Question about Acer Computers & Internet
Please need your help. When i put on my laptop( acer tmp 453) the screen is totally black. Happened after removing RAM and hard disk
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Did you put the RAM back in? A PC will not boot without RAM. If you put the ram back in and its still doing it i would try reseating the RAM module(s) or trying different slots.
Posted on Dec 23, 2016
  • Anonymous Dec 24, 2016
    THANK FOR THAT IT WORKED. IT CAME BACK AND STILL STOPS AT THE ACER SCREEN.
  • Corey Fields
    Corey Fields Dec 24, 2016
    If it is stopping at the acer post screen then it sounds like there is no Operating system installed, the operating system is stored on the hard drive, make sure the hard drive is plugged in. If it is plugged in then maybe the operating system needs to be re installed
    Problem Solver:
  • 21 Answers
If the system beeps while booting than reset the RAM. Clean the RAM with eraser and than insert in its slot. System will not display without RAM.
Posted on Dec 24, 2016
ComputerDave
  • 128 Answers
SOURCE: acer laptop
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
Posted on Feb 02, 2008
  • 244 Answers
SOURCE: acer extensa 5220 - how do I remove the hard disk?
Checked if there is rubber behind the harddrive, that rubber is used for holding harddrive so it won't loose from motherboard.
If there is any, you can removed the rubber first. the rubber shape is like block.
Posted on Apr 26, 2008
SOURCE: I need this driver please
TRY TO CHANGE THIS IN SET UP
Posted on Nov 08, 2008
SOURCE: Acer 4520 Power up for 1 second and turns off
in acer4520 auto power off within 5 sec
Posted on Apr 06, 2011
joecoolvette
  • 5660 Answers
SOURCE: Hp laptop... black screen... caps lock flashes 5
When the Caps Lock flashes, it is then being used in a diagnostic mode. 5 times flashing means a problem with the System Board.
Motherboard.
I don't doubt it.
Two common problems, all based on one issue.
Overheating.
1) Problem One;
Primer;
The Processor, and the GPU are the two hardware components that produce the most heat.
[ GPU = Graphics Processing Unit. Slang? Graphics chipset,
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
GPU,
http://en.wikipedia.org/wiki/GPU ]
It could be something as simple as foam has melted, and melted down onto the motherboard, near the Processor socket. Removal puts the laptop back into service again.
It could be much more complicated, and follow an issue that has beleaguered the HP Pavilion dv2000 series, dv6000 series, and dv9000 series.
The cooling system for the GPU is inefficient. Allows the GPU to overheat.
Constant overheating partially melts the solder connections of the GPU to the motherboard.
The graphics chipset (GPU) is mounted to the motherboard with a BGA surface mount.
Ball Grid Array,
http://en.wikipedia.org/wiki/Ball_grid_array
To explain the BGA surface mount;
Compare to an older Intel Pentium 4 processor, and it's Socket 478 processor socket,
http://en.wikipedia.org/wiki/Socket_478
The processor has contact pins on the bottom. (478 of 'em) These line up with matching socket holes in the Socket 478 processor socket. (478)
With a BGA surface mount there are no contact pins, nor socket holes.
Solder Balls take the place of the contact pins, and Copper Pads take the place of the socket holes.
The graphics chipset's Solder Balls, are lined up with the matching Copper Pads on the motherboard.
Heat is then applied at a specific temperature, and length of time.
This procedure melts the Solder Balls, and solders the graphics chipset to the Copper Pads.
(Motherboard)
With constant overheating the solder connections that were created, start to melt. This creates a poor connection.
The professional method to repair this problem, is to use a BGA Rework Machine, to Properly re-solder the connections.
Due to the location of repair shops that have a BGA Rework Machine, and the C-O-S-T, many are attempting to perform the procedure with a non-professional method.
A thin metal shield is cutout in the middle, for the graphics chipset. This shield is set over the graphics chipset, and lays on the motherboard. Heat is then kept just to the graphics chipset, and the other components on the motherboard are protected.
Heat is applied with a propane torch, or a hot air gun, (Not hair dryer), in a circular (Spiral), pattern to the graphics chipset. With a more proper method used, the tip of a thermometer that can read this heat range, is laid on the chipset, and is used to keep the chipset at a specific temperature.
(Too much heat will burn up the chipset. Too little will not properly remelt the solder connections. A Cold Solder joint, or joints, will result)
The heat from the heating instrument, (Propane Torch/Hot Air Gun), is rotated around in a spiral pattern on the chipset. Constant moving around to distribute the heat evenly.
(You do not want a 'hot spot')
When the specific heat range is met, the heating instrument is slowly moved away from the chipset.
Move up an inch or so, keep spiraling. Then move up another inch or so, and keep spiraling the heat source. Slowly move up in increments while spiraling. S-L-O-W-L-Y back away. Method is used so that the chipset slowly cools down. Otherwise a cold solder joint, or joints, could result.
(Right back to where you started)
This link is to a video that shows one style of the procedure. It is not an advertisement for the video, just linked for the procedure information,
http://www.youtube.com/watch?v=bnkQNmKauEc&feature=pyv&ad=5823851286&kw=DV9000
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Nov 12, 2011
Acer Aspire 5315 Screen Keep Go Black
Does changing your power options in control panel make any difference?
Dec 18, 2012 | Acer Aspire 3680 Laptop
Acer Aspire 5336 boot/screen/ram problem
Yeah, sounds like a ram problem. You can try re-seating it by pulling it out and putting it back in or its very possible the ram has gone bad and you will need to replace it.
Oct 24, 2012 | Acer Aspire 5336-2283 Notebook
Acer 5334 stuck on e recovery management screen
By stuck do you mean that each time you boot the computer it goes to this screen? If this is the case then unfortunately this means something has happened to the installation of your operating system on your hard drive and in order to get Windows to load, you will need to perform this recovery. This could be caused by any sort of damage to the partition that the OS installation is on which could be caused by hard drive failure, corrupted data or physical disk damage.
I hope this helps.
Jun 27, 2011 | Computers & Internet
HI MY LAPTOP SUDDENLY BLACK OUT AN HOUR OR TWO AGO..WHILE I'M PLAYING OFFLINE GAME. I CAN OPEN THE LAPTOP BUT THERE'S NOTHING IN THE LCD.IT'S JUST BLACK.. I TRIED TO DO ALT CRTL DEL BUT NOTHING...
Hi
I get that you was play on the notebook and it was hang and give black screen ...
please try this steps and I hope that helps you :
1- if you don't shutdown the notebook please click along on power button to shutdown the device and then open it again.
2- if you do that you must check about any voice appear when you start the device like Beep ...if there I think there's a RAM Problem or VGA.. if RAM it,s make long beep ..
3- if there is no sound thin you must note if the start up info appear in screen like Acer,CPU and RAM info , Boot info ....
4- if it appear I think you need new operating system , else may be its Video card problem ..
you can also remove the RAM and restore it may be that solve the problem.
Apr 24, 2011 | Acer Aspire 5100 Notebook
I have an Acer Aspire 7720-6182 and when I open it, the screen stays totally black please help!
I had this last week on my Acer 5536. The only solution is to re-install the operating system from a saved disk - you lose all folders, alas, unles you can save them from the hard drive.
Oct 27, 2010 | Acer Aspire 7720 Notebook
ACER Aspire 1804 LT won't boot
From what you describe it sounds like you have some kind of hardware problem possibly related to the hard-drive connection. Try starting it with the hard-drive removed it should at least show the bios screen. If it doesn't then you should start removing hardware(CD-ROM, RAM, etc) using a process of elimination. If you don't want to go though all that you could just sell it on eBay for part.
Jul 14, 2010 | Acer Aspire 1804WSMi Notebook
Black Screen
this mean it cannot boot due to a faulty hardware device that cannot startup (hard disk, vga, soundcard, camera etc).
first of all remove the hard drive and and see if it boots-up then remove dvd.
(this is easy just unscrrew the hdd cover at the bottom of the laptop)
if not, replace ram - if you are lucky and have two ram modules installed, take the one out see if it boots and if not put it back and take the other one out. unfortunately all of the other devices that might cause the problem are built in (on the main board). so, if its for example the video card or the sound card you should look for a new laptop as motherboards are expensive (check with an authorized acer repair shop to see if its worthed)...
Sep 03, 2009 | Acer Aspire One PC Notebook
MY Acre Aspire 3680 is Frozen! Need some Heat- appreciated :)
This one can do to remove the Hard Disk and try to enable it without hard disk.
if the problem is both are still remove the memory and clean it.good luck
Aug 15, 2009 | Acer Aspire 5720-6661 Notebook PC
Can you hear the system fan running? If the fan fails, the PC shuts down itself to protect the processor from FRYING.
Apr 14, 2009 | Acer Aspire 4520-5582 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
