Where to get superior gas fireplace igniter - Heating & Cooling
  • 667 Answers
Ebay
Posted on Dec 23, 2016
3 Suggested Answers
milten1
  • 1304 Answers
SOURCE: I have a used unvented gas fireplace with no
check with you local building inspector
they will give you all the codes for clearence
Posted on Oct 10, 2009
  • 744 Answers
SOURCE: Need a manual (preferably a pdf I can print) for
The number you provided is for a blower kit. However, I was able to find a pdf for you that should describe your fireplace. See this link:
http://www.lennoxhearthproducts.com/resources/manual/725024%20NC-%20BCF_BRF_38_43(C&O).pdf
The blower kit is described at the end of the manual.
Posted on Mar 18, 2010
Our superior gas fireplace operates via remote control. Worked yesterday. Not today. And yes I did change the batteries in the remote. Thank you
Your remote may need to be paired again with the receptor on your fireplace.
Find your model number and check out the documentation for your model from this site:
http://superiorfireplaces.us.com/tech_support/documents
Jan 10, 2018 | Heating & Cooling
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
Gas fires troubleshooting
The thermocouple might not be close enough to the pilot.
Jan 25, 2014 | Water Heaters
I HAVE A HC3820 AND AM CURRENTLY LOOKING TO OBTAIN A BLOWER. THE PROBLEM IS THAT THE ONE NEEDED FOR THIS MODEL IS FAK-1500 AND I CANT FIND IT ANYWHERE! PLEASE HELP!
Honestly, go to www.grainger.com. Since Superior/Lennox Hearth/and FMi are all merging into one company you are going to have a very hard time finding replacement parts for older Superior units. Plus the new company, Astria Fireplaces, is going to be using FMI for their woodburning products so no more Superior products available.
If you bring the old blower to your local Grainger they can match it up. I hope this helps.
Jan 24, 2014 | Superior FBK-200 Fireplace Blower Kit for...
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Cant start gas fireplace
  • Find the remote's receiver under the fireplace.
  • There should be a switch to change from "remote" to "ON".
  • Turn the switch to "ON", if the fireplace ignites, you may need to re synchronize your remote. If it does not, your remote control may be bad.
  • Bypass the remote to ensure your fireplace is operational by connecting the "TH" and "TP/TH" terminals on the valve with a wire or paperclip. If the fireplace lights up fine, then it is for sure a bad remote.
  • Universal gas fireplace remotes can be found HERE.
Oct 28, 2012 | Empire Comfort Systems Empire Tahoe...
I'm looking for a user manual for a Superior Gas Fireplace model FAK 1500. I want to know how to take off the front glass as it has become covered in a white residue.
The fak 1500 number is for the blower assembly. I found this manual for a fireplace using the blower assembly. hope it is what you are looking for. Lennox has bought out the fireplace company and there are no manuals available under superior.
Feb 11, 2011 | Heating & Cooling
Can one use unvented gas logs in a superior CF3860 fireplace?I
Little documentation on this fireplace but it appears to be a vented wood-burner(?) If vented, there should be no problem using gas logs. If burning correctly, you may consider cutting back on the flue and intake air, as moisture build-up is the biggest drawback to gas fireplaces. Too much air is just wasting gas.
Dec 03, 2010 | Heating & Cooling
Need a manual (preferably a pdf I can print) for the Superior FAK 1500 gas fireplace.
Mar 17, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
