to **** up the water. It also keeps the front cover level and from dragging on the carpet when pushing it forward. Both were problems I was experiencing. Hope this helps!
Mar 09, 2009 | Bissell 1699 ProHeat Clear View Upright...
Making noise
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tyt
Nov 18, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View uses very little soap.
The valve at the bottom of the soap tank may have gone bad, Also try running a mix of water and vinegar(not on carpet) to see if it will clean the system out. The system may just need cleaning out.
Jun 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
283 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
