WORD 2007 TIP: HOW TO USE SHORTCUTS FOR SPELL-CHECK
Spell-check has been around for years; however, it just keeps getting better!Microsoft Office 2007 Spell-check is even more intuitive and easy-to-use.You'll find Spell-check by clicking on the Review Tab located on the Ribbon, and then select Spelling and Grammar from the Proofing Group.If you don't use Spell-check very often, you may have trouble remembering which Tab to click on (I know that I do).
As a trainer, I've learned that each individual works differently.That's why I like to present different methods of performing the same task, especially if it can save time and help a student work more efficiently. I personally think it's much easier to simply press the F7 key to initiate Spell-check.That's because I favor keyboard shortcuts.Some students prefer to create customize toolbars with their favorite features.In Word 2007, you can't customize the Ribbon, however you can customize the Quick Access Toolbar:
1.Start MS Word 2007
2.Go to the Customize Quick Access Toolbar button (It's located at the top left of the screen and it looks like a small arrow with a bar on top of it.)
3.Select Spelling & Grammar from the list.
4.You should see a Spelling & Grammar button appear on the Quick Access Toolbar.
5.The next time you want to use SpellCheck, just click on the new button you created. Both of these shortcuts will save you time to help you work more efficiently!
Did you install the Logitech Set Point software? If you did, you can edit the Function key assignments by opening that program. There are other ways to change your keyboard settings, pressing Left Alt and Shift can do this with Windows 7 by default. To check this in Windows 7, click Start > Control Panel. Under Clock, Language, and Region select Change Keyboard or other Input method. Once that window opens, click on the Keyboards and Languages tab and click Change Keyboards. Then select the Advanced Key Settings tab. There is a section marked Hot Keys for Input Language.
HERE is the Logitech instructions to set the Date and Time
As for the caps lock indicator, this is provided by the Logitech SetPoint software available here. If you already have the software installed (usually there will be a small icon on the tray in lower right corner you can double click to bring up the interface. Under the tools tab, the top check box toggles on and off the caps lock status notification.
Your keyboard should have some type of button on the bottom that "resets" it. Your keyboard has bounced to a new channel that is not recognized by the reciever. I kept having this problem so now I use a wireless mouse but, a corded keyboard.
Place the CD that came with the Logitech keyboard into your computer's CD drive. Allow the computer several seconds to load the contents of the disc.
Step 2
Follow the pop-up on-screen instructions to install the keyboard's set drivers.
Step 3
Plug the keyboard into the computer.
Step 4
Navigate to "Control Panel" in the "Start" menu of Windows. Then double-click on the "Keyboard" icon.
Step 5
Click on the "Buttons" tab in the keyboard window. This will take you to a screen where you can set the functions of custom buttons on the keyboard.
Step 6
Click on each button setting and use the on-screen options to set functions for each of them. Also, if desired, set custom functions for the "F1" through "F12" keys and others.
You should not need any additional hardware - but you may have to install a driver (software).
If you just bought the keyboard it should have come with an installeation disc. If you don't have that you can go to the following Logitech website and peform the auto scan function (your new keyboard should be attached via USB cable.
This scan will detect the keyboard and tell you if you need any additional drivers installed.
this is a known issue with outlook express so the resolution is to use third party spell check for outlook express
download and install the spell check for outlook express http://www.snapfiles.com/get/spelloe.html
