Question about Elmo Projectors Omnigraphic 301 Slide Projector
My Kodak 800 carousel projecter will not select slide into viewing position or rotate
Glad the cycle solenoid solution helped identify the problem with the Carousel 800! Let me know if I can assist with anything else, and if you are able to get the 800 fixed!
Sep 30, 2011 | Office Equipment & Supplies
The slides appear to be dropping to far down so when viewed you see the top of slide (cardboard) and top half of picture- thi swas given to me used and I dont have a book - it is 300AF
Try using a full thickness plastic slide mount. Some card slides are so thin that they miss the slide support when being dropped down from the magazine. Some magazines are designed specifically for card mounted slides whilst other are for glass mounted slides. Types shouldn't be mixed for correct and consistent operation.
Feb 14, 2011 | Elmo Projectors Omnigraphic 301 Slide...
Where in Canada can I obtain bulbs for a Vivitar 2000AF slide projecter 24 volt 150w Q.I ( hanimex type A1/216
Try They have an amazing assortment of discontinued lamps! Good Luck !!
Feb 13, 2011 | Vivitar V5000AF Slide Projector
I am hooked up to a projecter but the projecter is not projecting my computer screen i am using an acer aspire 5315-2153 i have pressed shift-f8 and shift-f5
Your laptop screen resolution is to high for the project to show, on the laptop goto the display properties by right clicking on the screen, goto settings, in that window at the bottem you will see a slider that says resolution adjust slide the slider back towards the left until the setting 800 by 600 is showing, then on the other side change the bit rate to 16bit or 24bit, click apply, OK , and turn the laptop off, rig up the projector and turn the laptop back on, you should now have your windows screen on your projector. hope this helps and post back your results. thanks.
Oct 30, 2010 | Acer Aspire 5315 Notebook
I'm having a problem loading a tray on a 440 slide projecter any solutions?
check for any gears noise, any dirty magazine mec., any error displayed?
Jan 14, 2010 | Kodak Carousel 4400 Slide Projector
Change headlight blub
The whole head lamp assembly has to come out to replace the headlight bulb. Here's how to do it.
Here is a link to instructions
Jun 18, 2009 | 2002 Jeep Grand Cherokee
Apparent fixture problem for halogen plug
This dimmer was not made to dim a load smaller than 40VA. That halogen bulb would only have been 20VA or so.
I think that when your bulb burnt out, the dimmer over-volted the transformer and smoked it. That said, I think you have a fixture problem and, possibly, a switch problem, too.
May 17, 2009 | Lamson HOME PRODUCTS AR180 "PLUG IN...
Slide carousel rapide speed
The problem is caused by a mis-adjusted clutch contact. This adjustment requires some dis-assembly, so unless you have service manuals for the Carousel 600, I would recommend you find a factory-trained repair dealer.
Apr 23, 2009 | Kodak Office Equipment & Supplies
How to replace blub in headlight
The entire headlight comes out from the exterior of the car. When you open your hood, there is a lever that you need to slide up. The light will then pop out and you will be able to replace the bulb and then pop the light back in. You will have to push hard inorder to get the lever to go back down. We had better luck with two of us doing it... one pushing... the other working the lever.
Apr 06, 2009 | 2003 Volkswagen Beetle TDI
Elmo Projectors Omnigraphic 301 Slide Projector Logo
47 people viewed this question
Top Elmo Projectors Office Equipment & Supplies Experts
Are you an Elmo Projectors Office Equipment and Supply Expert? Answer questions, earn points and help others
