Question about Tablets & eReaders
I forgot my nobis screen lock - Tablets & eReaders
How do i factory rezet my nobis tablet when its froze and wont go past the nobis emblem screen?
Hi Jeffrey, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
How To fix any Android Phone Tablet that won turn on
Apr 30, 2016 | Tablets & eReaders
Lost password Nobis 1022C what do I do.
I already answered you. You need to do a Factory Reset.
  • How to reset 9" nobis tablet to factory setting? - How do ... www.askmefast.com > Consumer Electronics > TVs > Reset Nobis internet table recovery mode. You can perform a factory restore on the phone to get back in. power off phone, then boot into recovery mode by holding volume up ...
  • Nobis 9" Tablet 8GB Memory Dual Core - Walmart.com www.walmart.com > ... > Nobis 9" Tablet 8GB Memory Dual Core Nobis 9" Tablet 8GB Memory Dual Core. ... I have called customer support twice and performed a simple reset and a factory ... I went on the Nobis site to look ...
  • How to I factory reset my nobis 7" tablet? - Ask Me Fast www.askmefast.com > ... > Reset Factory reset nobis pad. The volume keys wont navigate when trying to factory reset my tablet? ... How to i factory reset my nobis 7 tablet?
  • Apr 03, 2016 | Tablets & eReaders
    Nobis 9" blue tablet. why is the screen backwards and reversed?
    Not sure what version of Android O/S you are using but in
    Settings > Developer Options look for:
    Force RTL Layout Direction
    If it's got a checkmark then uncheck it.
    Jun 12, 2015 | DOUBLE POWER TECHNOLOGY Nobis NB09BLUE 9"...
    My nobis 9" tablet keeps popping up windows saying unfortunately blah blah has stopped working. i turned it off and turned it back on and now i can't even get the home screen. please help
    Nobis 9 tablets are defective. Many, if not most, of them end up having bad internal memory. They might work for a week, a month or maybe even two months but, sooner or later, theminternal memory goes bad. When this happens you get the stopped working error messages and in many cases it will no longer boot up. Just Google, Nobis NBO9 stuck on go and you will see you aren't the only one who got ripped off when you bought this POS.
    I know, I have one. I sent it in when the internal memory went bad. Cost me 20 bucks postage. They fixed it and sent it back. It worked about two weeks and the internal memory went bad again. Then they gave me the runaround and refused to issue me an RMA.
    Stay away from anything sold by Bidwell that uses the Nobis brand. Better yet stay away from Bidwell period. They are rip off artists, IMO.
    Apr 07, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
    My nobis tablet is stuck on the nobis start up screen. How do I fix it.
    If you Google NobisNB09 stuck on GO you will find many angry people who have the same problem. Rarely does the factory reset procedure work to fix it. IMO they have a problem with faulty internal SD chips. So, what I'm saying is you may not be able to fix the problem other than trying to get an RMA and sending it back for repair if it's still in the warranty period.
    Here is the factory reset procedure.
    1) press and hold at the same time both the power button and the volume(-) button.
    2) keep holding them until you see the Nobis screen, Then it will go off. Keep on holding both buttons down for perhaps ten or fifteen more seconds and finally you will see a screen with some green text options
    3) Among the options is one that says something like "wipe data/factory reset.
    4) Using the volume (+) button scroll to it and then press the power button once to select it.
    5) Another screen will come up with text options of no, no no for five or six lines with one that has a go ahead for the reset option. Again, using the volume (+) to scroll to the reset option and select it using one push of the power button.
    6) you will get a reboot option.
    7) reboot by pushing the power button, it will turn off.
    8) Give it a minute or so and then push the start button and
    hold it until you see the Nobis screen. Let it go and wait. If the hardware's OK it will go through the initialization routine which
    should take several minutes. Anything more than about ten
    minutes without going to the set up screen indicates you have
    bad hardware such as a faulty internal SD memory.
    One hint: turn off your wi-fi router so it can't connect to wi-fi.
    It will boot up with the wi-fi ON and it will connect to any open
    router it can find and commence to download updates for all the apps. This makes it take forever and can completely fill
    up the available app partition memory and result in another failure to boot up next time.
    IMO the Nobis NBOP is a POS! I have one so I know.
    Apr 06, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
    I bought my son a 7inch Nobis tablet for his bday and he forgot the password what do I do?
    When you forgot your password and exceeded the tries you can enter it with, your account will be locked and will have to be unlocked using your internet connection (WiFi or data connection). Your device will ask you for your gmail and password. Once able to provide, they will ask which you prefer to reset and it is done. Unfortunately, not everyone is connected when the account is locked. You will have to do the following when this happens: - turn off device - press the following: volume up/down or both power button home button (if any) OR press the reset button/hole -wait for a logo to appear before letting go -choose recovery mode -choose wipe data/factory reset -choose yes -device will restart or will ask you to restart and confirm.
    Jan 07, 2015 | Tablets & eReaders
    Tablet stuck on go logo
    play mother may i :)
    turn it on with a computer usb cable plugged in
    turn it on holding vol cont up +
    turn it on while flapping the other arm
    you ddint say mother may i
    Aug 31, 2014 | DOUBLE POWER TECHNOLOGY Nobis NB09BLUE 9"...
    Nobis tablet froze and won't go past nobis screen
    Do a factory restore, using the buttons on the tablet. The procedure varies but typically it's Hold VOLUME DOWN and POWER buttons at the same time. When (if) you get a menu, choose factory reset. The sad news is she will lose all her pics, music, apps, etc. but the tablet should work.
    Jul 20, 2014 | Tablets & eReaders
    I have a nobis Tablet.I tried to do a hard reset hut won't go past nobis screen. I already held down volume button ans power button and it stays on the nobis screen. Please help
    guess is that the float level is not closing (need to open float bowl and clean everything inside with carb cleaner. Confirm that the float is operating (up and down) . Reassemble and try again...should be fine.
    May 25, 2014 | Tablets & eReaders
    Nobis Tablet has blurry screen and is unable to read.
    You should go see somebody that's good with electronics.
    Dec 26, 2013 | Tablets & eReaders
    Tablets & eReaders Logo
    29 people viewed this question
    Top Tablets & eReaders Experts
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
