Removable wheel for oil heater - Heating & Cooling
Any user manual/documentation for an oil-filled heater, Italian, name on nameplate Omas? Today I purchased a used one.
luckily most
caster wheels can be interchanged or retro fitted to any oil heater
take one of the castors with you
just takes time to find 4 that will suit your heaters fitment
big hardware stores or a known caster wheel seller ,ebay
heater oil is heater oil so that can be sourced easily
a few older style Omas oil heaters for sale in New Zealand
newer models from amazon
cant find its user manual online
or a parts supplier that will carry Omas parts
Oct 13, 2016 | Heating & Cooling
Where do I get wheel set for my 14 fins heaterthey are very weak plastic wheels, the hinge part.
Try places like Home Depot, Lowes, Harbor Freight, etc. They stock a variet of wheels and casters.
May 05, 2014 | DeLonghi 6707E Oil Filled Radiator Heater
Hi. 2 side wheels on my oil heater have broken. Can I replace them? Where will I find them?
Remove one that is good and go to some hardware depot with the sample. There is usually one equivalent in hardware shops. Ask the counter personnel if they can help you. Be careful that the thread size matches. You put the sample thread against the substitute so you will see no gaps in between the threads then you have perfect match. You will need to replace all four. Try buying one first. If it fits, buy the other three. The leveling would be different.
Mar 12, 2014 | DeLonghi TRD0715T Oil Filled Radiator...
Broken Wheel
look at theplate and see if it has a phone number u can call or go on line and try to find their website or jus go to where it was purchased and they can point u in the right direction
Feb 22, 2010 | Lakewood Oil-Filled Electric Radiator...
Speedometer goes very slow both up and down again on a 1981 yamaha xs 400 special. how do i solve this? is there a heater in the speedometer and is it replaceable. there is a bulb and something that look...
there is no heater. remove the cable from front wheel to speedo, lube it with 3 in 1 oil (or any other thin oil), remove speedometer and put a few drops of oil where the the cable goes into it. my first bike was a brand new 1982 xs400 when i was 17, ah the memories
Aug 28, 2009 | 1981 Yamaha XS 400 Special
Patton POH2501
take a hole punch and knock a hole in each end, one on the top, one on the bottom and drain the oil into a 2 litre plastic bottle. Now you can recycle both!
Oct 23, 2007 | Holmes Products POH2501 Oil Filled...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
